POV-Ray : Newsgroups : povray.binaries.images : sprout box Server Time
24 Jul 2026 04:56:38 EDT (-0400)
  sprout box (Message 1 to 10 of 14)
Subject: sprout box
Date: 26 Apr 2001 03:53:00
Message: <3ae7d3dc@news.povray.org>
here is much better version of my sprout box
I still looking fot "faster" settings
this was rendered over 40 hours :-(
current settings are :
global_settings{
  assumed_gamma 1
  ini_option "Quality=11"
  ini_option "Radiosity=yes"
  ini_option "Antialias=yes"
  ini_option "Sampling_Method=2"
  ini_option "Antialias_Threshold=0.1"
  ini_option "Jitter=no"
  ini_option "Antialias_Depth=3"
  radiosity{recursion_limit 3 brightness 1.2 normal on}
  max_intersections 255
  max_trace_level 255
  photons{count 20000 gather 20,100 autostop 0}
sky_sphere{pigment{gradient y color_map{[0 color blue .6][1 color rgb 1]}}}
light_source{<-30,30,-30>color rgb 1 photons { reflection on refraction on }}
object{
  Platform()
  texture{
    pigment{color rgb 1 transmit .95 }
    finish{
      ambient -0.3
      diffuse 0.8
      specular 0.1
      roughness 0.1
      metallic
      brilliance 1
      reflection_type 1
      reflection_min 0.0
      reflection_max 1.0
      conserve_energy
  interior{ior 1.5}
  photons {target 1.0 reflection on refraction on }
and some parts of output attached
any ideas what could it speed up without loosing quality ?
ABX
#local A="000114120001121034130151142153134064180060195"#local B=0;#macro G()
#declare B=B+1;val(substr(A,B,1))#end#local S=seed(1);light_source{10,1}blob{
threshold.6#local U=z;#local Y=0;#while(Y<15)#local E=G()*.7+.1e-3;#local V=<
3.5-G(),G()-2.5,-1>;#local X=0;#while(X<1)sphere{<12*X+rand(S)-6,Y+rand(S)-5,
-1>1,1}sphere{U+X*(V-U)+rand(S)E,.3}#local X=X+.01;#end#local U=V;#local Y=Y+
1;#end texture{pigment{rgb 1}normal{agate}}}camera{location z*8look_at 0}
Download 'platform.jpg' (52 KB) Download 'OUT.TXT' (4 KB)
Preview of image 'platform.jpg'
Subject: Re: sprout box
Date: 26 Apr 2001 04:45:31
Message: <3AE7E048.B6139A58@gmx.de>
Hmmm...
I would suggest trying 'recursion_limit 1' for radiosity or even totally
omitting it, of course that would require reworking the lighting and
finishes.
The photons are not at all visible to me, you probably need much more.
Date: 26 Apr 2001 09:44:18
Message: <3ae82632$1@news.povray.org>
No tips for speeding it up, but the plastic looks perfect. I'm saving that
finish into a file somewhere.
 Shay
Wlodzimierz ABX Skiba <abx### [at] abxartpl> wrote in message
news:3ae7d3dc@news.povray.org...
> global_settings{
>   assumed_gamma 1
>   max_trace_level 255
1]}}}
on }}
> object{
>   Platform()
>   texture{
>     finish{
>       ambient -0.3
>       diffuse 0.8
>       specular 0.1
>       roughness 0.1
>       metallic
>       brilliance 1
>       reflection_type 1
>       reflection_min 0.0
>       reflection_max 1.0
>       conserve_energy
>   interior{ior 1.5}
> ABX
G()
V=<
Y=Y+
Date: 26 Apr 2001 11:03:35
Message: <3ae838c7$1@news.povray.org>
Given the photons don't seem to be doing anything, you could try leaving
them out...
Date: 26 Apr 2001 12:30:24
Message: <3ae84d20@news.povray.org>
Tom Melly wrote in message <3ae838c7$1@news.povray.org>...
> them out...
I would do it but .... my real box produces such effect very clearly. It should
be visible on the border of shadow of corner of walls and base. Of course I'll
check version without photons.
ABX
Date: 26 Apr 2001 15:19:19
Message: <3ae874b7@news.povray.org>
Thats looking much better
PGP Public Key
Date: 26 Apr 2001 18:42:02
Message: <3AE8A32B.66FDC049@yahoo.com.au>
Try ignore_photons, it can make a big differnce. I don't know if this will help
you, but below is a texture for glass that gives me good results with radiosity.
Perhaps you could modify it for the plastic you want. Use global_settings {
ambient_light 0 } with it though.
        hollow on
        texture
                pigment
                        colour rgbf <1,1,1,1>
                finish
                        diffuse 0.001
                        specular 1
                        roughness 0.001
                        reflection_type 1
                        conserve_energy
        interior
                ior 1.5
                media
                        intervals 1
                        samples 5,5
                        confidence 0.999
                        variance 0.001
                        method 3
                        absorption (1-(<0.95,0.96,0.95>*(1/0.96)*0.98))
        photons
                target
                reflection on
                refraction on
                ignore_photons
Date: 30 Apr 2001 03:37:05
Message: <3aed1621@news.povray.org>
Christoph Hormann wrote in message <3AE7E048.B6139A58@gmx.de>...
> finishes.
You are wrong :-(
I've removed recursion_limit and rendered it during weekend. With removed
recursion_limit it was even 9 hour longer and result _IS_ the same even without
working with lighting and finishes.
ABX
Date: 30 Apr 2001 03:38:37
Message: <3aed167d$1@news.povray.org>
Wlodzimierz ABX Skiba wrote in message <3ae84d20@news.povray.org>...
>> them out...
should
Well.. I've checked this without photons, but ... only shadow on the desk
disapeared and render took 44 hour.
ABX
Date: 30 Apr 2001 03:40:17
Message: <3aed16e1@news.povray.org>
Mark James Lewin wrote in message <3AE8A32B.66FDC049@yahoo.com.au>...
help
radiosity.
I have checked your settings. They decreased render time to 18 hour. Still to
long for animation :-( but nearly the same. Thanks.
ABX
Download 'platform.jpg' (54 KB)
