POV-Ray : Newsgroups : povray.binaries.images : Le Divan D'Ivan (~104kau) Server Time
9 Jun 2026 13:58:27 EDT (-0400)
  Le Divan D'Ivan (~104kau) (Message 11 to 13 of 13)
Subject: Re: Le Divan D'Ivan (~104kau)
Date: 2 Jun 2001 03:09:11
Message: <0f3hht0o5epufjlnvn34nb3re9otjhuh2p@4ax.com>
On Thu, 31 May 2001 23:49:39 -0600, "Tony[B]" <ben### [at] catholicorg>
wrote:
>:( First, it was too bright, and without contrast... now it's too dark...
>you can't have both... Grrr! I'll see what I can do...
On a sunny day the irradiance of sunlit and shadowed areas can be off
by a factor of 10^5 and even more. Of course, our eyes react
non-linearly but still, trying to represent this on a screen is a
heavy task. Kari seems to know the most about this stuff, maybe if
you're a good boy... ;)
Peter Popov ICQ : 15002700
Date: 2 Jun 2001 03:09:12
Message: <0k3hhto1u902ghkoukt70ktao72ef0k50q@4ax.com>
On Fri, 1 Jun 2001 10:33:13 -0600, "Tony[B]" <ben### [at] catholicorg>
wrote:
>Yes, I did. I won't use a recursion of 2 because that ruins the radiosity
>which I use, and I'm already using a brightness >2. I've made the
>fill-lights an eensy bit brighter.
 >2?! Keep brightness low (0.75 - 1) and use a recursion of 2. Lower
diffuse and maybe increase brilliance a bit, that should give you more
contrast. Ditch the fill lights altogether except if you really need
them, but use light groups to only illuminate the parts you want.
And then show us the result :)
Date: 4 Jun 2001 03:04:32
Message: <3b1b3300@news.povray.org>
Tony[B] <ben### [at] catholicorg> wrote in message
news:3b17b622@news.povray.org...
> Well, I'm glad someone likes the lighting... :) And, yes, you're right...
> what do you suggest I add outside? I was thinking maybe some grass or
> something.
Top of a tree, distant hills.
Gail
* gsh### [at] monotixcoza                *   Step into the abyss,           *
* http://www.rucus.ru.ac.za/~gail/   *   and let go.        Babylon 5   *
* The difficult we do immediately, the impossible takes a little longer *
