POV-Ray : Newsgroups : povray.binaries.images : Lightning and Radiosity Server Time
25 Apr 2026 23:37:47 EDT (-0400)
  Lightning and Radiosity (Message 1 to 7 of 7)
Subject: Lightning and Radiosity
Date: 3 May 2001 12:17:51
Message: <3af184af@news.povray.org>
from posts in text.scene-files - no lights in scene, just radiosity and
emitting media in the bolt.
"To stop children being afraid of the dark, try to fill their daylight hours
with as much terror as possible"
www.tomandlu.co.uk
Download 'newboltcode2.jpg' (6 KB)
Preview of image 'newboltcode2.jpg'
Subject: Re: Lightning and Radiosity
Date: 3 May 2001 12:44:24
Message: <3af18ae8@news.povray.org>
Wow, couldn't you compress it a little bit more than this?
Nice image, btw :)
cu!
Date: 3 May 2001 12:48:21
Message: <3af18bd5$1@news.povray.org>
    I agree, 8 kb is a bit much for a binary group. It took almost
0.00000238 hours to download.
Date: 3 May 2001 18:30:04
Message: <3af1dbec@news.povray.org>
Bill DeWitt wrote in message <3af18bd5$1@news.povray.org>...
enough already with the size of my uploads jokes...
Date: 4 May 2001 02:10:46
Message: <3af247e6@news.povray.org>
Very nice. Will you post the radiosity code as well. I don't know how to use
radiosity so this would be a help.
Nekar
#version unofficial MegaPov 0.7;#local Q=seed(7);#local S=<-2,2,5>;#local
E=<2
,-2,5>;#local B=S;#while(vlength(B-E)>.1)#local
B=(B+(<rand(Q),rand(Q),rand(Q)
>/20));#local B=B-(2*(B-S))*((vlength(B-E)>vlength(S-E)));#local
S=B;glow{//NX
location S size.1 radius.07}glow{location S size.1 radius.07 rotate
z*90}#end
Date: 4 May 2001 05:23:29
Message: <3af27511$1@news.povray.org>
"Nekar Xenos" <j-p### [at] citywalkcoza> wrote in message
news:<3af247e6@news.povray.org>...
use
Well, here the scene - I'm not sure if my radiosity settings are "correct" -
the brightness setting seems anti-intuitive. (and don't forget to render
with +qr)
#version unofficial MegaPov 0.6;
#declare doRad = true;
#if(doRad)
global_settings
  assumed_gamma 1.0
  ambient_light 0
  radiosity{
    pretrace_start 0.08
    pretrace_end 0.02
    count 150
    nearest_count 5
    recursion_limit 4
    error_bound 1
    low_error_factor .5
    gray_threshold 0.0
    minimum_reuse 0.015
    brightness 50
    media on
camera{location  <0, 0.5, -10.0> look_at   <2, 1.2,  0.0>}
sphere{0, 4.75 pigment{bozo scale 0.1 color_map {[0.0 color rgb <0.1, 0.2,
0.3>*.25] [1.0 color rgb <0.11, 0.3,0.4>*.25]}} scale<100,1,100> inverse
finish{ambient 1}}
plane { y, -1 pigment{ color rgb <0.7, 0.5, 0.3> }normal{bumps scale 3 }}
plane { y, 0 pigment{bozo color_map{[0.0 color rgbt <0,0,0,1>][1.0 color
rgbt <0.11, 0.3, 0.4,0>]} scale 0.1}normal{bumps scale<1,1,10>} rotate x*180
translate y*10}
fog{distance 50 color rgb 0}
#macro Make_Bolt(LArraySize, LSeed, LWidth, LHeight, LSpread, LBranch,
LCutoff, LSpike)
  #declare myArray = array[LArraySize]
  #declare checkCount = -1;
  #declare highCount = 0;
  #declare arrayCount = 0;
  #declare myArray[arrayCount] = <0,0,0>;
  #declare myRand = seed(LSeed);
  #declare Lightning_Bolt =
    merge{
    #while (checkCount < highCount)
      #declare checkCount = checkCount + 1;
      #declare segPosA = myArray[arrayCount];
      #declare arrayCount = arrayCount + 1;
      #declare xPlus = (rand(myRand)-0.5)*LSpread;
      #declare zPlus = (rand(myRand)-0.5)*LSpread;
      #while(segPosA.y < LHeight)
        #declare xShift = segPosA.x + ((rand(myRand)-0.5)*LSpike) + xPlus;
        #declare yShift = segPosA.y + (rand(myRand)/5);
        #declare zShift = segPosA.z + ((rand(myRand)-0.5)*LSpike) + zPlus;
        #if (yShift > LHeight)
          #declare yShift = LHeight;
        #declare segPosB = <xShift, yShift, zShift>;
        cylinder{segPosA, segPosB, LWidth}
        #declare segPosA = segPosB;
        #declare randNum = rand(myRand);
        #if (randNum < LBranch & segPosA.y > LCutoff)
          #declare highCount = highCount + 1;
          #declare myArray[highCount] = segPosA;
        #declare LWidth = (LWidth*0.995)   ;
      #declare LWidth = (LWidth*0.9)   ;
Make_Bolt(500, 11211, 0.03, 6, 0.003, 0.05, 0.5, 0.2)
object{
  Lightning_Bolt
  pigment{rgbt 1}
  interior{media{emission<3,3,5>*5}}
  hollow
  rotate x*180
  no_shadow
  translate y*5
Date: 6 May 2001 01:17:43
Message: <3af4de77$1@news.povray.org>
Zeger Knaepen wrote in message <3af18ae8@news.povray.org>...
I managed to get it down to 10KB with no significant loss of quality ;-)
Mark
