POV-Ray : Newsgroups : povray.binaries.images : Radiosity: Algorithm vs. Reality Server Time
10 Jun 2026 01:07:46 EDT (-0400)
  Radiosity: Algorithm vs. Reality (Message 4 to 13 of 13)
<<< Previous 3 Messages Goto Initial 10 Messages
Subject: Re: Radiosity: Algorithm vs. Reality
Date: 20 Mar 2001 10:21:52
Message: <3ab77590@news.povray.org>
Christoph Hormann <chr### [at] gmxde> wrote:
> "news.povray.org" wrote:
>> the obvious thing is that the crackles aren't lit by the environment
>> by radiosity, but only by the sunlight ...
> - use 'normal on' in the radiosity block.
I can't find information on this in the POV manual or the MegaPOV manual
(07)  When was this feature added?
On the other hand, it did help me find the "media on" feature, which might
help in my curren WIP scene (although probably will slow it down immensely)
Geoff
Date: 20 Mar 2001 10:32:38
Message: <3AB77816.D28D733F@gmx.de>
it's mentioned in:
10.2.7. Miscellaneous changes & bug fixes
Never have seen a good example for 'media on' though.
Date: 20 Mar 2001 10:45:20
Message: <3ab77b10@news.povray.org>
environment
Where is this described ?? I've never read this ...
> - it's always better to use real surface distortion (isosurface)
instead
> of normal.  Of course it's much slower.
It's obvios that this will work, but not necessary to give the thing a
little structure ...
> > the second thing, (I'm not sure about this) is that there is this
edge
> > on the sphere, that makes it seem, to be a mirror...
> > In the lower half the sphere is brighter, than the upper half.
It's
> > from the radiosity, reflecting the groundfog-brightness ...
> > But I didn't expect such a sharp edge ... Maybe I'm wrong ...
> > except these things it looks quite beautiful .. (I'think)
> > Because it's short, I've attached the source here ...
> Some things that should be changed:
> - use finish { ambient 0 } for the sphere
It already has this from GroundTex ...
That's what I learned first: In Radiosity pics objects don't need
Ambient, or they will glow...
> - recursion_limit 3 is really unnecessary for such a simple scene.
1 or
> maybe 2 is perfectly sufficient.  This also avoids the sharp
blue/white
> boundary.
I'd preferred to go even deeper ...
background{rgb 1}camera{location<1,5,-2>look_at 0}#macro
m(a,b,i)#local d=(b-a)
/8;#local
e=vcross(d,y);#if(i)m(a-e,a+e+2*d,i-1)m(a+e,a+2*d-e,i-1)m(a+3*d-e,a+e
+3*d,i-1)m(a+3*d-e,a+5*d-e,i-1)m(a+6*d-e,a+e+6*d,i-1)m(a+8*d-e,a+e+8*d
,i-1)#else
cylinder{a,b,vlength(d)/3 pigment{rgb 0}}#end#end m(-4*x,2*x,4) // Jan
Walzer
Date: 20 Mar 2001 10:45:21
Message: <3ab77b11$1@news.povray.org>
"Tony[B]" <ben### [at] catholicorg>
> > First: I've not that much experience
> > with radiosity; maybe I'm just
> > using the wrong parameters...
> You're not using the ones I use, at least. No one is quite sure
which ones
> are the "right" ones. It's mostly a guessing game. I've been using
mine
> quite happily for some time now. They were developed in conjunction
with
> Gilles and Xplo et al. Even then they need to be adjusted a bit on a
> per-scene basis.
I used the guide in the radiosity chapter of the old docs ...
Of course, I know, Nathan has changed(rewritten?) the radiosity part,
but I hoped, the params still have the same function...
> > I wanted to try something simple, when
> > I saw the radiosity pic of Tony[B]...
> I inspired someone... <rapture> :)
No ... not inspired ;)...
I just felt I also need some testing in Radiosity, cause everyone else
is doing this ...
> One thing I wish could be added.
Christoph told me something about the "normal on" parameter in the
radio-statement...
I'm rendering now ...
> > is that there is this edge on the sphere,
> I noticed this when I used count 1 or 2. I don't see why you're
getting it
> here.
It's
> In this unrealistic situation, I think it's correct.
> Do radiosity ever look otherwise? :) I'll try your source with my
parameters
Of course not ...
> later. I'm rendering a tabasco bottle for someone.
I hope it will be bigger than the last Image ... ;)
/8;#local
,i-1)#else
Walzer
Date: 20 Mar 2001 11:06:14
Message: <3ab77ff5@news.povray.org>
> it's mentioned in:
Don't know how I missed it, since I read pretty carefully.  Must be going
blind or stupid, and last I checked, my eyes were fine... *sigh*
Well, I'll do a test render, and if it works, great.  If it doesn't I kill
it.
Geoff
Date: 20 Mar 2001 11:08:09
Message: <3ab78069@news.povray.org>
I think a sphere on a plane always ends up with a sharp line because of the
underlying geometry.  Your sphere has a brighter than average division line
because of the cumulative effect of all that fog (looking at your horizon I
can see a whiter-than-white stripe that gets reflected in your sphere).
I know nothing about radiosity and look forward to seeing your experiment
evolve.
BTW, unless you are the news administrator it would be nice if you changed
your name to something other than "news.povray.org".
Date: 20 Mar 2001 11:17:37
Message: <3AB782A2.465737A9@gmx.de>
Oops, i missed that, sorry.
Date: 20 Mar 2001 11:26:52
Message: <3ab784cc@news.povray.org>
changed
Yes ... just realized this ...
That happens, when you need to reinstall your windows ...
I'm sorry for that ... I hope it's OK now ...
/8;#local
,i-1)#else
Walzer
Date: 20 Mar 2001 12:36:37
Message: <3AB79525.4EE22720@kivisalo.net>
You are not wrong. There seems to be errors in rad calculations when
using background{} color. Replace this:
> background {color rgb <0.0,0.30,0.80>}
With this:
sphere{0,1000
  pigment{color rgb <0,0.3,0.8>}
  finish{diffuse 0 ambient 1}
  no_shadow
______________________________________________________________________
Kari Kivisalo                                  http://www.kivisalo.net
Date: 20 Mar 2001 13:15:37
Message: <3ab79e49@news.povray.org>
I think I found why you see a "reflection".
> #declare GroundTex=texture {
>                         pigment {checker color rgb 1, color rgb 0.95}
>                         finish {ambient 0 diffuse 0.8}
> sphere {y*6,5.5
>         texture {GroundTex
>                 normal {
>                         crackle 1
>                         scale 0.5
