POV-Ray : Newsgroups : povray.binaries.images : IRTC-WIP take 7 (near final- 240 kb) Server Time
9 Jun 2026 12:26:15 EDT (-0400)
  IRTC-WIP take 7 (near final- 240 kb) (Message 6 to 15 of 15)
<<< Previous 5 Messages Goto Initial 10 Messages
Subject: Re: IRTC-WIP take 7 (near final- 240 kb)
Date: 20 Jun 2001 18:35:14
Message: <3B312565.202C2132@gmx.de>
JRG wrote:
> I shall not use radiosity: I didn't manage to solve the truble about the
> sphere_sweeps (probably a bug, but nobody answered me).
I'm quite sure if you'd post a small sample showing this behavior someone
will investigate in that.
> I'm looking for new handwrinting fonts just now, so the wrinting on the desk
> should be fine next time.
> About the ambient finish enigma: I discovered that when I added the dirt
> layer to a texture, moving the finish block (with ambient 0) to the upper
> layer, the lower layers looked like they had the default ambient 0.1 . IMHO
> it makes no sense the finish block in lower layers... Anyway, I set ambient
> 0 by default to avoid this problem.
> Comments are welcome.
It looks good with the darker desk, but don't add too many more objects,
IMO the blue screwdriver should be omitted.
Date: 21 Jun 2001 10:55:15
Message: <3b320ad3$1@news.povray.org>
Very nice.  I like getting lost in the image.
I have used a trick of creating the writing as a height field.  Simply
create the height field by making a painting via the mouse (or scanning
writing you have made) to a TGA image.  Use a difference (usually a box) to
remove the bottom flat section of the height field and you have a 3D text
object that looks as sloppy as you like.  It seems to render faster than
text does.
"JRG" <jrg### [at] hotmailcom> wrote in message
news:3b30f329@news.povray.org...
desk
IMHO
ambient
> Jonathan.
Date: 21 Jun 2001 12:42:42
Message: <3B322456.7B5130A7@inapg.inra.fr>
Patrick Dugan wrote:
> Use a difference (usually a box) to remove the bottom flat section of the
> height field
... or just give a water_level > 0
G.
http://www.oyonale.com
Graphic experiments
Pov-ray gallery
Date: 21 Jun 2001 12:53:07
Message: <3b322673@news.povray.org>
I posted the buggy radiosity image last week. Have a look to the "take 6"
thread.
Jonathan.
"Christoph Hormann" <chr### [at] gmxde> ha scritto nel messaggio
news:3B312565.202C2132@gmx.de...
desk
upper
IMHO
ambient
> Christoph
> IsoWood include, radiosity tutorial, TransSkin and other
> things on: http://www.schunter.etc.tu-bs.de/~chris/
Date: 21 Jun 2001 13:03:12
Message: <3B32292B.BDA43562@gmx.de>
> thread.
I of course meant a scene file showing the bug, as simple as possible of
course (no need to use the whole IRTC scene).
Date: 21 Jun 2001 15:03:36
Message: <3B324532.66EBB8A5@qwest.net>
better and better... I just want something in there
that really highlights and brings out the mechanixcal
spider- I mean gives the metal a chance to shine and
reflect- the shadows are too deep near it and the
contrast a little too stark (IMHO).
This one is shaping up to place at the very least.
-Peter
http://www.users.qwest.net/~dearmad
But why bother?  I'm not interesting.
Date: 21 Jun 2001 15:51:15
Message: <3B325033.5ECAB08@iki.fi>
Sad :-(.
The image and its amount of details is incredible. OTOH, with such large
number of objects, there is always some details to correct. My list of
things that could possibly be ignored comes here:
-The lamp does not like bright enough. I think the tube should be just
plain white - now it has some shadows.
-The monitor does not cast any light. I think normal CRT in dark room
illuminates quite much, altought the picture in it is quite dark.
-Papers look too much like simple crackle pattern to my pov'er eyes.
-Wood textures are continuous between boards.
          /"\                           |    iki.
          \ /     ASCII Ribbon Campaign |    fi/
           X      Against HTML Mail     |    zds
Date: 22 Jun 2001 15:51:07
Message: <3b33a1ab@news.povray.org>
You meant something like this?
#version unofficial megapov 0.7;
global_settings {
ambient_light 0
radiosity {}
ini_option "+qr"
box {-1,1
scale 12
pigment {rgb 1}}
light_source {
<0,0,0>
rgb 0.7}
#declare oggetto=0;  // 0 sphere_sweep, 1 torus
#if (!oggetto)
sphere_sweep {
catmull_rom_spline_sphere_sweep
6,
<1,0,0>,.1
<0,0,1>,.1
<-1,0,0>,.1
<0,0,-1>,.1
<1,0,0>,.1
<0,0,1>,.1
pigment {rgb x+y}
scale 2
translate -y}    //if you close the spline the effect is reduced...
#else
torus {1,0.1
pigment {rgb x+y}
scale 2
translate -y}
camera {location <0,0,-5> look_at 0}
Date: 22 Jun 2001 15:51:09
Message: <3b33a1ad$1@news.povray.org>
> Only question I have is where the scope signal is coming from -
> the spider?
> Regards,  Sander
Well, yeah, it should (through the data interface, or whatever it's called
in English...)
Cheers,
Jonathan
Date: 22 Jun 2001 16:48:02
Message: <3B33AF4E.28EE5AD5@gmx.de>
Yes, that's very good.
It indeed looks like a bug to me, there is an easy workaround, just add
another object to the scene like:
plane {y,-100 }
I'm of course in doubt if this also works in your complete scene but in
this small sample it generally seems to work.
Another method to fix it for your scene would be to use Chris Colefax's
spline include file and not the sphere_sweep.
