POV-Ray : Newsgroups : povray.binaries.images : Lake View, or: wow reflection blur + iso can be slow [~50K Jpg] Server Time
9 Jun 2026 21:24:45 EDT (-0400)
  Lake View, or: wow reflection blur + iso can be slow [~50K Jpg] (Message 5 to 14 of 14)
<<< Previous 4 Messages Goto Initial 10 Messages
Subject: Re: Lake View, or: wow reflection blur + iso can be slow [~50K Jpg]
Date: 5 Apr 2001 11:19:41
Message: <3acc8d0d@news.povray.org>
"Bob H." <omn### [at] msncom> wrote in message
news:3acc6583$1@news.povray.org...
Which is the iso - the water, the landscape, or both (I'm assuming the
water)?
Date: 5 Apr 2001 12:58:51
Message: <3acca44b@news.povray.org>
"Geoff Wedig" <wed### [at] darwinepbicwruedu> wrote in message
news:3acc871f@news.povray.org...
> Hmm, not certain why you're even bothering with an iso.  The distance and
> wave size mean that a surface normal would probably be more than
sufficient
> for this image, even if blown up to a very large size.
Huh?  :-)  Oh!  You think the water is an isosurface!  Ha ha.  Well no, it
is not.
> Also, I wonder why you are using blurred reflection, since reflections on
> water are pretty sharp.  If you want the blurring, then I'd think you'd
want
> rougher water, not blurred reflec.  So I guess I wonder why you're using
> these features in this instance.
The blurring is taking place of mere normals or displacement (isosurface?).
Figured I'd give it a try for effect.  I have to change the amounts the
three water textures have I can tell because it doesn't have smooth and
rough areas like it had before.
Thanks, glad you liked it anyway.
Bob H.
Date: 5 Apr 2001 12:59:41
Message: <3acca47d@news.povray.org>
I knew I should have said the water is only a textured plane.
Bob H.
"Tom Melly" <tom### [at] tomandlucouk> wrote in message
news:3acc8d0d@news.povray.org...
> water)?
Date: 5 Apr 2001 13:05:44
Message: <3acca5e8$1@news.povray.org>
news:3ACC6DB6.AA3DA529@gmx.de...
> That's fairly normal for isosurface & reflection, reflection blur even
> more.  Usually in such a scene i would expect the horizon part to be quite
> slow too.
Indeed it was.  Only the sky and midway down the lake was it what I'd call
"fast".
> Before the last 20 lines there is not much of the isosurface to be
> reflected so things are probably quite fast.  I would estimate that the
> mountain reflections in the lake are the part which is slowest.
Correct.
> Just add some radiosity and you will find everything before extremely fast
> Nice scene BTW, the clouds look quite good, just the rim of the lake seems
> a bit steep.
Believe me, I thought about using radiosity before I realized how slow it
gets at the last lines.
And thanks, making a shoreline is one of the intended additions, if I can
get it right.  I think it hasn't any scale much until I do.
Bob H.
Date: 5 Apr 2001 13:41:07
Message: <3accae33@news.povray.org>
> sufficient
> is not.
Ah!  I assumed that they were on the same object.  Oops.
> want
Ah, ok, experimenting.  Hmm.  Not sure what to suggest.
Geoff
Subject: Re: Lake View, guess you'd like a look... [~34K Jpg]
Date: 5 Apr 2001 15:22:45
Message: <MPG.1536e46e9b21cd6c989730@NEWS.POVRAY.ORG>
In article <3acc6661@news.povray.org>, Bob H. says...
> ... so here it is this time, for what it's worth.
This is tantalizingly small, but I understand that you would be in
trouble if you rendered a larger one :)
Regards,  Sander
Date: 6 Apr 2001 04:12:39
Message: <3acd7a77$1@news.povray.org>
Hmm, seems counter-intuitive to me that a reflection of an iso should take
any longer to render than the iso itself. Anyone got an explanation?
news:3acca47d@news.povray.org...
> Bob H.
Date: 6 Apr 2001 07:39:00
Message: <3acdaad4@news.povray.org>
The reflection is blurred.  Blurred reflections of anything take longer than
rendering the object itself.
Geoff
Date: 6 Apr 2001 09:38:19
Message: <3ACDC7EE.473B029E@mail.com>
If reflection blur is causing the trouble, you may be able to get away
with something different.  If the bump_map on the water has features
that are smaller than one pixel, anti-aliasing would do much the same
thing as the blurred reflections.
Both methods would average over a variety of "stochastically sampled"
reflected rays, but the "anti-aliasing method" would only be turned on
when it made a difference in the final image.  Hopefully, this would
really improve the render time.
-Ben
Date: 6 Apr 2001 16:04:49
Message: <3ace2161@news.povray.org>
"Ben Birdsey" <cla### [at] mailcom> wrote in message
news:3ACDC7EE.473B029E@mail.com...
Hmmm, yeah, think I'll try changing the scaling of the normals anyway and
see if that improves things first before I give up on the reflection_blur
altogether.  It occurs to me that what the blurring does is actually reverse
of what it would be IRL I believe.  Distant horizon reflections should be
blurred more than those nearer below the camera due to the waves seen closer
together at an oblique angle far away.
Reflection blurring blends out the reflected objects the farther they get
into the reflecting surface.
That sound right anyone?
Bob H.
