POV-Ray : Newsgroups : povray.binaries.images : Request for help with media Server Time
9 Jun 2026 11:00:12 EDT (-0400)
  Request for help with media (Message 11 to 16 of 16)
Subject: Re: Request for help with media
Date: 22 Jun 2001 03:13:24
Message: <3b32f014@news.povray.org>
"Jim Kress" <kre### [at] kressworkscom> wrote in message
news:3b32d0ba@news.povray.org...
> Here's another result using:
>    method 3
>    intervals 20
>    samples 3,5
>    confidence 0.999
>    variance 1/1000
> What's going on with this?  Looks like the sampling algorithm is not
> behaving properly.
I hadn't seen the number of layers your df3 might be made up of but that
intervals change suggests to me there are a few.   Nathan Kopp has made the
method 3 somehow figure the intervals out on it's own (I'm guessing) and
maybe what you really need to do is increase the samples.  I often use equal
numbers.  Perhaps a samples 10,10 is okay for you?  If not there's always
method 2 and samples 5,5 could possibly do well.
Bob H.
Date: 22 Jun 2001 11:28:33
Message: <3b336421@news.povray.org>
Thanks.  I'll give it a try.
Jim
"Bob H." <omn### [at] msncom> wrote in message
news:3b32f014@news.povray.org...
> >    method 3
> >    intervals 20
> >    samples 3,5
> >    confidence 0.999
> >    variance 1/1000
> > behaving properly.
the
equal
> Bob H.
Date: 22 Jun 2001 13:24:11
Message: <3b337f3b@news.povray.org>
OK.  It turns out that, although media is supposed to be contained within a
unit cube, it really isn't.
If you lok at my inc file, you'll see I used a unit cube box to contain the
media so it could be rendered.  Well, if I change the box specification from
 box{ <0,1>
to
 box{ <0,0,-2>, <2,2,2>
the problem goes away, as one can see in the attached image.  Hopefully this
does not indicate there is a bug in megapov.
Thanks for your suggestions!
Jim
Download 'rohf_density_001_5,5_samples_intervals_10_bounding_box_fixed.jpg' (27 KB)
Preview of image 'rohf_density_001_5,5_samples_intervals_10_bounding_box_fixed.jpg'
Date: 22 Jun 2001 17:12:51
Message: <3b33b4d3@news.povray.org>
news:3b337f3b@news.povray.org...
a
the
from
>  box{ <0,1>
> to
this
I can't see that happening here, using spiral.df3 in place of your df3, the
media is contained within the 1 unit cube as described in the doc.
I thought perhaps it could be wave type but default is ramp_wave and looked
okay to me anyway. Most likely thing could be you are getting some sort of
perspective trouble.  Make your box transmit 0.5 instead of 1 and you can
see where the sides are.
Bob H.
Date: 24 Jun 2001 16:06:43
Message: <3B3648D1.D868817C@pobox.com>
Jim Kress wrote:
> Attached is a volumetric rendering using media.  What is the best way
> (i.e. best quality for shortest rendering time) to get rid of the
> graininess and get nice, smooth colors?
I think it's quite pretty as is.
Anton Sherwood  --  br0### [at] p0b0xcom  --  http://ogre.nu/
Date: 24 Jun 2001 17:23:22
Message: <3b365a4a$1@news.povray.org>
Thanks.
Jim
"Anton Sherwood" <bro### [at] poboxcom> wrote in message
news:3B3648D1.D868817C@pobox.com...
