POV-Ray : Newsgroups : povray.binaries.images : GI test. No radiosity - just light dome. Server Time
14 Jan 2026 01:35:46 EST (-0500)
  GI test. No radiosity - just light dome. (Message 1 to 5 of 5)
Subject: GI test. No radiosity - just light dome.
Date: 20 Aug 2001 23:58:20
Message: <3b81dc5c@news.povray.org>
I was just experimenting with using a dome of low powered point lights
instead of radiosity, and here is the resulting image.
The small image shows the placement of the light grid.
Unfortunately, I placed the lights using a couple of #while loops, and this
leads to more lights being grouped together directly above the scene. Anyone
know how to code a geodesic dome kind of thing, so the lights are evenly
spaced? The code should easily allow for using a small number of lights for
test renders, and then upping the number of iterations (?) for final
renders.
I quite like the effect anyway, although even 100% jpeg is unkind to the
smooth areas.
Andy Cocker
Download 'GI-test-show-grid.jpg' (6 KB) Download 'GI-test.jpg' (54 KB)
Preview of image 'GI-test-show-grid.jpg'
Preview of image 'GI-test.jpg'
Subject: Re: GI test. No radiosity - just light dome.
Date: 21 Aug 2001 00:43:44
Message: <3b81e700$1@news.povray.org>
a buckminsterfulleren has a theoretically ideal distribution on a sphere.
But a half sphere is limited to only 30 points.
Here I have the coordinates (from my warm_up entry last round)
light_source{< 14580,    8540,  -29570> color rgb 0.1}
light_source{<  1320,   10620,  -32310> color rgb 0.1}
light_source{< 21160,   16820,  -20690> color rgb 0.1}
light_source{< 14450,   27140,  -14650> color rgb 0.1}
light_source{<  1100,   29230,  -17430> color rgb 0.1}
light_source{< -5450,   21000,  -26210> color rgb 0.1}
light_source{< 29880,   11510,  -11560> color rgb 0.1}
light_source{<-18180,   19080,  -21550> color rgb 0.1}
light_source{<-24260,    6770,  -22920> color rgb 0.1}
light_source{<-31590,    1520,  -12620> color rgb 0.1}
light_source{<-19570,   26180,   -9870> color rgb 0.1}
light_source{< -7620,   32460,   -7320> color rgb 0.1}
light_source{< 19050,   28180,   -1790> color rgb 0.1}
light_source{< 28580,   18540,     150> color rgb 0.1}
light_source{<-33040,    8630,    -820> color rgb 0.1}
light_source{<-27170,   20980,     480> color rgb 0.1}
light_source{< -2940,   33720,    5650> color rgb 0.1}
light_source{< 10330,   31450,    8450> color rgb 0.1}
light_source{< 29440,   11970,   12250> color rgb 0.1}
light_source{<-32360,    2060,   11240> color rgb 0.1}
light_source{<-22700,   22150,   13090> color rgb 0.1}
light_source{<-10250,   28770,   15770> color rgb 0.1}
light_source{< 11310,   25060,   20570> color rgb 0.1}
light_source{< 20810,   15150,   22440> color rgb 0.1}
light_source{< 17610,    3530,   29050> color rgb 0.1}
light_source{<-26080,   10060,   20000> color rgb 0.1}
light_source{< -1110,   23170,   25300> color rgb 0.1}
light_source{< -4450,   11060,   32240> color rgb 0.1}
light_source{<  4820,    1500,   33960> color rgb 0.1}
light_source{<-16900,    4490,   29540> color rgb 0.1}
But it looks not very homogenous with primitives, you can see distict
shadows on planes.
Norbert
"Andy Cocker" <big### [at] mariner9fsnetcouk> schrieb im Newsbeitrag
news:3b81dc5c@news.povray.org...
> Hi,
this
Anyone
for
> renders.
> smooth areas.
> Andy Cocker
Date: 21 Aug 2001 01:05:22
Message: <3B81ECB3.BA81DA7D@engineer.com>
To be specific about this you are using point lights instead of a dome
and 1 bounce radiosity. Radiosity can do much more than that :)
BTW, where does this desire to use a hemisphere of lights to replace
radiosity (http://roy.gmxhome.de/) come from ? It's a rather limited
arrangement and 1 bounce radiosity should be as fast.
_____________
Kari Kivisalo
Date: 21 Aug 2001 06:36:48
Message: <slrn9o4e5l.7u3.steve@zero-pps.localdomain>
On Tue, 21 Aug 2001 04:53:38 +0100, Andy Cocker wrote:
>Hi,
Interesting stuff.
 11:31am  up 38 days, 13:35,  2 users,  load average: 1.01, 1.02, 1.00
Date: 21 Aug 2001 14:11:51
Message: <3b82a467@news.povray.org>
Hey,
Looks cool, though the shadows at the base of the pillars look odd (you can
see the smaller column, which is quite in shade, thought the ground just
below it isn't).
As for the whole geodesic dome thing, take a look at
http://www.cris.com/~rjbono/html/domes.html. There is C++ source code for
generating geodesic dome coordinates, as well as a Windows program that
outputs Povra scene files. Just found it through a Google search.
All the best,
Element
