POV-Ray : Newsgroups : povray.binaries.images : parking garage radiosity, two views [~57K Jpg] Server Time
16 Jul 2026 17:32:09 EDT (-0400)
  parking garage radiosity, two views [~57K Jpg] (Message 1 to 10 of 13)
Subject: parking garage radiosity, two views [~57K Jpg]
Date: 23 Nov 2000 07:44:46
Message: <3a1d113e@news.povray.org>
This was what I was talking about before at the "My last radiosity plays" thread from
David Gemelli, after
having seen a parking garage lit by sun and sky and fluorescent lights when I woke up
after a short (ok, long)
nap in my truck at a shopping mall.
Needless to say this is probably never going to look the same as the Real Version TM.
I haven't put much effort into the modeling as of yet, mostly color and radiosity
adjusting.  The concrete is
only rgb 0.9 with ambient 0.15 and diffuse 2 (two) with some granite 0.01 for normal.
It's a rough draft, as you'll no doubt think too.
"David (I frequently see a wonderfull real effect I want to render but... I never have
a camera to take a
shot)"
I had taken film in to develop that day also but left the camera at home.  Thing is, I
never get a picture that
looks the same anyway.  This rendering is no different in that regard but it's better
than nothing at all.
omniVerse http://users.aol.com/persistenceofv/all.htm
Download 'parkinggarageradiosity.jpg' (42 KB)
Preview of image 'parkinggarageradiosity.jpg'
Subject: Re: parking garage radiosity, two views [~57K Jpg]
Date: 23 Nov 2000 07:59:44
Message: <3A1D1512.16F35051@xlstudio.com>
It looks great ! The top in the second view is excellent ! what is at the origin of
the rays ? lights ? sun ?
       David
Subject: Re: parking garage radiosity, always_sample on [~19K Jpg]
Date: 23 Nov 2000 08:28:45
Message: <3a1d1b8d@news.povray.org>
"gemelli david" <d.g### [at] xlstudiocom> wrote in message
news:3A1D1512.16F35051@xlstudio.com...
Hi again David.  I'd have to say radiosity settings are the cause, nothing else could
be.
It's awful really... the overly bright places at pillar joints, the lights don't have
correct "area"; but the
blotchiness helps texture the concrete.  There isn't any specular highlighting at all.
This is what I've been using:
global_settings {
assumed_gamma 2
max_trace_level 4
ambient_light <.9,.95,.99>*.0125
ini_option "+qr"
     radiosity {
       brightness 0.9
       count 123
       error_bound 0.15
       gray_threshold 0.1
       low_error_factor 0.4
       minimum_reuse 0.015
       nearest_count 3
       recursion_limit 1
always_sample off // on
pretrace_start .1
pretrace_end .01
This image attached here has always_sample on instead.  I don't think much change in
render time, unfortunately
I didn't keep statistics on the previous renders though.  This one (no AA) was about 3
minutes on a 500MHz
PIII.
Download 'pgr always_sample on.jpg' (14 KB)
Preview of image 'pgr always_sample on.jpg'
Date: 23 Nov 2000 10:00:30
Message: <3A1D310E.D75F217E@schunter.etc.tu-bs.de>
It looks good, i only wonder about a few things:
- the bright area behind the column seems a bit too strong to me, it
should be a bit brighter than the area around but not so strong IMO, but i
don't know how to influence this.
- The artificial lights seem quite bright in relation to the sunlight,
although i'm not so sure about that (the second view seems better under
this aspect)
Date: 23 Nov 2000 11:43:32
Message: <3A1D4944.601973D4@kivisalo.net>
Real world concrete is diffuse ~0.4. Diffuse 2 was used here which causes
this unnatural brightening. Think about it, perfect mirror is diffuse 1
in radiosity sense. assumed_gamma 1.0 would brighten the scene correctly
radiomertrically speaking.
______________________________________________________________________
Kari Kivisalo                                  http://www.kivisalo.net
Date: 23 Nov 2000 12:02:14
Message: <3A1D4DE9.BBB7C7CC@xlstudio.com>
0.4 ??? I always used 0.6 ! oups ! need to change this in my last scenes to see
the result... I'll post them again...
      David (very interested by this news)
Date: 23 Nov 2000 12:15:31
Message: <3A1D50C7.905B246C@kivisalo.net>
> the result...
That 0.4 was from a list describing "typical" reflectances. I bet there
are construction companies that do 0.6 concrete :)
Date: 23 Nov 2000 12:34:28
Message: <3A1D5525.6B852380@schunter.etc.tu-bs.de>
doesn't it also depend on the color or do you mean using color rgb 1 ?
Subject: new sphere with diffuse at 0.4
Date: 23 Nov 2000 13:32:03
Message: <3A1D62F4.4E2F9C4C@xlstudio.com>
I changed some details in order to make it better than the precedent one...
Diffuse change from 0.6 to 0.4 for the back is not a bad thing...
      David
Download 'metal_07.jpg' (25 KB)
Preview of image 'metal_07.jpg'
Date: 23 Nov 2000 14:30:04
Message: <3A1D7052.E0205600@kivisalo.net>
Yes. If the color is rgb 0.5 the diffuse should be 0.8.
