POV-Ray : Newsgroups : povray.binaries.images : Rusty metal textures Server Time
30 Jun 2026 04:34:05 EDT (-0400)
  Rusty metal textures (Message 3 to 12 of 12)
<<< Previous 2 Messages Goto Initial 10 Messages
Subject: Re: Rusty metal textures
Date: 24 Mar 2001 00:45:01
Message: <3abc345d$1@news.povray.org>
Uh oh... Now I feel bad.  I think I was misleading.  In the effort to make
my web site look as nice as possible I (*gasp*) used an image map.  I did
make the textures myself however.  The stairstep effect that you liked so
much is the result of converting the texture to grayscale and running a
median filter (Irfanview) on it several times.  I could send you the TGA's
if you would still like to see them, but I don't think it would have the
same effect.  Sorry.
"Dave Blandston" <gra### [at] earthlinknet> wrote in message
news:3abc31e4@news.povray.org...
> Oh boy! I love rusty metal textures! The texture of the gear is really
good.
> My one small suggestion would be to give the lighter brown areas a little
> bit of granite normal. Rust probably wouldn't be that smooth and shiny.
What
> I think I like best about that texture is the stairstep effect. It's very
> realistic. Are you planning to post the source for that texture (I
hope)???
> Regards,
> Dave
> "Stephen Bell" <ste### [at] yahoocom> wrote in message
> news:3abc2620@news.povray.org...
> > Hi everybody.  I tried to send this earlier, but I don't think it went
> > through, so my humblest apologies if I posted this twice.  I trying to
> > revamp my web site right now with some POV-Ray graphics that would make
> the
> > menus look like rusted metal.  I want some feedback on my textures.
> Thanks
> > Stephen Bell
> > http://students.oc.edu/stephen.bell
Date: 24 Mar 2001 00:58:40
Message: <3abc3790@news.povray.org>
Hey, don't feel bad! - Whatever technique you use to achieve your desired
result is as good as any other if it works! You've inspired me to see if I
can duplicate that stairstep effect procedurally, though. I've never tried
any normal commands other than the basics, so maybe I'll learn something
new.
Dave
news:3abc345d$1@news.povray.org...
> same effect.  Sorry.
Date: 24 Mar 2001 03:16:37
Message: <3ABC57E5.DAE9D036@gmx.de>
> revamp my web site right now with some POV-Ray graphics that would make the
> menus look like rusted metal.  I want some feedback on my textures.  Thanks
The gear looks quite good, just the finish is quite too shiny.  You
probably know that the shape of it's teeth is quite wrong :-)
The text stuff looks good too, but the letters are too black so their 3d
shape is not very visible.  Maybe add some reflection and a background
behind the camera.
Date: 24 Mar 2001 04:02:44
Message: <3ABC6390.D4D26D6A@unforgettable.com>
The stair-step look on the gear is neat, suggests some kind of corrosion
process. But I'd say that your rust is too smooth and shiny looking, and
I can't help but wonder what this yellowish metal is supposed to be.
I've never seen rust on gold... ^_-
-Xplo
Date: 24 Mar 2001 09:45:13
Message: <chrishuff-85B40A.09385124032001@news.povray.org>
In article <3abc2620@news.povray.org>, "Stephen Bell"
> went through, so my humblest apologies if I posted this twice.  I
> trying to revamp my web site right now with some POV-Ray graphics
> that would make the menus look like rusted metal.  I want some
The screw heads are much too shiny, they should be dull and rough
looking. Right now they look like some kind of polished rock...simply
removing the highlights will help a lot. Also, they seem to be
glowing...try lowering the ambient value.
The background makes me think of sandstone more than anything else...put
some non-corroded metal in there, instead of the yellow stuff. A dull
blueish-gray, like iron or steel.
I was only able to view nameplate.jpg, gear.jpg resisted all my efforts
to decode it.
Christopher James Huff
Date: 24 Mar 2001 17:56:11
Message: <3abd260b$1@news.povray.org>
Okay, as for the shape of the gear, I was trying to copy a picture I found
on Corbis. The picture that I used to make the texture for the nameplate
also came from Corbis.  I've posted my "inspiration pictures" for these at
http://students.oc.edu/stephen.bell/gear.jpg and
http://students.oc.edu/stephen.bell/rustedpaint.jpg  That should help you
see where I'm coming from.  I will try to make the sunken in parts of the
gear more rough (material map?  I'll have to figure it out).  Thanks for
your help.
the
Thanks
> Stephen Bell
Subject: Re: Rusty metal textures (292k)
Date: 27 Mar 2001 07:52:46
Message: <3AC08C52.423D409@videotron.ca>
Jari Juslin wrote:
> Jari Juslin wrote:
> > Attached is two images showing what I managed to do. The first one
> > (rust0.png)
> And of course I posted the wrong one for rust0. Attached is newer
> version.
> Jari Juslin
Great work, but I think it is too shiny and the bumps are too smooth.
Rust should be extremely intricate, even flaky.
Francois Labreque | The surest sign of the existence of extra-
    flabreque     | terrestrial intelligence is that they never
        @         | bothered to come down here and visit us!
  videotron.ca    |                             - Calvin
Subject: Re: Rusty metal textures (292k + 336k)
Date: 27 Mar 2001 17:41:39
Message: <slrn9c24gt.bd9.steve@zero-pps.localdomain>
At the risk of deeply offending someone: --
That was over 1 Meg worth of rust examples there thank you.
I saved the largest of the files you posted as a jpg and got
it down to 24K with no noticeable difference, the original
was 336K.
Some of us don't read on line because we have to pay by the
minute, and don't get a chance to say weather or not we want
to receive a particular post (because that would just take
extra minutes).
I'm sure some people who havn't retrieved their news today would
be helped if you could cancel your original two posts that contained
the large files and replace those posts with new ones using smaller
jpeg files rhather than png.  It's not the image format that I object
to, it's the file size.
 10:45pm  up 53 days, 23:28,  2 users,  load average: 1.12, 1.18, 1.09
Subject: Re: Rusty metal textures (47k + 44k)
Date: 27 Mar 2001 23:20:30
Message: <3AC1668B.90DEC355@iki.fi>
Stephen Bell wrote:
> I will try to make the sunken in parts of the gear more rough
This tempted me, so I made few quick trials on rust textures.
(rust0.png) is done completely with textures. It has two layers, the
bottom one makes the larger-scale pattern and level with bozo and
slope_map. The top one uses granite to give the rough small-scale
pattern. I had to make it with partly transparent layers, because I'm
not aware of any non-iso way to combine conventional textures. I think
it would have looked better if they were truely combined.
The second one (rust1.png) is done with iso surfaces, and it definitely
needs some more work. It uses just plain 3D noise to give some roughness
and bozo with slope_map for the levels - but, as levels are "imaginary"
and noise is "real", it seems that the levels disappear. Also, the noise
is too soft-looking for this. I tried with other iso surfaces, too, but
couldn't add results here, because the sample picture takes hours to
render.
I also used some phong and a bit specular high-lighting, because it
seemed to make the tests look more like the photo.
These ones are more the type of rust that was in the gear photo, that
the type that appeared in your render, because I needed the photo to
compare results with. But, I believe there is some type of rust existing
in reality, that looks more levelled, like the type you rendered. If I
have time sometimes, I try to find such photo and try to render such. In
such case some material_map could be ideal solution.
For these ones, rust0 rendered in 3 minutes, 45 seconds on Celeron 500,
with AA0.3 and radiosity. The second one took some 2-3 times longer.
          /"\                           |    iki.
          \ /     ASCII Ribbon Campaign |    fi/
           X      Against HTML Mail     |    zds
Download 'rust1.jpg' (44 KB) Download 'rust0.jpg' (47 KB)
Preview of image 'rust1.jpg'
Preview of image 'rust0.jpg'
Date: 30 Mar 2001 07:38:34
Message: <3ac47e4a@news.povray.org>
very nice ... an example of some code so we beginners can play ????
tanks
Y
