POV-Ray : Newsgroups : povray.binaries.images : Might as well... (~75kbu) Server Time
13 Jun 2026 17:30:35 EDT (-0400)
  Might as well... (~75kbu) (Message 7 to 16 of 16)
<<< Previous 6 Messages Goto Initial 10 Messages
Subject: Re: Softer Clouds (~76kbu)
Date: 21 Dec 2000 13:16:50
Message: <3a424912$1@news.povray.org>
> The stars fade out closer to the Earth...it's surrounded by an area of
> complete darkness. Maybe you should check your media settings...or
> max_trace_level, but since there isn't a very sharp boundary, I doubt
> that is the problem.
I actually did that on purpose, I used a bmp for the stars, after blacking
out a circle in the center.  I rendered it at 1024x768, then shrunk it with
photoshop.  The stars are more visible in the larger pic.
Date: 21 Dec 2000 13:28:03
Message: <chrishuff-77355B.13291321122000@news.povray.org>
In article <3a424912$1@news.povray.org>, "Ben Lauritzen"
> blacking out a circle in the center.
Oh...um, why?
Christopher James Huff
Date: 21 Dec 2000 13:56:21
Message: <3a425255@news.povray.org>
> Oh...um, why?
Because... it's hard to see the stars when there's something brighter in the
way.  I guess...
Date: 21 Dec 2000 16:44:52
Message: <3A427994.95D8215B@post3.tele.dk>
Definitely an improvement, I think! Looks very good..  :o)
Well, I see no stars (?) if they are supposed to be there.. Anyway my
idea for a further improvement, would be to make the shadows from the
clouds a little less dark.. And by the way, do you use 2 layers for the
clouds? Then, the bottom layer looks a bit strange.
But I like the whole of it, nevertheless.
Hugo
Date: 21 Dec 2000 18:12:30
Message: <3A428D88.977FD37E@videotron.ca>
Ben Lauritzen wrote:
> Personally, I think it's purdy.
Indeed it is.
But (there has to be one!) I think your water is unrealistically clear.
Can we actually see the continental shelf off the coast of Venezuela
from space?
Francois Labreque | Rimmer: "Let's go to red alert!"
    flabreque     | Kryten: "Are you sure, Sir?  You realize it
        @         |          actually means changing the bulb!"
   videotron.ca
Date: 21 Dec 2000 18:27:42
Message: <3A4290FE.C4B1F209@faricy.net>
Improved, but they look awfully thick still.
Earth pics are always purdy. :)
Date: 21 Dec 2000 19:21:52
Message: <3A42A159.758375A4@pilot.msu.edu>
Looks very good.  Any code?
Date: 22 Dec 2000 00:00:12
Message: <cd9COrlK4G8zP4ROndcp6I5TP5kB@4ax.com>
On Thu, 21 Dec 2000 10:39:43 -0600, "Ben Lauritzen" <loo### [at] yahoocom>
Impressive!
Any chance of getting a glimpse at the sourcecode?
Marc van den Dikkenberg
The PowerBasic Archives -- http://www.xs4all.nl/~excel/pb.html
All Basic Code Archives -- http://come.to/abcpackets
Date: 22 Dec 2000 11:36:21
Message: <3a438305@news.povray.org>
> from space?
Well, no... artistical merit and all.  I had the water as a solid color
before, but I couldn't seem to get it to look like water, so I just used the
land map again, which has clear water for some reason.
Date: 22 Dec 2000 23:50:51
Message: <3a442f2b$1@news.povray.org>
Not always...
