POV-Ray : Newsgroups : povray.binaries.images : Request for help with media Server Time
9 Jun 2026 11:00:10 EDT (-0400)
  Request for help with media (Message 7 to 16 of 16)
<<< Previous 6 Messages Goto Initial 10 Messages
Subject: Re: Request for help with media
Date: 22 Jun 2001 00:41:17
Message: <3b32cc6d@news.povray.org>
Thanks Ian.  I'll give it a try.
Jim
"Ian Burgmyer" <the### [at] hotmailcom> wrote in message
news:3b32cb61$1@news.povray.org...
> "Jim Kress" <kre### [at] kressworkscom> wrote in message
> news:3b32be05$1@news.povray.org...
> > Also, I am using version 3.1g.
> To improve the quality, btw, imcrease the number of samples up.  I'd say
> samples 3,5 should work for what you're using.  Just stick that into all
the
> media blocks you're using, and the effect should look real nice when
you're
> done.
> Prepare to leave your computer on overnight, though :-/
> -Ian
Date: 22 Jun 2001 00:49:50
Message: <3b32ce6e@news.povray.org>
Ian,
OK. Tried your suggestion with megapov 0.7  The results are attached.
Media looks better except the top and both sides have been chopped off (or
left off).  Any ideas what's going wrong or how to fix?
Thanks.
Jim
Download 'rohf_density_001_mpov7.jpg' (29 KB)
Preview of image 'rohf_density_001_mpov7.jpg'
Date: 22 Jun 2001 00:56:03
Message: <3b32cfe3$1@news.povray.org>
This was using
   method 3
   intervals 1
   samples 3,5
   confidence 0.999
   variance 1/1000
Jim
news:3b32ce6e@news.povray.org...
> Ian,
> Thanks.
> Jim
Date: 22 Jun 2001 00:59:38
Message: <3b32d0ba@news.povray.org>
Here's another result using:
   method 3
   intervals 20
   samples 3,5
   confidence 0.999
   variance 1/1000
What's going on with this?  Looks like the sampling algorithm is not
behaving properly.
Jim
the
you're
> done.
> -Ian
Download 'rohf_density_001_mpov7_2.jpg' (29 KB)
Preview of image 'rohf_density_001_mpov7_2.jpg'
Date: 22 Jun 2001 03:13:24
Message: <3b32f014@news.povray.org>
news:3b32d0ba@news.povray.org...
>    method 3
>    intervals 20
>    samples 3,5
>    confidence 0.999
>    variance 1/1000
> behaving properly.
I hadn't seen the number of layers your df3 might be made up of but that
intervals change suggests to me there are a few.   Nathan Kopp has made the
method 3 somehow figure the intervals out on it's own (I'm guessing) and
maybe what you really need to do is increase the samples.  I often use equal
numbers.  Perhaps a samples 10,10 is okay for you?  If not there's always
method 2 and samples 5,5 could possibly do well.
Bob H.
Date: 22 Jun 2001 11:28:33
Message: <3b336421@news.povray.org>
Thanks.  I'll give it a try.
Jim
"Bob H." <omn### [at] msncom> wrote in message
news:3b32f014@news.povray.org...
> >    method 3
> >    intervals 20
> >    samples 3,5
> >    confidence 0.999
> >    variance 1/1000
> > behaving properly.
the
equal
> Bob H.
Date: 22 Jun 2001 13:24:11
Message: <3b337f3b@news.povray.org>
OK.  It turns out that, although media is supposed to be contained within a
unit cube, it really isn't.
If you lok at my inc file, you'll see I used a unit cube box to contain the
media so it could be rendered.  Well, if I change the box specification from
 box{ <0,1>
to
 box{ <0,0,-2>, <2,2,2>
the problem goes away, as one can see in the attached image.  Hopefully this
does not indicate there is a bug in megapov.
Thanks for your suggestions!
Jim
Download 'rohf_density_001_5,5_samples_intervals_10_bounding_box_fixed.jpg' (27 KB)
Preview of image 'rohf_density_001_5,5_samples_intervals_10_bounding_box_fixed.jpg'
Date: 22 Jun 2001 17:12:51
Message: <3b33b4d3@news.povray.org>
news:3b337f3b@news.povray.org...
a
the
from
>  box{ <0,1>
> to
this
I can't see that happening here, using spiral.df3 in place of your df3, the
media is contained within the 1 unit cube as described in the doc.
I thought perhaps it could be wave type but default is ramp_wave and looked
okay to me anyway. Most likely thing could be you are getting some sort of
perspective trouble.  Make your box transmit 0.5 instead of 1 and you can
see where the sides are.
Bob H.
Date: 24 Jun 2001 16:06:43
Message: <3B3648D1.D868817C@pobox.com>
Jim Kress wrote:
> Attached is a volumetric rendering using media.  What is the best way
> (i.e. best quality for shortest rendering time) to get rid of the
> graininess and get nice, smooth colors?
I think it's quite pretty as is.
Anton Sherwood  --  br0### [at] p0b0xcom  --  http://ogre.nu/
Date: 24 Jun 2001 17:23:22
Message: <3b365a4a$1@news.povray.org>
Thanks.
Jim
"Anton Sherwood" <bro### [at] poboxcom> wrote in message
news:3B3648D1.D868817C@pobox.com...
