POV-Ray : Newsgroups : povray.binaries.images : Oilve Oil Bottle - Photons - (and oil) Server Time
9 Jun 2026 22:47:59 EDT (-0400)
  Oilve Oil Bottle - Photons - (and oil) (Message 21 to 26 of 26)
Subject: Re: Oilve Oil Bottle - Photons - (and oil)
Date: 3 Apr 2001 21:08:35
Message: <3aca7413@news.povray.org>
> Yet you can use -z*27.0 fine (yes, with #version megapov) - I know, it's
> what I use
i know i can, however its what is outputted by moray that i am working with,
and works perfectly till i add the version info, then it all falls down, i
dont want to have to start manually editing my scenes, especially as some
can get extremly complex with many layers of csg involving hundreds of
objects! (which is the reason i use a modeller!)
Hi-Impact web site design & database driven e-commerce
PGP Public Key
Date: 3 Apr 2001 22:05:20
Message: <3aca8160@news.povray.org>
> > what I use
with,
Search & replace? changing the -27.0*z to -z*27.0
Then again, time consuming
Date: 3 Apr 2001 22:33:23
Message: <3aca87f3@news.povray.org>
would have to search and replace every value one by one, would be simpler to
edit the code line by line by line.
PGP Public Key
Date: 4 Apr 2001 07:24:07
Message: <3acb0457@news.povray.org>
>> what I use
There really is something weird with your installation, since I do this kind
of thing all the time, and have never had a problem.  Perhaps something else
weird in your code, that just causes the break there?
Geoff
Date: 5 Apr 2001 04:56:44
Message: <3ACC33DA.DCB3AAB5@reading.ac.uk>
_Exactly_ what version info do you put in, and where do you put it? I
use the shorthand rotates/translates using (float)*(axis) all the time
in Win versions of MegaPov, PoVMan etc. I've never used Moray, but I
can't see this particular shorthand causing a problem with any
unofficial version.
Bye for now,
	Mike Andrews.
Date: 5 Apr 2001 12:37:58
Message: <3acc9f66@news.povray.org>
to
Realised that after :(
