POV-Ray : Newsgroups : povray.binaries.images : Ocean's Edge 2 (40kbu) Server Time
9 Jun 2026 12:26:07 EDT (-0400)
  Ocean's Edge 2 (40kbu) (Message 11 to 18 of 18)
Subject: Re: Ocean's Edge 2 (40kbu)
Date: 8 Jun 2001 04:00:21
Message: <3B208651.678B7996@gmx.de>
Gail Shaw wrote:
> I've changed the ocean function, toned down the area light and added a
> couple
> of clouds. Render time ~20 hours
> I thought about adding some birds or plants, but I kinda like the desolate
> look.
> Comments? Suggestions?
The water texture looks really good now, I am just not sure about the
scale of the waves.  The clouds in front of the sun should be darker.
Date: 8 Jun 2001 08:13:24
Message: <3b20c164@news.povray.org>
Christoph Hormann <chr### [at] gmxde> wrote in message
news:3B208651.678B7996@gmx.de...
> scale of the waves.
I'm going to reduce the vertical scale and add a second smaller.
If the waves aren't so big, I should be able to get away without
having to add foam on the waves
I'm thinking about redoing the clouds completely, keeping the
idea of a few scattered near the horizon.
Gail
* gsh### [at] monotixcoza                *   Step into the abyss,           *
* http://www.rucus.ru.ac.za/~gail/   *   and let go.        Babylon 5   *
* The difficult we do immediately, the impossible takes a little longer *
Date: 8 Jun 2001 08:49:22
Message: <3b20c9d2@news.povray.org>
For the foam, how about using warps in the areas of the rocks? I've never used
warps before, so I'm not really sure if it would work.
I've got an idea on how to do the foam, here's the pseudo-code:
difference
    {waves with slightly exagerated verticle scale      // red line on pic -
foam
        pigment{foam}
    {Waves - as in the scene}                                       // black
line - water
The exagerated wave should only show over the top of the wave.
Hope this helps - if you want to do the foam.
- Nekar
Download 'Graphic1.jpg' (10 KB)
Preview of image 'Graphic1.jpg'
Date: 8 Jun 2001 09:14:53
Message: <3b20cfcd@news.povray.org>
Another approach might be to use a gradient y for two different textures -
one for the normal water, one for the foam. Give them different normals and
blend them a little bit. That does not help for your problem if you just
want to add foam around the rocks. But you could "raise" the water around
the rocks a bit (with some formulas which multiplies those areas with
something like 1.2 f.e) - it might work.
Marc-Hendrik
Date: 8 Jun 2001 13:14:16
Message: <slrn9i1ok2.ttj.steve@zero-pps.localdomain>
>couple
>look.
I don't knwo how you're doing the water but it looks like concrete
with all those hard straight edges.  Apart from that it looks great.
  3:33pm  up 126 days, 16:23,  2 users,  load average: 1.00, 1.00, 1.00
Date: 10 Jun 2001 01:08:25
Message: <3B22FF33.5F83AB9B@faricy.net>
Very nice pic.  Good lighting and composition.
Minor improvements I would suggest, maybe make the clouds more
transparent, and more color change in the sky.  How are the clouds
done?  If they're no media, try media.
Date: 11 Jun 2001 05:19:46
Message: <3b248d32@news.povray.org>
David Fontaine <dav### [at] faricynet> wrote in message
news:3B22FF33.5F83AB9B@faricy.net...
Fade to blue faster? or something else
> How are the clouds
spheres filled with scattering media.
Gail
Date: 11 Jun 2001 17:55:01
Message: <3B253C9A.A3E93419@faricy.net>
Nah, changed my mind.
> > How are the clouds
Hmm.  They don't look very 3D though.  Don't know what you should do.
