POV-Ray : Newsgroups : povray.binaries.images : Impossible triangle Server Time
29 Mar 2026 02:38:36 EDT (-0400)
  Impossible triangle (Message 1 to 10 of 26)
Subject: Impossible triangle
Date: 6 Jul 2001 13:09:36
Message: <3b45f0cf@news.povray.org>
The impossible triangle with cubes was first invented by the
Swedish artist Oscar Reutersvard back in 1934.
  This image has two tricks. The first one is obvious (the triangle). But
there's another trick which may not be obvious. Can you guess what it is?
Download 'ImpossibleTriangle.jpg' (48 KB)
Preview of image 'ImpossibleTriangle.jpg'
Subject: Re: Impossible triangle
Date: 6 Jul 2001 13:16:31
Message: <3b45f26f@news.povray.org>
The boxes which are more distant from the camera are bigger (so that they
all look the same size)?
BTW great effect!
Jonathan
"Warp" <war### [at] tagpovrayorg> ha scritto nel messaggio
news:3b45f0cf@news.povray.org...
> #macro N(D,I)#if(I<6)cylinder{M()#local D[I]=div(D[I],104);M().5,2pigment{
> rgb M()}}N(D,(D[I]>99?I:I+1))#end#end#macro M()<mod(D[I],13)-6,mod(div(D[I
> ],13),8)-3,10>#end blob{N(array[6]{11117333955,
> 7382340,3358,3900569407,970,4254934330},0)}//                     - Warp -
Date: 6 Jul 2001 15:45:12
Message: <3b461548$1@news.povray.org>
The big block in the background is actually the same size as the blocks in
the triangle?
Date: 6 Jul 2001 17:19:20
Message: <MPG.15b04a033c332d099897f2@NEWS.POVRAY.ORG>
In article <3b45f0cf@news.povray.org>, Warp says...
The image wasn't done with POV alone, but you used some image editor,
right??
Regards,  Sander
Date: 6 Jul 2001 18:00:34
Message: <3b463501@news.povray.org>
Sander <san### [at] stolscom> wrote:
: The image wasn't done with POV alone, but you used some image editor,
: right??
  A suggestion like this is a great offence. I would never go that low!
  The image is made entirely with (hand-coded) POV-Ray code and one render,
and no external files. All the objects in the image are real 3D primitives
and all textures are regular POV-Ray procedural textures (eg. no image maps
nor anything).
Date: 6 Jul 2001 18:01:42
Message: <3b463543@news.povray.org>
JRG <jrg### [at] hotmailcom> wrote:
: The boxes which are more distant from the camera are bigger (so that they
: all look the same size)?
  Well, no. The second trick isn't related to that.
: BTW great effect!
  Thanks.
Date: 6 Jul 2001 18:02:36
Message: <3b46357b@news.povray.org>
Thomas Lake <tla### [at] homecom> wrote:
: The big block in the background is actually the same size as the blocks in
: the triangle?
  Nope. It's truely bigger (in fact, exactly 6 times).
Date: 6 Jul 2001 21:28:57
Message: <3b4665d9$1@news.povray.org>
The shadows go the opposite direction to the visible light source??
Nice pic btw :)
Dave
Date: 7 Jul 2001 06:18:31
Message: <3b46e1f6@news.povray.org>
Davey B <kry### [at] totalisecouk*nospam*> wrote:
: The shadows go the opposite direction to the visible light source??
  Nope. There are two light sources, and nothing special is related to them.
Date: 7 Jul 2001 07:12:05
Message: <MPG.15b10d2958944fcf9897f3@NEWS.POVRAY.ORG>
In article <3b463501@news.povray.org>, Warp says...
> : right??
> nor anything).
No offence meant and intended: I stupidly forgot the :) in my reply.
When I look at the left vertical vertices of the vertical stack of cubes
I get the impression that there is a lack of AA, as if these cubes have
been cut out and pasted. That made me make my offensive remark...
But I suppose there are other reasons for this to happen :))))
Regards,  Sander
