POV-Ray : Newsgroups : povray.binaries.images : Fill any object with dense-packed spheres of any radius (16kbbu) Server Time
26 Apr 2026 18:59:59 EDT (-0400)
  Fill any object with dense-packed spheres of any radius (16kbbu) (Message 1 to 7 of 7)
Subject: Fill any object with dense-packed spheres of any radius (16kbbu)
Date: 30 Dec 2000 21:51:04
Message: <3a4e9f18@news.povray.org>
See file in p.b.s.-f.
Code fills with spheres in fcc structure.
Download 'volume31.jpg' (16 KB)
Preview of image 'volume31.jpg'
Subject: Re: Fill any object with dense-packed spheres of any radius (16kbbu)
Date: 30 Dec 2000 21:55:22
Message: <3a4ea01a@news.povray.org>
"Greg M. Johnson" <"gregj;-)56590\""@aol.c;-)om> wrote in message
news:3a4e9f18@news.povray.org...
This looks very interesting Greg.. I'll go get the code now. Thanks
Andy Cocker
Date: 31 Dec 2000 08:51:31
Message: <3a4f39e3$1@news.povray.org>
I'd been trying to do something similar, which I gave up on.
My version was to imitate the pov-ray rendering icon, where any space is
filled with X-point touching randomly scaled and translated spheres of
random texture having no intersections.
I never got it to work. I never came close. I don't even know where to start
beyond needing an intersection testing algorhythm.
ian
Greg M. Johnson <"gregj;-)56590\""@aol.c;-)om> wrote in message
Date: 31 Dec 2000 09:09:37
Message: <3a4f3e21@news.povray.org>
You don't need that. The object function does the trick, plus knowing how the
face centered cubic structure is stacked...
Here is the core of my algo:
   #declare obfun=pigment {object {MyObject color Black color White}}
                #local dd=array[5]
                #local drr=(2^0.5)*radii;
                #local dd[1]=<0,0,0>;
                #local dd[2]=<0,drr,drr>;
                #local dd[3]=<drr,0,drr>;
                #local dd[4]=<drr,drr,0>;
    #local place=dd[nnnn]+<minx+ix*dx,miny+iy*dy,minz+iz*dz>;
    #local blank=eval_pigment(obfun,place);
    #if (blank.x>0)
               sphere {place,radii*1}
Date: 31 Dec 2000 10:04:00
Message: <3A4F4A4A.3FB3A8E2@videotron.ca>
What's this?
From what I understand, it is someway of making sure the inside of your
object is white, and the outside, black.  Am I right?
Francois Labreque | Rimmer: "Let's go to red alert!"
    flabreque     | Kryten: "Are you sure, Sir?  You realize it
        @         |          actually means changing the bulb!"
   videotron.ca
Date: 31 Dec 2000 11:05:25
Message: <chrishuff-33756A.11064931122000@news.povray.org>
In article <3A4F4A4A.3FB3A8E2@videotron.ca>, Francois Labreque
He is using the object pattern in MegaPOV as an interior testing method,
the first thing following the object covers all points outside the
object, the second covers all interior points. So you are correct, it is
a pigment that is a white shape surrounded by black in the shape of the
object.
Christopher James Huff
Date: 31 Dec 2000 11:20:55
Message: <chrishuff-CF1915.11222031122000@news.povray.org>
In article <3a4f3e21@news.povray.org>, "Greg M. Johnson"
Hmm, I use something more like "eval_pattern(object {MyObject})" when I
do this...actually, I wrap it in a macro.
This would make your code shorter and probably slightly reduce parse
time(though the use of a macro might counteract that benefit), the main
advantage is that it is shorter and easier to read.
Instead of:
    #if (blank.x>0)
My version would be:
#macro InObj(Pt, Obj) eval_pattern(object {Obj}, Pt) #end
    #if(InObj(place, MyObject))
