POV-Ray : Newsgroups : povray.binaries.images : YMPRF final (~110k) Server Time
23 Jul 2026 15:57:23 EDT (-0400)
  YMPRF final (~110k) (Message 15 to 24 of 24)
Subject: Re: YMPRF final (~110k)
Date: 26 Jul 2001 09:42:44
Message: <3B601EC0.7D3DA222@gmx.de>
Jaime Vives Piqueres wrote:
>   But, if so, how Gilles radiosity scenes look so nice? I my self tried
> just now pretrace start and end to 1 with my current irtc entry, and the
> result is a 30% faster than with the recommended settings.
Of course it's faster, but is it better?  It would be really nice to see
some samples for comparison.
There is also the opposite approach BTW:
low pretrace_end, always_sample off and using save_file / load_file.
> And,
> strangely, the result seems to be more "natural" although it has some
> artifacts. Perhaps for "dirty" scenes it adds some irregularity that
> looks better to our "anti-perfectly-clean" minds. In any case, I would
> stick to 1 at least for that concrete scene, cause it renders faster and
> the result looks slightly better.
I always find this kind of 'dirt' quite confusing and unnatural. NTL, if
you have a nice example showing this effect i would be eager to see it.
Date: 26 Jul 2001 10:33:34
Message: <3B602A33.40307AE7@ignorancia.org>
  Well, at least the increased time seems to not justify the little
quality added. I don't want to show my current entry now, but at the end
of the round I will post both versions.
  I've substracted both images and the difference is not really visible.
I had to highly  increase bright and contrast on the differenced image
to see which zones changed. At the eye, the only visible difference is
the behavoir of layered textures. With pretrace=1 it seems more like
without radiosity, while with the recommended setting the layers seems
to "blend" (obviously that must happen bcos more rays come trough,
isn't?), making the texture strange. Perhaps the problem is that we must
create the layered textures thinking on the later use of radiosity...
http://www.ignorancia.org/
Date: 26 Jul 2001 10:39:23
Message: <3B602B8C.51ABF449@inapg.inra.fr>
> result is a 30% faster than with the recommended settings. And,
> artifacts.
To be frank, it's very confusing. I just tested this and the truth is that I
don't have a proper answer. In one little test scene, using Christoph's rad
"IndoorHQ" settings, using pretrace values <1 is better than pretrace 1
values : slightly lower rendering times, slightly less artifacts (but
artifacts nonetheless).
Now I'm sure to have experienced the same speed boost as you just noticed,
which is why I've been using these settings for almost a year with no
visible problems (I think that it was Xplo who found this trick). Note that
this could also explain why I don't have artifacts when I stop and resume
radiosity scenes (something I've been doing systematically to save memory,
even with 640 Mb of RAM).
I guess we should test this on full scenes. I just launched one of these
(800*320) with pretrace activated, and will render it again without. I
should have some answers on Saturday...
G.
http://www.oyonale.com
Graphic experiments
Pov-ray gallery
Date: 26 Jul 2001 13:32:59
Message: <3B6054B9.26F7D8AB@gmx.de>
I have done some quick tests myself, not as valuable as testing in a real
scene, but it shows the effect in different situations:
http://www.schunter.etc.tu-bs.de/~chris/rad/radiosity_pretrace.html
Note that the times given are not extremely accurate.
It seems that in some situations differences in both quality and speed are
quite low, in other cases it's much faster without pretrace, but also much
lower quality.
What seems interesting to me is that in the first sequence (without light
sources) the 'medium settings' (last picture) give the best quality of all
the three cases.
Date: 26 Jul 2001 17:35:53
Message: <3B608DAB.C20C51A1@unforgettable.com>
> > artifacts.
It's been a while since I actually messed with pretrace parameters, but
IIRC, error_bounds > .1 benefit visually from a really precise pretrace
(although above .4 or so, the benefit may not be worth the time anyway),
whereas smaller error_bounds don't, so pretrace should be set to 1 to
save time. Don't take this as absolute gospel, though; these are
approximations off the top of my head, and not based on extensive testing.
It's worth pointing out that the messier your scene naturally is (due to
texturing, or objects casting a lot of small shadows, or something), the
less perfect your radiosity has to be. Those of you who like making
radiosity scenes where everything is apparently made out of smooth gray
plastic might do well to keep that in mind...
-Xplo
Date: 27 Jul 2001 06:00:40
Message: <3B613BB8.14224559@inapg.inra.fr>
My feeling too. My rule of thumb would be like this:
[1] test renders with no quality requirement : pretrace 1 (saves time)
[2] final renders with error_bound < 0.1 : pretrace 1 (saves time)
[3] all other types of radiosity renders  : small pretrace values may save time
and improve quality
BTW, I was too optimistic about my current test renders as the first one (with
pretrace<1) is crawling at 150 points per minute. No answers (checking rule [2])
until next Monday at best.
This is true, and particularly for flat surfaces. However, in my experience, small
error_bound values are always needed to get accurate shadows below objects placed
in radiosity-lit areas.
G.
Graphic experiments
Pov-ray gallery
Download 'periphdetail6.jpg' (16 KB)
Preview of image 'periphdetail6.jpg'
Date: 27 Jul 2001 06:25:03
Message: <3B6141F4.B655DCD0@unforgettable.com>
Yeah, but you can at least reduce the count if the artifacts won't be noticed.
-Xplo
Date: 27 Jul 2001 07:53:57
Message: <3B6156CA.9574E8DE@gmx.de>
> and improve quality
I have made some more test renders, available on the URL posted in the
other subthread.  The differences in speed are quite marginal and the
quality differences seem to diminish with lower error_bound, just like
Xplo said.
Date: 2 Aug 2001 09:22:36
Message: <3B6914F7.5D8E369A@inapg.inra.fr>
Much too optimistic... The second render just finished. The comparison was between a
pretrace_start/pretrace_end =1/1 render and a 0.08/0.01 one.
Note that the experiment was not scientific, because Povray was running in the
background with a low priority while I working with other CPU-consuming apps
(databases) during half of the renders. I also had to make a slight change on a
texture between the two renders (I guess with no effect on the render time).
- identical render times : 27h 46 min
- substracting the image shows some little differences (in the parts not touched by
the texture change) but final appearance could be said identical apart one
antialiasing problem with the 0.08/0.01 image.
Other rad params were :
count 400
error_bound 0.05
nearest_count 4
recursion_limit 1
low_error_factor 1
gray_threshold 0.15
minimum_reuse 0.015
brightness 1.5
adc_bailout 0.01/2
normal on
Attached: two PNG (extracts of the final images) of 58 kbu each.
G.
Graphic experiments
Pov-ray gallery
Download 'periph2.png' (58 KB) Download 'periph1.png' (58 KB)
Preview of image 'periph2.png'
Preview of image 'periph1.png'
Date: 2 Aug 2001 17:31:53
Message: <3b69c6c9@news.povray.org>
AWESOME ROLEX! No really I can't believe this is rendered. Perhaps part of
it is the small size of the picture but I still say that is unbelievably
realistic.
"Gilles Tran" <tra### [at] inapginrafr> wrote in message
news:3B6914F7.5D8E369A@inapg.inra.fr...
(with
rule [2])
between a
the
apps
on a
time).
touched by
> count 400
> error_bound 0.05
> nearest_count 4
> recursion_limit 1
> low_error_factor 1
> gray_threshold 0.15
> minimum_reuse 0.015
> brightness 1.5
> adc_bailout 0.01/2
> normal on
> G.
> Graphic experiments
> Pov-ray gallery
