POV-Ray : Newsgroups : povray.binaries.images : Shortest code ever for mandel landscape made of spheres Server Time
16 Jul 2026 10:08:09 EDT (-0400)
  Shortest code ever for mandel landscape made of spheres (Message 1 to 10 of 18)
Subject: Shortest code ever for mandel landscape made of spheres
Date: 18 Jan 2001 06:22:55
Message: <3a66d20e@news.povray.org>
For very long time I thought that this was the shortest way of getting
a decent-looking mandelbrot landscape made of spheres with MegaPov:
camera{location 2look_at 0}light_source{9,1}$R=-2;#while(R<1)$I=-2;#while
(I<2)$A=R;$B=I;$N=0;#while($T=B*B;N<9&A*A+T<4)$B=2*A*B+I;$A=A*A-T+R;$N=
N+1;#end sphere{<R,N/9,I>.02pigment{bozo}}$I=I+.03;#end$R=R+.03;#end
  However, I just realized that I have been wrong all the time. There's a
much shorter way of doing the same:
(R<1)$I=-2;#while(I<2)sphere{<R,eval_pattern(mandel 9,
<R,I>),I>.02pigment{bozo}}$I=I+.03;#end$R=R+.03;#end
  In practice this makes the exact same thing as the previous. (Images made
with both codes included at the end of the article.)
  By the way, can you guess what does this code do without rendering it?
(Answer forwared to this article)
#macro A()int(rand(R)*4)*90#end$P=union{torus{1,.05translate<1,0,-1>}
torus{1,.05translate<-1,0,1>}cylinder{-y,y,.05}clipped_by{box{-1,1}}}
$R=seed(1);light_source{<99,30,-30>1}camera{location<9,6,-13>look_at
0angle 35}$Z=-11;#while(Z<21)$Y=-11;#while(Y<12)$X=-13;#while(X<12
)object{P rotate<A(),A(),A()>translate<X,Y,Z>no_shadow pigment{
rgb<1,.5>}finish{specular.5}}$X=X+2;#end$Y=Y+2;#end$Z=Z+2;#end
Download 'mandel1.jpg' (33 KB) Download 'mandel2.jpg' (32 KB)
Preview of image 'mandel1.jpg'
Preview of image 'mandel2.jpg'
Subject: Re: Shortest code ever for mandel landscape made of spheres
Date: 18 Jan 2001 06:23:45
Message: <3a66d23f@news.povray.org>
Download 'pipes.jpg' (127 KB)
Preview of image 'pipes.jpg'
Date: 18 Jan 2001 07:25:49
Message: <3A67172B.4FBD85F@chesapeake.net>
I am getting a new mental image of why you sign your
posts thhe way you do.
> char*i="b[7FK@`3NB6>B:b3O6>:B:b3O6><`3:;8:6f733:>::b?7B>:>^B>C73;S1";
> main(_,c,m){for(m=32;c=*i++-49;c&m?puts(""):m)for(_=(
> c/4)&7;putchar(m),_--?m:(_=(1<<(c&3))-1,(m^=3)&3););}    /*- Warp -*/
Date: 19 Jan 2001 18:49:33
Message: <3A68D147.6D05B6A6@faricy.net>
Defines an object that is two semi-torii connected by a vertical rod, going in
opposite directions from each other, and it tiles this object 23x23x23, each
one randomly rotated. There is also a typo, #while(Z<21)...
Date: 19 Jan 2001 18:53:08
Message: <3A68D21F.756DDEE3@faricy.net>
D'oh, I was getting coordinates confused. Of course it is a truchet tile, the
quarter-torii and coplanar and the cylinder runs between them. And the rotation is
a multiple of 90.
I was completely not seeing that!
Subject: Re: Shortest code ever for mandel landscape made of spheres => Not any more (25KB)
Date: 20 Jan 2001 08:03:53
Message: <3A698C6A.25CA6C7@online.no>
It can be done with 2 characters less.
(The image below is done that way.)
So Warp, can you spot how to shorten your code ?
And your "spaghetti"-code can be shorten too.
I think the same can be done with (at least)
11 characters less.
Btw.:
What's wrong with your keyboard ?
Best regards,
Tor Olav
mailto:tor### [at] hotmailcom
Download 'mandel.jpg' (25 KB)
Preview of image 'mandel.jpg'
Date: 20 Jan 2001 10:10:53
Message: <3A69AA7D.22E3C533@gmx.de>
I could not find it until now, but i have a version that is 8 characters
shorter than Warp's, although i'm not sure if you will accept it, because
it's not made of spheres.
I also managed to eliminate one while loop from Warp's version, but that
makes it slightly larger, maybe someone can also reduce this:
camera{location 2look_at 0}light_source{9,1}$R=0;#while
(R<99)sphere{<int(R)/99,eval_pattern(mandel 9,
<(R-int(R)-.5)*3,int(R)/40-1>),R-int(R)>.01pigment{bozo}}$R=R+.02;#end
Date: 22 Jan 2001 20:34:15
Message: <3A6CDF5D.C4140793@online.no>
Well, here's my solution:
camera{location 2look_at 0}light_source{9,1}$R=1;#while
(R+2)$S=2;#while(S+2)sphere{<R,eval_pattern(mandel 9,
<R,S>),S>.01pigment{bozo}}$S=S-.02;#end$R=R-.02;#end
If you're not doing it with spheres, then what are you using ?
Code please !
Interesting solution !
This reminds me of something Dan Johnson did in
his Arrange_3d macro. See his "Polyhedra include file"
thread in povray.binaries.scene-files, 11. Jan -01:
news://news.povray.org/3A67EB4C.EFE1B3BD%40hotmail.com
Best regards,
Tor Olav
Date: 23 Jan 2001 03:11:15
Message: <3A6D3CA0.D8B4DD91@gmx.de>
Well, that's not the obvious solution for a pascal programmer :-)
> Code please !
camera{location 2look_at 0}light_source{9,1}height_field
{pattern 99,99{mandel 9 color_map{[0 rgb 0][1 rgb 1]}
scale.3rotate-x*90translate.5}pigment{bozo}}
I first tried it with mod(), but it turned out beeing ways longer.  What's
in fact missing is a frac() function returning the fractional part of a
variable (although R-int(R) does perfectly suffice apart from length :-).
Date: 23 Jan 2001 08:27:05
Message: <Xns9032931CE5942seed7@povray.org>
If it's reduction in character count what you're looking for:
(R<99)%S=int(R);sphere{<S/99,eval_pattern(mandel 9
<(R-S-.5)*3,S/40-1>)R-S>.01pigment{bozo}}$R=R+.02;#end
Ingo
