POV-Ray : Newsgroups : povray.binaries.images : about time for more ridged multifractaling [~222K Jpg] Server Time
13 Jun 2026 14:27:15 EDT (-0400)
  about time for more ridged multifractaling [~222K Jpg] (Message 11 to 20 of 22)
<<< Previous 10 Messages Goto Latest 10 Messages Next 2 Messages >>>
Subject: Re: antialiased ridged multifractaling [~150K Jpg]
Date: 18 Jan 2001 10:26:05
Message: <3A670A7B.AF88AB34@videotron.ca>
"Bob H." wrote:
> Changed the sunlight direction for better terrain relief and shadows since that last
one.  3.5 hours to render.
Geez...  It took so long to render that some of the snow has melted. ;)
It's probably just the camera angle or me, but the mountain in the lower
left-hand side seems a bit too low to have glaciers.
> Oh, and the scene file is at p.t.s-f.
Thank you very much.
Francois Labreque | In the future, performance will be measured
    flabreque     | by the size of your pipe.
        @         |             - Dogbert, on networking
   videotron.ca
Date: 19 Jan 2001 01:01:03
Message: <3a67d81f@news.povray.org>
"Hans-Detlev Fink" <hdf### [at] pecosde> wrote in message
news:3A670386.27BA903A@pe.cos.de...
> I'm not sure whether this one is better than the non-aa one.
> Probably truth lies in between.
Hmmm, okay.  Thanks(?)
> A trick that used to work quite well for me is to render
> without aa but with 50% more size (each, x and y), then blur
> it in Photoshop/Gimp/... (2-3 pixels) and finally scale it
> down to the desired format.
> This usually results in a very fine blur effect, less
> than aa in the renderer, thus leaving many of the details.
Yeah, used to do that a lot myself back in the 486 CPU days.  If the render can
be done within a day and at a large res. while using AA I'm not so tempted
anymore.  Btw, this was +a0.2 +r2 +am2 +j1.0
Bob H.
Date: 19 Jan 2001 01:06:01
Message: <3a67d949@news.povray.org>
news:3A6704F2.2047238D@gmx.de...
> Making the vegetation 3-dimensional by adding it to the geometry of the
> landscape would be a nice thing if you are not afraid of slow rendering.
Uh, you're talking about a huge parse aren't you? :-)  I'm still only at 256MB
memory here.
I figure each tree would be only several pixels even closest to the camera.
> I posted a 2d gradient pattern some time ago that could be used for this
> purpose similar to the slope pattern you used for the texture.
Not exactly sure how you meant "2D" here but I seem to recall that.
> Thanks for the code BTW.
Glad you liked, and yw.
Bob H.
Date: 19 Jan 2001 01:13:46
Message: <3a67db1a@news.povray.org>
"Francois Labreque" <fla### [at] videotronca> wrote in message
news:3A670A7B.AF88AB34@videotron.ca...
Yeah, just snow let's pretend, not glaciers.  Think you're right though the
terrain flattens out under the camera, or appears so anyway.
YW, and I forgot to mention that I had done a strange thing to the slope
texture.  I rotated it some.  Not sure if that was a good idea to try.  Was
thinking about shadow-side having more snow and sunlit-side having less snow.
Needs another approach for that but I haven't figured a way (yet?) using just
the slope texture alone.  Probably only messed it up but I forgot to remove
that part.
Bob H.
Date: 19 Jan 2001 02:11:14
Message: <3A67E891.1090DF7@gmx.de>
> memory here.
No, i meant to do the plants with the isosurface, just make the planted
parts a bit higher and more noisy.
It only means that it's 2d :-) meaning that it calculates the gradient in
a plane. Souldn't matter here, because usually you use something like:
isosurface {
  function { y - fnRMF(x, 0, z) - fnAdditiomalNoise(x, y, z) }
so you only use the RMF function on a 2d plane
Your construction is somewhat different, so i'm not sure if it works.
Subject: Re: about time for more ridged multifractaling [~222K Jpg]
Date: 19 Jan 2001 02:15:22
Message: <3A67E95E.AA1436A0@online.no>
"Bob H." wrote:
> "Tor Olav Kristensen" <tor### [at] onlineno> wrote in message
> news:3A662AA9.72C9714C@online.no...
> > May I see the source ?
> > So that I can have a look at how to do such a nice scene :)
> > And can you please also render it with AA ?
> Oh, okay  ;-)  guess everyone would rather see it that way too.
> I'll post the pertinent part of the scene file to povray.text.scene-files
> shortly.  The AA render will be a while.
The new rendering looks better.
Your sea is quite realistic.
I like that it has areas that been "stirred up" (?)
by the wind and the way the mountains reflects in it.
Thank you very much for sharing the code.
Best regards,
Tor Olav
mailto:tor### [at] hotmailcom
Date: 19 Jan 2001 03:05:31
Message: <3a67f54b@news.povray.org>
news:3A67E95E.AA1436A0@online.no...
Glad to.  Of course, "needs work" is all I can ever think about it.
Date: 19 Jan 2001 03:21:22
Message: <3a67f902$1@news.povray.org>
I see now, yes, that's the kind of thing I've thought too but when I tried it
the render time was phenomenal by my standards.  First time I've seen your
Ategeros program concept at your web site.  I do remember the talk about that.
By comparison what I'm doing here is child's play but I'll see what I can do to
improve  :-)
Bob H.
news:3A6### [at] gmxde...
> isosurface {
> Christoph
Date: 19 Jan 2001 12:29:18
Message: <3A68796E.4EE6BA4F@gmx.de>
I already feared that, maybe some internal gradient pattern would be
faster.
> improve  :-)
I don't think that can be compared since Ategeros is only about
heightfields so it's quite limited.  Of course adding some seperate
objects for trees could be quite good even for an isosurface landscape.
I did not work much on Ategeros recently, also because isosurfaces offer
many things not possible with heightfields.
Date: 19 Jan 2001 18:41:11
Message: <3A68CF51.91A944CE@faricy.net>
"Bob H." wrote:
> Got to admit this makes the unantialiased one look bad.  It's just that sometimes AA
does a lot to make things
> fuzzy and blurred, esp. when using lower screen resolutions, and I liked the better
than 20-20 vision sort of
> thing.
I agree. In a way it's kind of a lose-lose situation, but not much you can do about
it. The best would of course be
a super-high-res render w/out aa, but that would take forever and it could really only
be viewed as a printout
anyway.
