POV-Ray : Newsgroups : povray.binaries.images : yet another mengersponge... Server Time
24 Jul 2026 09:49:38 EDT (-0400)
  yet another mengersponge... (Message 11 to 20 of 36)
Subject: Re: yet another mengersponge...
Date: 9 Mar 2001 12:31:53
Message: <3AA913EC.2DC3A191@inapg.inra.fr>
Bonsai wrote:
> But when I want to do the cut away with a sphere it goes back to the 1 or 2
What about cutting away the (correctly positioned) individual parts first ? It
should render faster than making the union first and cutting the union after.
One fun thing would be to make the sponge out of triangles... I would render
very quickly I guess.
G.
http://www.oyonale.com
Graphic experiments
Pov-ray gallery
Date: 9 Mar 2001 13:18:18
Message: <3AA91E79.770A2F54@b0n541.net>
with them. But I want to do some csg-ing with this little sponge thing after I
can create it fast enough.
Thanks for the hints again,
Bonsai
Date: 9 Mar 2001 16:16:54
Message: <3AA9494D.58AF9116@peak.edu.ee>
Bonsai wrote:
> I wanted to do the sponge in pure csg. So I did a lot of differences, that
> resulted in this long rendertime.
Why differences? You should get *much* faster rendering if you created the
sponge as an union, i.e. stack a lot of little blocks to make up the sponge
structure, instead of progressively cutting holes out of one big block.
Margus Ramst
Home page http://www.hot.ee/margusrt
Date: 10 Mar 2001 07:17:32
Message: <chrishuff-3098F7.07134510032001@news.povray.org>
In article <3aa8d2db@news.povray.org>, "Bonsai" <bon### [at] b0n541net>
wrote:
> I never wanted to let it look like cheese. I use the yellow color
> only for modelling and testing a new object or shape, because for me
It was supposed to be a joke...I just forgot the smiley. But I do think
the smaller piece would look at home on a mouse trap...
Christopher James Huff
Date: 10 Mar 2001 07:27:23
Message: <chrishuff-641476.07233610032001@news.povray.org>
In article <3AA8E44A.6218AF06@stress.uio.no>, Simen Kvaal
<sim### [at] stressuiono> wrote:
> Consider rendering a compact subset of R^3 (that is closed and
> bounded) which has zero volume but infinite surface area. Thus, it
> will require infinitely many recursion levels to trace one single ray
> accurately through it.
Of course, I meant an *approximation* of a Menger sponge...rendering a
real one would literally take forever, and probably not be that
interesting.
> And it would definetely not be transparent, or even semitransparent.
> Thus, better and better approximations would tend to a more and more
> opaque object which take longer and longer to render. I'd say; skip
> the transparency. :)
Um, with better approximations, the volume the ray passes through will
decrease, and the sponge will become more and more *transparent*. You
will get a fainter and fainter image of the sponge, until it is
invisible. But as I said above, I'm only interested in an approximation,
maybe 3-5 levels...a real sponge would be impossible.
Date: 11 Mar 2001 11:11:25
Message: <3aaba3ad$1@news.povray.org>
Interesting thought!
I think you're right; it should be invisible.
~simenkv.
Date: 12 Mar 2001 05:34:32
Message: <3aaca638@news.povray.org>
Bonsai wrote in message <3AA91E79.770A2F54@b0n541.net>...
such object as mesh should be extremly fast
and you don't need CSG - just clippped_by
remember that copy of mesh not waste memory !
and you can balance between memory and speed by spliting object to smaller cubes
(you must find level) and below size create triangles and above size create
copies of meshes with clipping only some of them
ABX
Date: 12 Mar 2001 11:38:58
Message: <3AACFBC6.4DAD69C2@aetec.ee>
I tried menger with different level of recursion. Iso-surface
calculation precision may affect results, so they are not definite, but
using recursion level of 40 made sponge disappear completely, level 30
showed only some very faint parts of it. Sponge with level 20 looks like
this:
(sorry about incomplete sponge: I left it on table for overnight and
mice thought that it was cheese and eat some of it. Next time I'll put
in place, where they can not access it! ;o)
Seems like sponge with levels up to 6-8 is acceptable, after this sponge
gets too blurry and loses its beauty.
Download 'menger20.jpg' (20 KB)
Preview of image 'menger20.jpg'
Date: 12 Mar 2001 13:25:00
Message: <3aad147c$1@news.povray.org>
    Are you saying that this is an isosurface? I have been expecting to see
a fractal isosurface soon but I didn't know one had been made.
Date: 12 Mar 2001 13:42:22
Message: <3AAD18B2.5A8A84C@aetec.ee>
No, I wrote that! :-) Yes, it is isosurface, like this (POVMan 0.7 is
required for running it, more complete example comes with
documentation):
#declare xyf=function{
    shader{
        shader_file "menger.slp"
        "rec_depth" 20
isosurface {
    function {
        xyf
    contained_by { box { -1.0,1.0 } }
    all_intersections
    max_gradient 100
    accuracy 0.001
    scale 2
shader file is as follows:
iso_function menge(float rec_depth = 8){
    float testfirst(output float mx, mn){
        float rv = -1;
        mx *= 3;
        mn *= 3;
        float i;
        extern float rec_depth;
        for (i=0; i<rec_depth;i+=1){
            if(mx<=1 && mn <= 1){
                rv = 1;
                break;
            else{
                mx = abs(mod(mx*3+1, 6) -1);
                mn = abs(mod(mn*3+1, 6) -1);
        return rv;
    float retv = -1;
    if (testfirst(abs(xcomp(P)),abs(ycomp(P))) == 1 ||
        testfirst(abs(xcomp(P)),abs(zcomp(P))) == 1 ||
         testfirst(abs(zcomp(P)),abs(ycomp(P))) == 1)
      retv = 1;
    return retv;
