POV-Ray : Newsgroups : povray.binaries.images : Clothray cloth simulation patch.. Server Time
15 Jun 2026 08:57:37 EDT (-0400)
  Clothray cloth simulation patch.. (Message 21 to 30 of 34)
<<< Previous 10 Messages Goto Latest 10 Messages Next 4 Messages >>>
Subject: Re: Clothray cloth simulation patch..
Date: 2 Mar 2001 17:06:20
Message: <chrishuff-C8184D.17043702032001@news.povray.org>
<ber### [at] inamecom> wrote:
> 	Exactly, but to do what he said, you would have to take the POV source
> code for intersection with objects...
No you wouldn't...supporting every single POV feature would be too much
work, but interaction with the basic objects and a simple description
language wouldn't require any POV source.
Christopher James Huff
Date: 2 Mar 2001 17:12:44
Message: <chrishuff-D1D4A2.17110402032001@news.povray.org>
> 	It could, but that would mean recomputing the cloth at each render which
> would be very slow.
What about cloth simulation *requires* this? It could easily be kept as
a persistent object, like the particle_system patch, or have data stored
in a temporary file, like radiosity or photon mapping.
> The difference between a cloth and an height field or a bezier patch
> is that those are converted to a mesh on the fly and then this mesh
> is used for the render, whereas the cloth is output to a file as a
> mesh and then you need to restart pov to render this mesh.
Again, why? A cloth object patch could easily convert to a mesh on the
fly. No need to output a mesh to a file or restart POV.
What is different about cloth that it can't be done like height fields,
bezier patches, or the particle_system?
Date: 3 Mar 2001 06:02:17
Message: <3AA0CFB4.F8F047C3@simberon.com>
> > would be very slow.
Cloth is simulated over time - a static model is not.  If cloth were implemented in
POV, you would have to specify how much time you want to step the simulation before
doing the rendering.  Too little time means that the cloth hasn't finished falling
and covering the area.  Too much time and the cloth could have fallen right off your
surface.  If you were to create an animation with cloth, you would have to simulate
from the start of the cloth simulation to the proper point in the scene.  Unless you
have some way of rendering multiple scenes in POV without stopping, you'd have to
recalculate that each frame and it would take longer each time.
Having said all that, it's possible to write the cloth simulation as part of POV or
as a separate utility.  The problem with a separate utility is that you have to
re-implement all of the POV shapes in the utility.  Incidently, the cloth-surface
intersection calculations are the same ones used for ray-surface intersection
already implemented in POV, so all the existing shapes could be supported for the
cloth to drape over.
David Buck
dav### [at] simberoncom
Date: 3 Mar 2001 08:59:49
Message: <chrishuff-15A430.08572303032001@news.povray.org>
In article <3AA0CFB4.F8F047C3@simberon.com>, David Buck
> implemented in POV, you would have to specify how much time you want
> to step the simulation before doing the rendering.
My particle_system patch is also a dynamic system...you specify the
number of iterations to use and the amount of time it spans.
> Too little time means that the cloth hasn't finished falling and
> right off your surface. If you were to create an animation with
> cloth, you would have to simulate from the start of the cloth
> simulation to the proper point in the scene. Unless you have some
> to recalculate that each frame and it would take longer each time.
You mean rendering without constantly re-parsing the scene? That isn't
possible yet, but you can render multiple images without recomputing the
entire cloth system each time. Either save the system to a file at each
frame with a save_file keyword, like radiosity or photon mapping, or
assign it to a persistent variable that is saved from frame to frame.
Date: 9 Mar 2001 10:18:53
Message: <3AA8F45C.4080101@iname.com>
 >> render which  would be very slow.
 >  as  a persistent object, like the particle_system patch, or have
 > data stored  in a temporary file, like radiosity or photon mapping.
	This assumes you're doing an animation and want the cloth to evolve from
frame to frame. I was speaking more of several test renders of the same
scene for which having the cloth computed once ond for all is clearly
better.
 > the  fly. No need to output a mesh to a file or restart POV. What
bezier
	Unless I'm very much mistaken, you do recompute the particle_system for
each render don't you? (I don't mean each frame in an animation here)
This is too slow in my opinion, so you need to be able to perform the
cloth simulation once and save the result in a file (a mesh is the most
logical form of output here, though not the only one). Maybe the
particle system renders faster than cloth, otherwise I would argue that
particle systems should probably be implemented as an outside utility too...
	The ability to transform a bezier patch into a mesh is just a trick to
make the render faster. The point isn't what internal structure pov uses
to render a particular piece of data, but how the data is generated in
the first place.
	I'll return the question about height-fields to you: what is the
difference between hfs and cloth that would justify the cloth to be
generated in pov while the hf is generated by an outside program?
(Again, the fact that pov transforms the hf into something very similar
to a mesh for rendering is irrelevant here, the point is that the data
itself is generated by an outside utility).
		Jerome
* Abandon the search for truth, * mailto:ber### [at] inamecom
* Settle for a good fantasy.    * http://www.enst.fr/~jberger
Date: 9 Mar 2001 10:21:22
Message: <3AA8F4F2.6090705@iname.com>
 >> source  code for intersection with objects...
 > much  work, but interaction with the basic objects and a simple
 > description  language wouldn't require any POV source.
	Since, as you said yourself, it would require too much work, the only
*practical* way of actually *doing* it is by taking the code from pov.
		Jerome
Date: 10 Mar 2001 07:40:10
Message: <chrishuff-0F8E58.07362210032001@news.povray.org>
> frame to frame.
No, it doesn't!
> I was speaking more of several test renders of the same scene for
> which having the cloth computed once ond for all is clearly better.
It certainly is (unless you are adjusting the cloth, of course...). And
there is no problem with storing it to a file and using the file for
test renders, or even with quitting and restarting POV-Ray.
Yes, I do, because I haven't implemented the save_file and load_file
features yet. But it is certainly possible to save the state to a file
and restore it when needed, it just needs to be implemented.
But you can't continue the cloth simulation from mesh data...the most
logical output would be to save the whole cloth simulation. If it was an
external utility and you were producing an animation, you would have to
output a lot of POV scenes and then render them, instead of running a
simulation while the animation progresses. If it is an internal patch,
it doesn't make sense to have it save to a POV file, because that means
you will always have to run it from the very beginning.
> Maybe the particle system renders faster than cloth, otherwise I
> would argue that particle systems should probably be implemented as
And I don't see what rendering time has to do with any of this...it will
render at the same speed whether you use a patch or an external utility.
Actually, it may be possible to optimize a patch for even more speed...
Um, well, I usually generate my height fields with POV-Ray...
The difference between height_fields and cloth? Cloth interacts with the
objects of the scene, that information is required in order to generate
the cloth, so it makes sense for it to be specified as part of the
scene. Height fields are a fixed element that don't usually depend on
anything in the scene.
Date: 11 Mar 2001 21:29:12
Message: <3aac3478@news.povray.org>
news:3AA### [at] inamecom...
    No it isn't, not entirely anyway. Reinventing the wheel may not be the
most efficient, but is often the most practical, solution to a  problem.
Scott Hill.
Software Engineer.
E-Mail        : sco### [at] innocentcom
Pandora's Box : http://www.pandora-software.com
*Everything in this message/post is purely IMHO and no-one-else's*
Date: 14 Mar 2001 13:30:21
Message: <3AAFB8BD.6010209@iname.com>
Chris Huff wrote:
 > [lots of thing about saving to a file]
	I see what you mean now. The problem with this approach is that it bloat
s
pov with code that has nothing to do with its original purpose. POV is a
rendering engine, it's meant to output images not cloth data, not
particle system data, only images. Adding "features" like that inside
pov itself can only result in overall slowdown (at least in the parsing
stage) and harder to maintain code (and therefore, more risk of bugs and
a longer wait between version). That's why I think those should be
implemented as separate utilities (even if ideally they would reuse the
pov code for object intersection. This isn't possible at the time being,
both because of the license and because pov wasn't written for it, but I
hope version 4 will address these points).
t
n
	If you look at the samples for the cloth simulator, you'll notice that i
t
does run the simulation while the animation progresses.
l
	If you allow the patch to write simulation related data to a file, then
rendering time has very little to do with it. If you don't, a patch will
have to recompute each time...
	Actually, it *is* possible to optimize a separate utility for more speed
since it may not need the same precision in the intersection
computations that pov does (the cloth simulator certainly doesn't)...
		Jerome
Date: 14 Mar 2001 15:17:53
Message: <MPG.1519e7a8c08ee958989708@NEWS.POVRAY.ORG>
In article <3AA### [at] inamecom>, =?ISO-8859-1?Q?J=E9r=F4me?= M.
Berger says...
> 	I see what you mean now. The problem with this approach is that it bloat=
> s=20
> pov with code that has nothing to do with its original purpose. POV is a =
> rendering engine, it's meant to output images not cloth data, not=20
> particle system data, only images. Adding "features" like that inside=20
> pov itself can only result in overall slowdown (at least in the parsing=20
> stage) and harder to maintain code (and therefore, more risk of bugs and =
> l=20
Just a quick interjection: why have you now the "=20" and "=t" bits in
your mail? html?
Regards,  Sander
