POV-Ray : Newsgroups : povray.binaries.images : IRTC-WIP3 Server Time
9 Jun 2026 14:15:35 EDT (-0400)
  IRTC-WIP3 (Message 2 to 11 of 21)
<<< Previous 1 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: IRTC-WIP3
Date: 7 Jun 2001 13:42:36
Message: <3b1fbd0c$1@news.povray.org>
yikes - this is starting to get very scary - 2 HQ images in one day.... i
think i may have to start working less and poving more...
PGP Public Key
Date: 7 Jun 2001 15:26:50
Message: <3B1FD711.3D660519@mail.com>
I have a suggestion.  Stop uploading photographs! ;)
Date: 7 Jun 2001 16:18:35
Message: <3b1fe19b@news.povray.org>
It's fabulous, but... it's as though POV's crand is seen a lot within the
trees and the mud.  On this LCD screen (a notebook) it's probably
exagerated.  Makes it look more noisy than natural, to me anyway.
Light and shadow is terrific.
Hadn't heard of XFrog before, I see it's at www.greenworks.de
Bob H.
Date: 7 Jun 2001 17:06:10
Message: <3b1fecc2$1@news.povray.org>
too much honor for me - thanks anyway
"Rick [Kitty5]" <ric### [at] kitty5com> schrieb im Newsbeitrag
news:3b1fbd0c$1@news.povray.org...
Date: 7 Jun 2001 17:10:30
Message: <3b1fedc6$1@news.povray.org>
lol !
pretty encouraging comment.
"Ben Birdsey" <cla### [at] mailcom> schrieb im Newsbeitrag
news:3B1FD711.3D660519@mail.com...
Date: 7 Jun 2001 17:40:19
Message: <3b1ff4c3@news.povray.org>
You are right, the pic looks grainy.
The main problem are the many leafes. Most of the trees have leafes with uv
mapped images as texture.
This type of leaf textures tend to look like a uniform green mass in
shadowed parts.
Therefore I reduced the ambient values and raised the normal component of
the leaf textures.
Radiosity would be a good idea in such a situation, but the render time
would increase to several months even with simple settings.
The result is the grainy look. Perhaps better antialiasing will help.
grainy look of the mud.
Norbert
"Bob H." <omn### [at] msncom> schrieb im Newsbeitrag
news:3b1fe19b@news.povray.org...
> Bob H.
Date: 8 Jun 2001 03:56:14
Message: <3B20855B.378EB8A0@gmx.de>
Norbert Kern wrote:
> hi all,
> my third version. Eight different deciduous trees substitute the pines.
> Beside that I made only some minor changes.
> Trees were mainly modeled with XFrog.
> All the 161 trees consume "only" 185 MByte. With Maketree, Tomtree or
> Splinetree, I would need two or three times as much memory.
> The whole scene needs about 519 MByte.
> I wasted a lot of time to integrate the trees in the macros. A loop with
> behavior!). So I had to create eight nearly identical macros for ech of the
> trees. Very boring, but it works now.
> Suggestions?
The foreground i definitely liked better in the last version, the shadowed
parts still look quite flat, you probably can't do much about that without
using radiosity... Maybe try a shadowless fill light on the right.
I would at least try radiosity with some low quality settings (as long as
you have enough memory of course) You probably can gain a lot of speed
with hierarchical grouping of the trees (unless you have already done this
of course)
Date: 8 Jun 2001 05:37:37
Message: <3b209ce1@news.povray.org>
"Norbert Kern" <nor### [at] t-onlinede> wrote in message
news:3b1ff4c3@news.povray.org...
> shadowed parts.
> the leaf textures.
I think if you added a slight reflection to the leaves it would help a lot.
Great stuff.
- Nekar
Date: 8 Jun 2001 07:09:49
Message: <3b20b27d$1@news.povray.org>
Christoph, what is a hierarchical grouping?
You mentioned this in your "water tunnel final" thread and I am very
interested but unsuspecting.
I tried radiosity my second version and the most simple settings. Rendering
time increased by a factor of twenty without any visible advantage.
I will try a fill light as you suggest.
> of course)
> Christoph
> IsoWood include, radiosity tutorial, TransSkin and other
> things on: http://www.schunter.etc.tu-bs.de/~chris/
Date: 8 Jun 2001 07:16:54
Message: <3b20b426@news.povray.org>
They are uv mapped from an image with alpha channel on a triangle.
If I would allow reflection, the whole triangle would reflect.
Its the same with specularity. You see the whole triangle.
The same disadvantage is true for "splinetrees".
Norbert
lot.
> Great stuff.
> - Nekar
