POV-Ray : Newsgroups : povray.binaries.images : Duet Server Time
23 Jul 2026 12:23:12 EDT (-0400)
  Duet (Message 11 to 19 of 19)
Subject: Re: Duet
Date: 29 Aug 2001 06:47:40
Message: <3b8cc84c$1@news.povray.org>
Radiosity artifacts, probably caused by the hole of the "body".
Jonathan
"Peter Hertel" <NOS### [at] hertelno> ha scritto nel messaggio
news:3b8c173f@news.povray.org...
> That's one big flute :) I remember the holes in my flute to be bigger, but
> it might be some other kind of flute. If it's one of these flutes you can
> take apart, it's a bit hard to see the intersection between the "body"
with
> holes and the "head".
> There are two dark spots in the bottom of the image, where do they come
> from?
> Peter
> http://hertel.no/peter
Subject: Re: Duet
Date: 29 Aug 2001 06:50:46
Message: <3b8cc906@news.povray.org>
"Daniel Lin" <dli### [at] yahoocom> ha scritto nel messaggio
news:3b8c1b32@news.povray.org...
> Comments, aside from the scale?  :)  Well, maybe a piano bench and light,
> but otherwise, nice.  The recorder I have is plastic and breaks up into
> three pieces like that one, but the joints on mine stick out a little
more.
> That is a recorder, right?
Ehm...perhaps it's me but I don't see the point...
Jonathan
Subject: Re: Duet
Date: 29 Aug 2001 06:52:20
Message: <3b8cc964@news.povray.org>
I just didn't want to wait too much....;)
Anyway this one took only 1h and 47 minutes...
Jonathan
"Dave Blandston" <gra### [at] earthlinknet> ha scritto nel messaggio
news:3b8c6f10@news.povray.org...
> Just one small suggestion - the piano suffers a lot from aliasing - try
> rendering it with anti-aliasing method 2 (+am2 +r3 on the command line
> usually works pretty well...)
> -Dave
> "JRG" <jrg### [at] hotmailcom> wrote in message
> news:3b8c0ffc@news.povray.org...
> > A sunny musical duet.
> > Comments?
> > Jonathan
Subject: Re: Duet
Date: 29 Aug 2001 08:11:05
Message: <3b8cdbd9@news.povray.org>
"Lutz-Peter Hooge" <lpv### [at] gmxde> ha scritto nel messaggio
news:MPG.15f637e8f8e0bf48989684@news.povray.org...
> In article <3b8c0ffc@news.povray.org>, jrg### [at] hotmailcom says...
> > Comments?
> I think the proportions are slightly incorrect,
do you?!
>but I may be wrong ;-)
You are. These are two souvenirs taken by a friend of mine, a certain
Gulliver, during his travels... ;)
> The textures are very good, except that wooden thingy on the piano that
> is for covering the keys if its unused (don't know how that thing is
> correctly called).
"Cover"?
> That looks like is has a strange normal.
No strange normals used. The texture is the same for every part of the
piano.
Jonathan
Subject: Re: Duet
Date: 29 Aug 2001 09:22:29
Message: <3b8cec95@news.povray.org>
Believe me. I've seen those spots before. They happen when you mix "objects
on a plane lit with a dome" radiosity and reflective objects. Increase
max_trace_level enough and they'll go away.
Subject: Re: Duet
Date: 29 Aug 2001 15:06:58
Message: <3b8d3d52@news.povray.org>
Sorry, I thought you were referring to those little dots at the end of the
flute...
I'll give it a try. :)
Jonathan
"Tony[B]" <ben### [at] catholicorg> ha scritto nel messaggio
news:3b8cec95@news.povray.org...
"objects
Subject: Re: Duet
Date: 29 Aug 2001 18:10:26
Message: <3b8d6852@news.povray.org>
but
can
> with
> > from?
> That is not a flute, I belive it is a recorder.
What's a "recorder" anyway? Some other kind of flute? If it is, what's the
difference?
Peter
Subject: Re: Duet
Date: 29 Aug 2001 19:54:14
Message: <3b8d80a6@news.povray.org>
news:3b8d3d52@news.povray.org...
> flute...
That's where the camera aligns with the lathe, only fix I know of is to
offset them enough to where the camera isn't on a plane intersecting the
extra-radial realm of the lathe.
Bob H.
Subject: Re: Duet
Date: 29 Aug 2001 22:47:10
Message: <3b8da92e@news.povray.org>
> difference?
I really know nothing about musical instruments so don't take my word for
gospel;-) A recorder is a completely different woodwind instrument, at least
from the modern flute. Most modern flutes are metal.
