POV-Ray : Newsgroups : povray.binaries.images : yet another mengersponge... Server Time
24 Jul 2026 11:36:00 EDT (-0400)
  yet another mengersponge... (Message 21 to 30 of 36)
<<< Previous 10 Messages Goto Latest 10 Messages Next 6 Messages >>>
Subject: Re: yet another mengersponge...
Date: 12 Mar 2001 13:48:51
Message: <3aad1a13@news.povray.org>
"Vahur Krouverk" <vah### [at] aetecee> wrote :L
> No, I wrote that! :-) Yes, it is isosurface, like this (POVMan 0.7 is
> required for running it, more complete example comes with
> documentation):
> #declare xyf=function{
>     shader{
>         shader_file "menger.slp"
>         "rec_depth" 20
> isosurface {
>     function {
>         xyf
>     contained_by { box { -1.0,1.0 } }
    But is it a fractal isosurface or a fractal shader? Seems like a shader
to me, not knowing anything about shaders.
Date: 12 Mar 2001 13:57:32
Message: <3AAD1C40.A259424C@aetec.ee>
Shader is probably not the best word for describing this. In version 0.7
I add feature, which allows to use shading language constructs and
virtual machine (which was created for shader byte-code execution) for
computing potential values for isosurfaces. So basically one can write
iso functions in C-like syntax, byte-compile them and use in iso-surface
calculation. As it appears, this works generally faster (2-5 times,
depending from complexity), than functions, which are written directly
in POV-Ray "language". And one can use more advanced features, such as
loops, temporary variables, etc.
Of course shader functions are slower, than built-in (i.e. hard-coded in
source code) iso-functions, about the same margin (2-5 times).
More about this is again in POVMan documentation.
Date: 12 Mar 2001 14:54:09
Message: <MPG.1517399eed9bd1a989897@news.povray.org>
> > Thus, better and better approximations would tend to a more and more
> > opaque object which take longer and longer to render. I'd say; skip
> > the transparency. :)
> Um, with better approximations, the volume the ray passes through will
> decrease, and the sponge will become more and more *transparent*. You
> will get a fainter and fainter image of the sponge, until it is
> invisible. But as I said above, I'm only interested in an approximation,
> maybe 3-5 levels...a real sponge would be impossible.
I'd have thought that would depend on the material being used to make
said sponge?  With a transparent but reflective material, surely internal
reflections would build up to the point where they would overpower and
obscure any view through the sponge?
I could be wrong though...
Bye for now,
     Jamie.
Date: 12 Mar 2001 15:15:57
Message: <3aad2e7d$1@news.povray.org>
> calculation.
    Ah, now I see. Thanks
Date: 12 Mar 2001 18:03:17
Message: <chrishuff-96D7F4.17591212032001@news.povray.org>
In article <MPG.1517399eed9bd1a989897@news.povray.org>,
Well, I was specifically talking about transparent sponges, but I think
that the cross-section area of the sponge will tend toward 0 as the
surface area tends toward infinity, so a ray (or in the real world, a
photon) wouldn't be able to hit a perfect sponge, and would just pass
through it.
Christopher James Huff
Date: 12 Mar 2001 18:05:54
Message: <chrishuff-012D20.18015012032001@news.povray.org>
In article <3aad1a13@news.povray.org>, "Bill DeWitt"
> shader to me, not knowing anything about shaders.
It's a fractal isosurface using a fractal shader as a function. It's no
more a shader than an isosurface that uses a pigment function is a
pigment. The object is an isosurface, defined as all points where a
function is equal to a threshold value...the way the function is
generated doesn't matter.
Date: 12 Mar 2001 19:35:26
Message: <3aad6b4e$1@news.povray.org>
"Chris Huff" <chr### [at] maccom> wrote in message
news:chrishuff-012D20.18015012032001@news.povray.org...
    Right. I got that, thanks.
    But I am still hoping that someone will make a fractal or pseudo-fractal
isosurface... as well as a good isosurface tree.
Date: 12 Mar 2001 22:21:05
Message: <chrishuff-947071.22170012032001@news.povray.org>
In article <3aad6b4e$1@news.povray.org>, "Bill DeWitt"
>     pseudo-fractal isosurface...
What's wrong with the Menger sponge isosurface?
This would probably be unuseably slow and unwieldly at a complexity high
enough for it to look like a tree. You might be able to do it with the
blob pattern in a pigment function, though...
Date: 12 Mar 2001 22:48:03
Message: <3aad9873@news.povray.org>
news:chrishuff-947071.22170012032001@news.povray.org...
    Doesn't it need the PovMan version to run? I just barely am willing to
go with the MegaPov.
    It's the principal of the thing.
Subject: Menger in space - 53 kbu (was: yet another mengersponge...)
Date: 13 Mar 2001 18:02:38
Message: <slrn9at7h6.b30.hjp-usenet@teal.h.hjp.at>
On 2001-03-10 12:23, Chris Huff <chr### [at] maccom> wrote:
>In article <3AA8E44A.6218AF06@stress.uio.no>, Simen Kvaal
I have started one at 4 levels (CSG, no isosurface), but it seems that
this will take a few days (or weeks) to render. At two levels, the
transparent sponge looks rather boring, but the histogram has a mildly
interesting, space-ship-like look, so I'm posting that instead:
Download 'menger-2-t5-h.jpg' (52 KB)
Preview of image 'menger-2-t5-h.jpg'
