POV-Ray : Newsgroups : povray.binaries.images : My chess set Server Time
9 Jun 2026 17:27:50 EDT (-0400)
  My chess set (Message 12 to 21 of 21)
Subject: Re: My chess set
Date: 7 May 2001 19:20:38
Message: <3AF72E9A.2209030E@yahoo.com>
to give your game the human touch, randomly position each piece within
its square and give it a random twist on its vertical axis.  in other
words, no human could place all of the pieces in the exact center of
each square and facing exactly forward.  nice job btw. :)
Warp wrote:
>   A chess set is not as classic as the reflective sphere on a checkered
> plane, but it comes close. Thus I decided to make one myself.
>   I made it completely from the scratch, all by hand and pure CSG (I have
> played chess quite a lot and I know what the pieces look like, approximately
> at least).
>   Making a chess set is actually quite fun. I recommend it to everyone
> who hasn't done one yet.
>   It's not too difficult (the horse is the piece that requires most work,
> as can see in my image as well).
>   The set forms a very nice hierarcy of objects. In my set the base of each
> piece is the same object; then I made colorless versions of each piece on
> the base object, and then white and black versions of each piece. Then I
> just copied the right number of pieces to the board.
>   It's also easy to make a little macro that positions a piece on the board
> given its coordinates. This way it's easy to actually "move" the pieces
> on the board, as in actual playing.
>    chess.jpg    Type: Postscript Document (application/postscript)
>             Encoding: x-uuencode
> #macro N(D,I)#if(I<6)cylinder{M()#local D[I]=div(D[I],104);M().5,2pigment{
> rgb M()}}N(D,(D[I]>99?I:I+1))#end#end#macro M()<mod(D[I],13)-6,mod(div(D[I
> ],13),8)-3,10>#end blob{N(array[6]{11117333955,
> 7382340,3358,3900569407,970,4254934330},0)}//                     - Warp -
Date: 7 May 2001 19:41:28
Message: <3af732a8@news.povray.org>
I guess you don't play chess with obsessive compulsives very often ;-)
Harolddd
"Ryan Constantine" <rco### [at] yahoocom> wrote in message
news:3AF72E9A.2209030E@yahoo.com...
Date: 8 May 2001 03:30:01
Message: <3af7a079@news.povray.org>
"Harold Baize" <bai### [at] itsaucsfedu> wrote in message
news:3af732a8@news.povray.org...
Ha! I wish I had said that.
I'm just such a person sometimes.  A chess set in particular must be exactly
aligned at the start.  I can lose to a 10 year old so unfortunately that
doesn't mean I can play well.
I like both kinds of setup; erratic or immaculate, either way.  Yet another
reason to do 3D rendering.
About the focal blurring maybe being overdone, I think of that in the same
way.  Or it has something to do with my eyesight and not always wearing my
glasses.
Bob H.
Date: 8 May 2001 06:10:18
Message: <3af7c60a@news.povray.org>
Harold Baize <bai### [at] itsaucsfedu> wrote:
: I agree that animations take up large amounts of hard disk, but the limiting
: factor is the number of frames you generate, not the camera movement.
: Right?
  Wrong. Most compressing animation formats take advantage of previous
(and sometimes next) frames in order to compress the current frame.
  This means that the less things change from frame to frame, the more
compression can be achieved.
  If you move the camera, virtually everything in the image changes, thus
resulting in less compression.
Date: 8 May 2001 14:24:07
Message: <3af839c7$1@news.povray.org>
Well wrong is some respects, but not as most people who animate with
POV-Ray are concerned. I think most of us render all the frames before
compression, and that is what eats up disk space, not the final animation
file. I know how video compression works. I recently animated (with POV)
a rotating factor structure from a factor analysis of a children's mental
health outcomes measure. I made 360 640x480 frames, so it was about
to 330MB before making an AVI file. Some programs, like Hash
Animation:Master will render directly to an animation so you don't chew
up so much disk space in the process. It is the pre-compression phase that
makes disk space a limiting factor, not the relatively small difference in
final
file size that camera movement contributes, even if it increases the final
animation file by a factor of four.
Harold
Date: 9 May 2001 12:00:31
Message: <3AF9699E.FCDBEA61@ucdavis.edu>
'perfectly aligned' by a human still isn't perfect.  iirc, we can see
down to about 4/1000 of an inch which is pretty small, but that doesn't
mean we can make our hands move things by such slight amounts.  you
would still need a robot to position the pieces 'exactly'.  so even the
obsessive compulsive couldn't position them exactly.  there would simply
be less jitter, in which case a positioning macro could have several
jitter settings: near perfect, regular, or sloppy.
> glasses.
> Bob H.
Date: 9 May 2001 12:31:08
Message: <3af970cc$1@news.povray.org>
"Ryan Constantine" <rcc### [at] ucdavisedu> wrote in message
news:3AF9699E.FCDBEA61@ucdavis.edu...
Okay, but for 3D modelling I'd be willing to bet the typical render
resolution disallows that accuracy with which you say a human can manage.
Or would I lose that bet?  Hmmm.  1/250 of an inch on a 19" screen at
1024x768 for example?  I think that's about 70 pixels per inch... maybe, or
something like 1/70 an inch of accuracy possible.
Bob H.
Date: 9 May 2001 21:58:00
Message: <3AF9F685.DA071D8B@yahoo.com>
unless you render higher than your screen resolution for print
purposes.  but, you did say 'typical' render resolutions.  my typical
final resolution is always print quality however.
> Bob H.
Date: 10 May 2001 06:20:53
Message: <3afa6b84@news.povray.org>
Bob H. <omn### [at] msncom> wrote:
: Okay, but for 3D modelling I'd be willing to bet the typical render
: resolution disallows that accuracy with which you say a human can manage.
  That's what antialiasing is for. It calculates sub-pixel information.
Date: 10 May 2001 12:13:46
Message: <3afabe3a$1@news.povray.org>
I must agree with Bob here. A human could position the pieces precisely
enough to be indistinguishable from computer alignment as viewed by
another human. Even without taking rendering or screen resolution into
account.
I also like Ryan's idea of programing the POV animation to vary the
precision of piece placement. It could reflect the personality of the
virtual chess player ;-)
Harold
"Bob H." <omn### [at] msncom> wrote in message
news:3af970cc$1@news.povray.org...
or
> Bob H.
