POV-Ray : Newsgroups : povray.binaries.images : Greetings from Arda! (~112kau) Server Time
13 Jun 2026 15:26:00 EDT (-0400)
  Greetings from Arda! (~112kau) (Message 11 to 15 of 15)
Subject: Re: Greetings from Arda! (~112kau)
Date: 6 Jan 2001 17:08:53
Message: <3a579775@news.povray.org>
> I really like the grass in the foreground and the puffy clouds. I don't
know
> about the colour. It seems to be a bit too bright green, but that might be
part
> of the story.
Well, I agree with you there, that's caused by the radiosity. That's why I
was asking if there was a way to reduce the effects of it.
> The mountain tops aren't really to bright, it's more the region just below
that
> seems to be a bit too dark.
Aha...
> My main suggestion would be to make the hills a bit less uniform in
colour.
I said I'd do that. I haven't added the forest, and I haven't added the
rocky cliffs yet. This is still very much a work in progress.
Date: 6 Jan 2001 17:14:57
Message: <3A5797C5.1F55D2F4@faricy.net>
I don't really see the point of radiosity, I think this pic would be better
without it.
Nice to see it coming along.
The terrain texturing needs a little work, intensity's too high and the dark
green ring doesn't look right, IMHO.
Date: 6 Jan 2001 23:32:46
Message: <3A57F2B2.20259203@teleport.com>
"Tony[B]" wrote:
> > Grass texture is too detailed for the entire scene.  It should blend
> > together in the background.
> I don't follow you... Please elaborate.
Hm... what I mean is that all the fine detail you have going on with
your grass in the forground is wasted in the background and in fact
degrades from the overall effect of the shot (IMO).  It never looks
quite "right".  In the real world haze and distance tend to blur things
together. If you are using a procedural texture then you can have it get
less active along the Y axis (Z being up in this case), for example.
Hm... methinks I am adding to the confusion. :o/
Anyway, keep at it.
Date: 8 Jan 2001 12:11:54
Message: <3A59F52A.7080DEF8@sheayright.com>
"Tony[B]" wrote:
> If you could write me a tutorial explaining how to go about this, I would be
> greatful. I cannot, with my current skill level, do this properly.
Create a second height_field with a tall central peak in it, and texture it like
a rock. Then place it in your scene just below the height_field you're using to
create the rolling hill so that the peak pokes up through the hill. Scale as needed.
Date: 8 Jan 2001 17:11:49
Message: <3a5a3b25@news.povray.org>
I understand that... what I was wondering was if he could explain how to
make the transition not be so abrupt.
