POV-Ray : Newsgroups : povray.binaries.images : Problem with torus Server Time
16 May 2026 12:37:32 EDT (-0400)
  Problem with torus (Message 1 to 5 of 5)
Subject: Problem with torus
Date: 2 Jun 2001 10:13:25
Message: <3b18f485@news.povray.org>
I would like to use a torus with minor radius > major radius to connect 2
cylinder  but here is the result when the minor radius > major radius.
The whole is not always visible.
Do you experimente this situation ?
Is there a way to avoid this whole ?
I post this message at ninaries images because for me it is easiest to to
explain my problem with an image
 default { texture { pigment { rgb <1,0,0> } }}
background { color <0.737255, 0.737255, 0.870588> }
camera{
  location  <4,-15,4>
  sky       <    0.00000,     0.00000,     1.00000> // Use right
handed-system
  up        <        0.0,         0.0,         1.0> // Where Z is up
  right     <    1.38192,         0.0,         0.0> // Right Vector is
adjusted to compensate for spherical (Moray) vs. planar (POV-Ray) aspect
ratio
  angle         54.40000    // Vertical      40.800
  look_at  0 }
light_source {   // Light001
  <0.0, 0.0, 0.0>
  color rgb <1.000, 1.000, 1.000>
  translate  <0,-110,-200> }
  <0.0, 0.0, 0.0>
  translate  <0,-110,200> }
plane {  y, 30
  texture { pigment { checker color red 0.5 green 0.5 blue 0.5 color red
0.847059 green 0.847059 blue 0.74902 }
        finish { ambient 1 diffuse 0 }
        scale 2 }
 hollow }
torus { 1 , 5  }
Download 'temp.jpg' (14 KB)
Preview of image 'temp.jpg'
Subject: Re: Problem with torus
Date: 2 Jun 2001 19:37:24
Message: <slrn9hiu3m.a21.steve@zero-pps.localdomain>
I don't really understand your problem here, but myabe this is the sort
of thing you're looking for, it takes a half torus and connects it to a
cylinder using two more torus sections:
union{
      difference{
                 torus{2.5, 0.2}
                 box{<3,0.5,0>, <-3,-0.5,-3>}
                } // End of Difference
      #local Dummy_Corner_Arc =
      difference{
                 torus{0.5, 0.2}
                 box{<1,0.5,0>,<-1,-0.5,-1>}
                 box{<0,0.5,1>,<1,-0.5,-1>}
                } // End of Difference.
      object{Dummy_Corner_Arc  rotate y*-90 translate x*-2}
      object{Dummy_Corner_Arc  rotate y*180 translate x*2}
      cylinder{<-2,0,-0.5>,<2,0,-0.5>,0.2 }
      texture{pigment{Dummy_Body_Colour1}
              finish{Dummy_Body_Finish}
      scale <0.5,0.75,0.65>
      rotate y*90
      translate x*1
     } // End of Union.
You'll have to change the texture to render this, hope it helps.
 10:57pm  up 120 days, 23:46,  2 users,  load average: 1.00, 1.00, 1.00
Date: 3 Jun 2001 01:28:26
Message: <3b19cafa@news.povray.org>
"m.o.p.s" <m.o.p.s.@wanadoo.fr> wrote in message
news:3b18f485@news.povray.org...
You are witnessing a bug, I believe, with the torus object in POV-Ray
version 3.1g (also MegaPOV 0.7).  What happens is that the inside/outside
becomes confused.
Bob H.
Date: 3 Jun 2001 13:46:02
Message: <3b1a77da$1@news.povray.org>
Thank you for your answer, so i have to find a way that doesn't use such a
torus.
Thank for all
Date: 3 Jun 2001 18:27:52
Message: <slrn9hlefb.1ls.ron.parker@fwi.com>
>becomes confused.
For what it's worth, this bug will be fixed in 3.5.
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbt 1}hollow interior{media{emission T}}finish{
reflection.1}}#end Z(-x-x.2y)Z(-x-x.4x)camera{location z*-10rotate x*90}
