POV-Ray : Newsgroups : povray.binaries.images : Scatter (103k) Server Time
13 Jun 2026 19:20:51 EDT (-0400)
  Scatter (103k) (Message 11 to 16 of 16)
Subject: Re: Scatter (103k)
Date: 18 Dec 2000 21:37:58
Message: <3a3eca06@news.povray.org>
"Chris Huff" <chr### [at] maccom> wrote in message
news:chrishuff-B4EB2C.15073418122000@news.povray.org...
> In article <3a3e6b3d@news.povray.org>, "Andy Cocker"
> <big### [at] mariner9fsnetcouk> wrote:
> > I don't quite understand what #if (Norm.x != 0 | Norm.y != 0 | Norm.z
> > != 0) means, but I've yet to really look into it.
> If the trace() function doesn't find an intersection, it will return <
> 0, 0, 0> as the normal. This allows you to find out if it actually hit
> something.
Thanks Chris. It was the ! and the | predominantly that I didn't understand,
but I think I've got it figured out... my new scene is behaving as I want it
to anyway.
Would I be correct in thinking that the ! stands for 'does not', and the |
signifies 'and', thus the code reads "unless the trace function returns
<0,0,0>, then parse the following.. otherwise goto #else"?
Forgive me, this is probably really elementary programming syntax, but I'm
no programmer. According to the docs then I think I'm right.
All the best,
Andy Cocker
Date: 18 Dec 2000 21:59:13
Message: <chrishuff-CA4F95.22001918122000@news.povray.org>
In article <3a3eca06@news.povray.org>, "Andy Cocker"
> the | signifies 'and', thus the code reads "unless the trace function
> returns <0,0,0>, then parse the following.. otherwise goto #else"?
Close, very close:
"!" means "not", like you said, so "!=" means "is not equal to". "|"
means "or", not "and", so this statement:
#if(Norm.x != 0 | Norm.y != 0 | Norm.z != 0)
A
#else
B
Means:
"If Norm.x is not 0, or if Norm.y is not 0, or if Norm.z is not 0, do A,
otherwise do B."
In other words:
"If any component of Norm is not 0, do A, otherwise do B."
The "&" symbol means "and", so it could also be written as:
#if(!(Norm.x = 0 & Norm.y = 0 & Norm.z = 0))
Which translates nicely into English as:
"If not all the components of Norm are equal to 0..."
And the reason for all this is that you can't compare normals...I
usually use a vEq(V1, V2) macro:
#if(!vEq(Norm, < 0, 0, 0>))
or a vNull(V) macro:
#if(!VNull(Norm))
Christopher James Huff
Date: 18 Dec 2000 22:14:55
Message: <3a3ed2af@news.povray.org>
Hey, thanks, that helped a lot. You certainly know your stuff...
So, I've figured out how to use trace () to 'drop' my objects onto my hf
etc... but at present they are all vertical. I'd really like to get them to
be perpendicular to the object they've landed on.. I take it I need to use
the data that  trace () returned to give me the surface normal, and then
rotate each object to match... at present I am very unclear how to do this,
but I realise it's bad practise to ask here before I've really tried to
achieve this myself , so I'll go away now and try to fathom it out.
Of course, there's no sense me trying to re-invent the wheel, so any
suggestions would be gratefully received.
All the best,
Andy Cocker
Date: 18 Dec 2000 22:34:21
Message: <chrishuff-BF9B97.22352618122000@news.povray.org>
In article <3a3ed2af@news.povray.org>, "Andy Cocker"
> I take it I need to use the data that  trace () returned to give me
> the surface normal, and then rotate each object to match... at
Try the Reorient macro, it is on the Thoroughly Useful Macros page:
http://users4.50megs.com/enphilistor/macs.htm
Date: 19 Dec 2000 03:13:30
Message: <3a3f18aa$1@news.povray.org>
Chris Huff wrote in message ...
Or get an include file that can do all that here:
http://www.geocities.com/Rengaw03/povray.html
It's the "vegetate.zip" file.
Mark
Date: 19 Dec 2000 13:09:46
Message: <3a3fa46a@news.povray.org>
"Mark Wagner" <mar### [at] gtenet> wrote in message
news:3a3f18aa$1@news.povray.org...
Great, thanks.
Andy Cocker
