POV-Ray : Newsgroups : povray.binaries.images : YMPRF final (~110k) Server Time
23 Jul 2026 15:57:23 EDT (-0400)
  YMPRF final (~110k) (Message 11 to 20 of 24)
<<< Previous 10 Messages Goto Latest 10 Messages Next 4 Messages >>>
Subject: Re: YMPRF final (~110k)
Date: 26 Jul 2001 03:07:31
Message: <3B5FC21F.DF935776@gmx.de>
Thomas Lake wrote:
> Hmm this is an interesting discusion, I've been wondering what these
> settings really do, the pov docs arn't much help here. I'll have to do some
> testing to see how different settings affect different images, but I'm not
> going to play with this image any more.
In general lower pretrace_end leads to better quality, but very often
1/image_width is more than necessary.  It should correspond to
error_bound, there meaning a lower error_bound should have a lower
pretrace_end.
Some suggested values are:
error_bound 3  => pretrace_end 0.08
error_bound 1  => pretrace_end 0.02
error_bound <1 => pretrace_end 0.01
but they only give a rough idea, for low error_bounds you will probably
have to try what leads to the best quality/speed ratio.
Date: 26 Jul 2001 07:55:03
Message: <3b600517@news.povray.org>
news:3B5FC21F.DF935776@gmx.de...
> > settings really do, the pov docs arn't much help here. >
> error_bound
    This is one of the aspects of radiosity that I just don't understand -
from reading the docs I don't see how or why error_bound and pretrace_end
are related...
Scott Hill.
Software Engineer.
E-Mail        : sco### [at] innocentcom
Pandora's Box : http://www.pandora-software.com
*Everything in this message/post is purely IMHO and no-one-else's*
Date: 26 Jul 2001 09:01:34
Message: <3B60151B.91A6F755@gmx.de>
> are related...
I don't have a precise technical explanation, but with high error_bound
lower pretrace_end values have no effect.  In other words, if you use
1/image_width, you will be on the safe side concerning quality, but the
last pretrace steps are totally unnecessary for the result.
Date: 26 Jul 2001 09:11:53
Message: <3B60170F.403DB754@ignorancia.org>
> pretrace_end.
  But, if so, how Gilles radiosity scenes look so nice? I my self tried
just now pretrace start and end to 1 with my current irtc entry, and the
result is a 30% faster than with the recommended settings. And,
strangely, the result seems to be more "natural" although it has some
artifacts. Perhaps for "dirty" scenes it adds some irregularity that
looks better to our "anti-perfectly-clean" minds. In any case, I would
stick to 1 at least for that concrete scene, cause it renders faster and
the result looks slightly better.
Jaime Vives Piqueres
http://www.ignorancia.org/
Date: 26 Jul 2001 09:42:44
Message: <3B601EC0.7D3DA222@gmx.de>
Of course it's faster, but is it better?  It would be really nice to see
some samples for comparison.
There is also the opposite approach BTW:
low pretrace_end, always_sample off and using save_file / load_file.
> And,
I always find this kind of 'dirt' quite confusing and unnatural. NTL, if
you have a nice example showing this effect i would be eager to see it.
Date: 26 Jul 2001 10:33:34
Message: <3B602A33.40307AE7@ignorancia.org>
  Well, at least the increased time seems to not justify the little
quality added. I don't want to show my current entry now, but at the end
of the round I will post both versions.
  I've substracted both images and the difference is not really visible.
I had to highly  increase bright and contrast on the differenced image
to see which zones changed. At the eye, the only visible difference is
the behavoir of layered textures. With pretrace=1 it seems more like
without radiosity, while with the recommended setting the layers seems
to "blend" (obviously that must happen bcos more rays come trough,
isn't?), making the texture strange. Perhaps the problem is that we must
create the layered textures thinking on the later use of radiosity...
Date: 26 Jul 2001 10:39:23
Message: <3B602B8C.51ABF449@inapg.inra.fr>
> artifacts.
To be frank, it's very confusing. I just tested this and the truth is that I
don't have a proper answer. In one little test scene, using Christoph's rad
"IndoorHQ" settings, using pretrace values <1 is better than pretrace 1
values : slightly lower rendering times, slightly less artifacts (but
artifacts nonetheless).
Now I'm sure to have experienced the same speed boost as you just noticed,
which is why I've been using these settings for almost a year with no
visible problems (I think that it was Xplo who found this trick). Note that
this could also explain why I don't have artifacts when I stop and resume
radiosity scenes (something I've been doing systematically to save memory,
even with 640 Mb of RAM).
I guess we should test this on full scenes. I just launched one of these
(800*320) with pretrace activated, and will render it again without. I
should have some answers on Saturday...
G.
http://www.oyonale.com
Graphic experiments
Pov-ray gallery
Date: 26 Jul 2001 13:32:59
Message: <3B6054B9.26F7D8AB@gmx.de>
I have done some quick tests myself, not as valuable as testing in a real
scene, but it shows the effect in different situations:
http://www.schunter.etc.tu-bs.de/~chris/rad/radiosity_pretrace.html
Note that the times given are not extremely accurate.
It seems that in some situations differences in both quality and speed are
quite low, in other cases it's much faster without pretrace, but also much
lower quality.
What seems interesting to me is that in the first sequence (without light
sources) the 'medium settings' (last picture) give the best quality of all
the three cases.
Date: 26 Jul 2001 17:35:53
Message: <3B608DAB.C20C51A1@unforgettable.com>
> > artifacts.
It's been a while since I actually messed with pretrace parameters, but
IIRC, error_bounds > .1 benefit visually from a really precise pretrace
(although above .4 or so, the benefit may not be worth the time anyway),
whereas smaller error_bounds don't, so pretrace should be set to 1 to
save time. Don't take this as absolute gospel, though; these are
approximations off the top of my head, and not based on extensive testing.
It's worth pointing out that the messier your scene naturally is (due to
texturing, or objects casting a lot of small shadows, or something), the
less perfect your radiosity has to be. Those of you who like making
radiosity scenes where everything is apparently made out of smooth gray
plastic might do well to keep that in mind...
-Xplo
Date: 27 Jul 2001 06:00:40
Message: <3B613BB8.14224559@inapg.inra.fr>
My feeling too. My rule of thumb would be like this:
[1] test renders with no quality requirement : pretrace 1 (saves time)
[2] final renders with error_bound < 0.1 : pretrace 1 (saves time)
[3] all other types of radiosity renders  : small pretrace values may save time
and improve quality
BTW, I was too optimistic about my current test renders as the first one (with
pretrace<1) is crawling at 150 points per minute. No answers (checking rule [2])
until next Monday at best.
This is true, and particularly for flat surfaces. However, in my experience, small
error_bound values are always needed to get accurate shadows below objects placed
in radiosity-lit areas.
G.
Graphic experiments
Pov-ray gallery
Download 'periphdetail6.jpg' (16 KB)
Preview of image 'periphdetail6.jpg'
