POV-Ray : Newsgroups : povray.binaries.images : Another Rad (19Kbu) Server Time
4 Mar 2026 13:49:48 EST (-0500)
  Another Rad (19Kbu) (Message 1 to 7 of 7)
Subject: Another Rad (19Kbu)
Date: 27 Nov 2000 00:55:37
Message: <3a21f759@news.povray.org>
Sorry... I'm just really enamoured with using radiosity on this particular
scene.
When I added the spheres, render time went up from around 5 mins, to over 8
hours! I've no idea why the huge difference... any ideas? The spheres are
just a simple union of nested #while..#end loops.
Andy Cocker
www.mariner9.net
..... for my music and graphics.
'I spilled spot remover on my dog. He's gone now. '
'I went to a restaurant that serves "breakfast at any time."
So I ordered french toast during the Renaissance. '
 - Steven Wright.
Download 'radballs.jpg' (20 KB)
Preview of image 'radballs.jpg'
Subject: Re: Another Rad (19Kbu)
Date: 27 Nov 2000 07:02:37
Message: <chrishuff-119162.07030927112000@news.povray.org>
In article <3a21f759@news.povray.org>, "Andy Cocker"
> over 8 hours! I've no idea why the huge difference... any ideas? The
> spheres are just a simple union of nested #while..#end loops.
Well, it takes a lot more computational work to check against hundreds
of spheres than to check against a couple boxes or planes. You might be
able to help with this by using a nested bounding structure, you know
what a quad-tree is? Basically, divide each wall of spheres into four
unions, bounded individually. Divide those unions further into four
each, bounded individually...etc. This will allow POV to skip testing
the bounding boxes for most of the spheres. You will have to tell POV
not to ignore your bounding, though, and you probably won't be able to
use while loops to generate the walls, though they would be easy to do
with a recursive macro.
Christopher James Huff
Date: 27 Nov 2000 08:19:18
Message: <3A225DFC.E99E61F1@my-dejanews.com>
> scene.
I for one "hate photorealism," but I too am so enamored by radiosity-using
scenes that I wonder what all those boring photorealistic scenes would look
like with a heavy dose of radiosity.
Date: 27 Nov 2000 09:40:29
Message: <3A227258.E82CEAD7@gmx.de>
Sounds like an interesting idea, i also had such problems in my recent
superellipsoid scene, i just wonder how much faster it would be (anyone
experience with such structures?)
Date: 27 Nov 2000 11:14:44
Message: <3A228874.F2E669B2@enst.fr>
	Lots, I already got a tenfold speed increase simply by adding an
individual bounding box for each line in a brick wall...
* Abandon the search for truth, * mailto:ber### [at] inamecom
* Settle for a good fantasy.    * http://www.enst.fr/~jberger
Date: 27 Nov 2000 14:17:30
Message: <3A22B33F.AEE3382E@gmx.de>
That sounds promising, i will probably give it a try.
Date: 27 Nov 2000 20:07:13
Message: <3a230541@news.povray.org>
"Andy Cocker" <big### [at] mariner9fsnetcouk> wrote...
> scene.
8
The primary reason is most likely that POV can't re-use as many radiosity
sample points.  It will have to take samples at more points because of the
curvature of the surfaces.  The "quality" of a sample point is determined by
how similar that point is to the current spot, looking at the position and
surface normal, among other factors.  If the point is not good enough for
the error_bound value, then more samples are taken, which slows things down.
When the surface normal changes a lot (like on a sphere), more samples have
to be taken.
More samples are also taken inside crevices, where diffuse lighting can
change drastically over a short distance.
This sample-reuse works best on flat surfaces, where the amount of diffuse
illumination doesn't change much from one point to the next.
-Nathan
