POV-Ray : Newsgroups : povray.binaries.images : Cheap Grass Server Time
23 Jul 2026 08:56:56 EDT (-0400)
  Cheap Grass (Message 12 to 21 of 21)
Subject: Re: Cheap Grass
Date: 22 Sep 2001 20:51:18
Message: <3bad3206$1@news.povray.org>
"Rune" <run### [at] mobilixnetdk> schrieb im Newsbeitrag
news:3bacbd42@news.povray.org...
> "Tony[B]" wrote:
> > I think the white and brownish lines are what give it away.
> > That, and the fact that there is no fuzziness on the horizon.
> Perhaps the attached version is slightly better?
> > Nice though. :)
> Thanks! :)
> Can anyone guess the trick I used?
I think, if it isn't a material/pigment-map,than maybe either an Isosurf or
Media, but both of them would be slow ... I don't see any artefacts of fast
mediasettings, but it seems to have some volume (as you can see at the edges
of the path)
at least it inspired me to the following 15mins hack (most time was waiting)
could you tell, if it's the right direction ?
// place some camera and lights here ...
plane { // ground and  lower limit of the container
  y, 0
  pigment { color rgb <0.7,0.5,0.3> }
difference { // this should be the container of the grass
    plane {y, 0.1}
    torus {3,0.3 scale y*20 translate x+1} // cut the path out of this ...
    hollow    // of course, we are playing with media
    pigment { color rgbt <0,0,0,1> }  // we ONLY play with media !
    finish { ambient 0 diffuse 0}     //  --------"-------------
    interior {
        media {        // here we go ...
            absorption 35   // we have small features ...
            samples 128,128   // and so we need much samples
            density {
                bozo        // I think every pattern playes well
                color_map { // one part of the secret is the colormap
                    [0, color rgb 0]     //  85% nothing happens
                    [0.85, color rgb 0]  //
                    [0.85, color rgb <0.9,0.25,0.9>]  // but here we
                    [1, color rgb <0.9,0.7,0.9>]      // create blades
                frequency 1.5         // to make it a bit denser ...
                scale <0.01,5,0.01>  // thats the other part of the trick
                warp { turbulence <0.3,0,0.3> } // and of course ...
this renders without AA at 1180PPS here ... what is quite fast, i think ...
Jan Walzer <jan### [at] lzernet>
"Microsoft: because choices are confusing..."
Date: 22 Sep 2001 20:54:33
Message: <3bad32c9$1@news.povray.org>
interesting. the forground looks painted, which i like a lot.
Date: 23 Sep 2001 06:26:03
Message: <3badb8bb@news.povray.org>
Looks much better with the road, helps to add a sense of scale :)
(i have no idea how you did it!)
PGP Public Key
Date: 23 Sep 2001 07:43:55
Message: <3badcafb@news.povray.org>
Well, actually it's supposed to be a small path, just half a meter wide, but
I don't think I succeeded in making it look that way. That's not so
important though.
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated June 26)
Date: 23 Sep 2001 07:43:59
Message: <3badcaff@news.povray.org>
"Batronyx" wrote:
> 3.5 function pigment?
Well, yes, but that doesn't say so much does it? ;)
> Couldn't begin to guess the specific formula.
I'll post it in a little while.
> It occurs to me that maybe you could replace the
> darker colors with transparency and use two copies
> of the ground stacked one above the other for a
> little extra realism. What do you think?
I've already done that. That's why the horizon is slightly fuzzy. :)
Rune
Date: 23 Sep 2001 07:44:04
Message: <3badcb04@news.povray.org>
"Mike Williams" wrote:
> If it's that fast it must just be a texture
Yep.
> I'd guess something like this:
>     scale <0.01,1,0.1>
That wouldn't work because of perspective, but you've guessed the basic
principle, only it's a bit more complicated.
Rune
Date: 23 Sep 2001 07:44:09
Message: <3badcb09@news.povray.org>
"Glen Berry" wrote:
> I like these, but I think they look more like the
> texture of some types of fur, carpet, or perhaps
> "Astro-turf", than actual grass. Have you tried
> simulating any of these other materials, using
> this technique  yet?
Nah, I'd prefer it to look like grass... :(
Rune
Date: 23 Sep 2001 07:44:14
Message: <3badcb0e@news.povray.org>
"Jan Walzer" wrote:
> I think, if it isn't a material/pigment-map, than maybe
> either an Isosurf or Media, but both of them would be slow
It's a texture... :)
> ... I don't see any artefacts of fast mediasettings, but
> of the path)
I'm using several copies of the object one on top of the other...
Rune
Date: 23 Sep 2001 07:44:19
Message: <3badcb13@news.povray.org>
Thanks!
Rune
Date: 23 Sep 2001 13:58:30
Message: <3bae22c6@news.povray.org>
"Rune" <run### [at] mobilixnetdk> wrote in message
news:3badcaff@news.povray.org...
No it doesn't. :) Just emphasizing your use of the new
functions over more traditional texture techniques.
Great! I'll check it out. Enjoyed playing with some
of your crackle variants recently. :)
I see that now. Hmmm. . . Perhaps some extra surface displacement on the top
layer to make the fuzzy/jagged effect more pronounced? It looks fresh
mowed on the edges but not in the middle. It might increase the realism
somewhat.
Impressive any way. :)
> Rune
> 3D images and anims, include files, tutorials and more:
