POV-Ray : Newsgroups : povray.binaries.images : YMPRF Server Time
25 Apr 2026 14:47:48 EDT (-0400)
  YMPRF (Message 1 to 10 of 12)
Subject: YMPRF
Date: 15 Jul 2001 03:52:43
Message: <3b514bcb@news.povray.org>
Yet More Pure Radiosity Fun:-)
I was talking about making a poster of one of my images, I'm thinking this
one would look good.
pretrace_start 0.01
pretrace_end   0.005
recursion_limit 2
error_bound 0.4
nearest_count 10
count 900
So if I want to render a super high quality one I don't have a hell of a lot
of room left to get red of those artefacts, especially considering count
maxes out at 1600.
Download 'box rad.JPG' (94 KB)
Preview of image 'box rad.JPG'
Subject: Re: YMPRF
Date: 15 Jul 2001 04:12:23
Message: <Xns90DF67D3D38FBseed7@povray.org>
> of a lot of room left to get red of those artefacts, especially
> considering count maxes out at 1600.
Assuming this is a no_light_source pic, why not put in an area_light?
It would help a lot with the artefacts, without changing the mood of
the image.
Ingo
Subject: Re: YMPRF
Date: 15 Jul 2001 04:22:44
Message: <3b5152d4$1@news.povray.org>
I thought of that and I'll probably give it a try, though it will probably
change the mood a bit, unless I make everything shadowless.
"ingo" <ing### [at] homenl> wrote in message
news:Xns### [at] povrayorg...
> the image.
> Ingo
> Photography: http://members.home.nl/ingoogni/
> Pov-Ray    : http://members.home.nl/seed7/
Subject: Re: YMPRF
Date: 15 Jul 2001 04:28:28
Message: <3b51542c$1@news.povray.org>
One thing that bothers me is that the glass cylinder is just crying out for
photons but without a light source photons don't work. And I am trying my
best to resist putting in a light source;-)
Subject: Re: YMPRF
Date: 15 Jul 2001 12:22:06
Message: <3B51C391.4147A978@gmx.de>
I never tried it, but wouldn't light groups be a solution for that?
Subject: Re: YMPRF
Date: 15 Jul 2001 17:41:56
Message: <3B520E89.D00A058A@infomagic.com>
> pretrace_start 0.01
> pretrace_end   0.005
> recursion_limit 2
> error_bound 0.4
> nearest_count 10
> count 900
> maxes out at 1600.
If you have a lot of time and a ton of RAM to burn, you can try dropping
error-bound to some absurdly small figure (.03 or thereabouts). You'll
still have artifacts, but with any luck (and a bit of tweaking to find
the right numbers) they'll be so small that you won't be able to see them.
-Xplo
Subject: Re: YMPRF
Date: 15 Jul 2001 17:51:48
Message: <3B5210D7.35F00240@infomagic.com>
Oh, a couple other suggestions while I'm at it: darken the pigment on
the metal ball (diffuse*pigment+reflection should be <= 1 for shiny
metals), and while there's no brightness setting for photons as there is
for radiosity (and shouldn't there be?), you could try a very weak light
with a very strong caustic for the glass cylinder.
-Xplo
Subject: Re: YMPRF
Date: 15 Jul 2001 18:31:09
Message: <3b5219ad@news.povray.org>
> metals),
Hmm I could raise the brightness value above the default in the finish.
I might give that a try, I tried that with photons but of course, as you
said, without a "brightness" setting you can't see any caustics with a very
dim light.
Subject: Re: YMPRF
Date: 15 Jul 2001 18:34:32
Message: <3b521a78@news.povray.org>
My experience has been that in scenes with pure radiosity lowering
error_bound does more harm than good. Usually you get thousands of
artefacts, like there are hundreds of light sources casting hundreds of
shadows or something. You can't go below about 0.4 before the scene becomes
unsaveable.
Subject: Re: YMPRF
Date: 15 Jul 2001 18:35:23
Message: <3b521aab@news.povray.org>
Could you please explain what you mean? I've never used light groups.
