POV-Ray : Newsgroups : povray.binaries.images : Drunken Bricks 55kbu Server Time
13 Jun 2026 15:24:55 EDT (-0400)
  Drunken Bricks 55kbu (Message 9 to 18 of 18)
<<< Previous 8 Messages Goto Initial 10 Messages
Subject: Re: Drunken Bricks 55kbu
Date: 6 Jan 2001 10:50:25
Message: <3A573DFD.45C79083@onwijs.com>
Cool! I've been working with bricks for a tower too lately, but never got such
an interesting effect.
BTW My problem is to get the bricks to 'fit' (i.e. the shape adapted to the
curves) and to get rounded bricks (I can't remember where I got that idea).
I'm glad to say I got it working, just to bad the result is boring (apparently
it works).
Cheers,
Remco
Alan Holding wrote:
> Hello, all.
> I'm making a brick wall macro thing at the moment which follows splines.  (I
> know other people have made brick macros, but there's nowt like doing for
> learning...)  After putting a rotation in the wrong place, I got this.  I
> quite like it, so I though I'd post it here.
> Bye,
> Alan.
Date: 6 Jan 2001 13:09:31
Message: <3A57609D.A66E98BB@teleport.com>
nice effect.
is that your texturing on it or is that a moire pattern I see?  If so...
how in the HECK did that show up?
Date: 7 Jan 2001 11:54:23
Message: <3a589f3f$1@news.povray.org>
Dearmad <dea### [at] teleportcom> wrote in message
news:3A57609D.A66E98BB@teleport.com...
> nice effect.
Every brick was given a random pigment and slightly different normal, the
code being:
pigment {rgb <rand(seed),rand(seed),rand(seed)>/2+0.5}
finish {phong 1 phong_size 75 ambient 0.2 diffuse 0.7 metallic}
normal {granite 0.25 scale 0.05 turbulence 0.02 translate rand (seed)*2}
which gave a nice pastel look to them, I think.
Date: 7 Jan 2001 11:54:25
Message: <3a589f41@news.povray.org>
Remco de Korte <rem### [at] onwijscom> wrote in message
news:3A573DFD.45C79083@onwijs.com...
the
idea).
(apparently
> it works).
The mortar is the problem for me.  When the bricks follow a sharp curve in
the spline, the nasty 'joins' in the mortar become obvious.  So, what I'm
attempting to do is sample the spline's heading at each point where a brick
would go, and then use CSG to chop up a cylinder to make nice curvy joins.
As I'm useful Chris Colefax's Spline Include File (again!) this should be
pretty painless to achieve.  (He says foolishly...)
Bye.
Date: 8 Jan 2001 07:58:21
Message: <3a59b96c@news.povray.org>
> it works).
I've got a stone wall macro that can do curcular towers and such, and can
even do bricks.  It uses isosurfaces, so it's a little slow, but the effect
is really nice.  I'm hoping to release it to the public as soon as I write
some docs, but if someone wants a look-see at a pre-release version, I could
see about doing that.
Geoff
Date: 8 Jan 2001 17:00:11
Message: <3A5A3796.9879657C@onwijs.com>
> > it works).
> Geoff
I wish I had that before. I thought it would probably be able to do this with
isosurfaces but I don't have a clue on how to start.
I've got it done now, including door and window openings.
Remco
Date: 9 Jan 2001 20:48:15
Message: <3A5BBEA0.14908A4E@online.no>
Alan Holding wrote:
> Hello, all.
I like it too.
Please make more such errors !
Tor Olav
mailto:tor### [at] hotmailcom
Date: 15 Jan 2001 02:37:13
Message: <3A62AAB1.D28CF104@pobox.com>
> normal, the code being:
> texture {
Ah, and assuming that rand() is a typical linear type (why can't i find
it in the doc?!), one would expect vague stripes to show up.
Why not apply the normal to the wall as a whole?
Anton Sherwood  --  br0### [at] p0b0xcom  --  http://ogre.nu/
Date: 15 Jan 2001 11:16:45
Message: <chrishuff-B6FE40.11180715012001@news.povray.org>
In article <3A62AAB1.D28CF104@pobox.com>, Anton Sherwood
> it in the doc?!)
Is this what you are looking for?
4.1.3.6 Float Functions
rand(I)     Returns the next pseudo-random number from the stream
specified by the positive integer I. You must call seed() to initialize
a random stream before calling rand(). The numbers are uniformly
distributed, and have values between 0.0 and 1.0, inclusively. The
numbers generated by separate streams are independent random variables.
Christopher James Huff
Date: 15 Jan 2001 12:48:42
Message: <3a6337fa$1@news.povray.org>
Anton Sherwood <bro### [at] poboxcom> wrote in message
news:3A62AAB1.D28CF104@pobox.com...
Er... Don't know, really.  You're right, of course.  In theory it should
save time (?), so I'll give it a shot and see if it speeds up the render
any.
Bye,
Alan.
