POV-Ray : Newsgroups : povray.binaries.images : Current attic Server Time
14 Jun 2026 01:05:50 EDT (-0400)
  Current attic (Message 4 to 13 of 33)
<<< Previous 3 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Current attic
Date: 7 Dec 2000 15:26:14
Message: <3A2FF267.43FE3517@gmx.de>
Do you want to burn the house or why is the wood above the candle that
dark? :-) The rest looks quite good now, just the box needs some work on
the texture IMO.
BTW why didn't you post it in plain jpg?
Date: 7 Dec 2000 15:40:51
Message: <MPG.149a105a6ad660e19896b9@news.povray.org>
in povray.binaries.images, Warp says...
> begin 600 attic2.jpg.bz2
BZ2 is unknown to me as an extension; what should I do with it?
Regards,  Sander
Date: 7 Dec 2000 15:55:32
Message: <3A2FF944.8C8BE2ED@gmx.de>
Ken wrote:
> You will probably have to do as I did and save the file to disk,
> change the name to attic2.jpg, and then open it in a regular
> image viewing program. It's a major big time hassle but if you
> want to see it this probably the only option you will have
> available to you as it was to me.
What viewing program do you use? It's no jpg file but bzip2 compressed and
therefore you need a decompressor.
To Sander:
There is a bunzip2.exe coming with cygwin, otherwise you could try
http://www.powerarchiver.com/ (presuming you are using windows)
Date: 7 Dec 2000 16:01:42
Message: <3A2FFAB5.75C3FD97@spiritone.com>
What kind of file is this? I can't read it.
Josh
Warp wrote:
>    attic2.jpg.bz2    Type: unspecified type (application/octet-stream)
>                  Encoding: x-uuencode
> main(i,_){for(_?--i,main(i+2,"FhhQHFIJD|FQTITFN]zRFHhhTBFHhhTBFysdB"[i]
> ):_;i&&_>1;printf("%s",_-70?_&1?"[]":" ":(_=0,"\n")),_/=2);} /*- Warp -*/
Date: 7 Dec 2000 16:23:15
Message: <3A2FFF91.183A4275@onwijs.com>
> Josh
Me neither, or at least after seeing the extension I didn't even try.
This is funny, when you think about the discussion on file formats going on in
the animation group. I guess my newsreader isn't as advanced as it should be on
my piece of crap toy system ;)
Remco
Date: 7 Dec 2000 16:28:19
Message: <Xns9003E2FD7seed7@povray.org>
Warp wrote:
>ingo <ing### [at] homenl> wrote:
>: I like the burning mark above the candle.
>  Can you guess how did I make it?-)
My first impression, when looking at the picture, was that it is a shadow.
That leads me to an invisible object or negative light.
My solution would probably be a scaled and turbulated spherical pigment.
>: The glass is way to clean, maybe
>: some condense or rain on it?
>  Any suggestions on how to do it?
Rain, little streams of water -> blobs, maybe with a little bit higher
reflection than the glass.
Condense, a very thin box, in front of the glass, containig scattering
media.
Ingo
Date: 7 Dec 2000 19:48:48
Message: <3a302ff0@news.povray.org>
on in
Almost seems to have been done as a matter of point, lets all start posting
our images in none standard hitherto unknown formats with or without
additional compression just for fun.
Kitty5 WebDesign - http://www.kitty5.com
Hi-Impact web site design & database driven e-commerce
PGP Public Key
Date: 7 Dec 2000 20:52:42
Message: <slrn930adr.vg1.steve@zero-pps.localdomain>
Condensation would be nice, and I'd use a bozo fairly large scale and
very transparent white/clear and put it on the pane of glass before
moving the glass into position, that way all the panes will have the
condensation in the same corner as in RL.
 12:11am  up 58 days,  2:36,  2 users,  load average: 1.44, 1.21, 1.08
Date: 7 Dec 2000 20:52:43
Message: <slrn930au4.vg1.steve@zero-pps.localdomain>
I thought Winzip could open these, I know from past experience that
it can open (and recognise) tar.gz files.
Date: 7 Dec 2000 23:51:37
Message: <3A3069A7.292CBFB8@pacbell.net>
Well you got me there. When I saved the file to disk I renamed it
attic.jpg. When I opened an image viewing program to view it I went
to a different directory from where I stored the recently saved
image. Unfortunately I also had an image titled attic.jpg from
a previous occasion (probably Warp's first version) and didn't
realize my mistake before posting. You are correct in that I
could not view todays image, as I stated I could, and apologize
for any confusion this may have caused.
(Does this mean I am a liberal ?)
Ken Tyler
