POV-Ray : Newsgroups : povray.binaries.images : parking garage radiosity, two views [~57K Jpg] Server Time
13 Jun 2026 22:17:44 EDT (-0400)
  parking garage radiosity, two views [~57K Jpg] (Message 4 to 13 of 13)
<<< Previous 3 Messages Goto Initial 10 Messages
Subject: Re: parking garage radiosity, two views [~57K Jpg]
Date: 23 Nov 2000 10:00:30
Message: <3A1D310E.D75F217E@schunter.etc.tu-bs.de>
It looks good, i only wonder about a few things:
- the bright area behind the column seems a bit too strong to me, it
should be a bit brighter than the area around but not so strong IMO, but i
don't know how to influence this.
- The artificial lights seem quite bright in relation to the sunlight,
although i'm not so sure about that (the second view seems better under
this aspect)
Date: 23 Nov 2000 11:43:32
Message: <3A1D4944.601973D4@kivisalo.net>
Real world concrete is diffuse ~0.4. Diffuse 2 was used here which causes
this unnatural brightening. Think about it, perfect mirror is diffuse 1
in radiosity sense. assumed_gamma 1.0 would brighten the scene correctly
radiomertrically speaking.
______________________________________________________________________
Kari Kivisalo                                  http://www.kivisalo.net
Date: 23 Nov 2000 12:02:14
Message: <3A1D4DE9.BBB7C7CC@xlstudio.com>
0.4 ??? I always used 0.6 ! oups ! need to change this in my last scenes to see
the result... I'll post them again...
      David (very interested by this news)
Date: 23 Nov 2000 12:15:31
Message: <3A1D50C7.905B246C@kivisalo.net>
> the result...
That 0.4 was from a list describing "typical" reflectances. I bet there
are construction companies that do 0.6 concrete :)
Date: 23 Nov 2000 12:34:28
Message: <3A1D5525.6B852380@schunter.etc.tu-bs.de>
doesn't it also depend on the color or do you mean using color rgb 1 ?
Subject: new sphere with diffuse at 0.4
Date: 23 Nov 2000 13:32:03
Message: <3A1D62F4.4E2F9C4C@xlstudio.com>
I changed some details in order to make it better than the precedent one...
Diffuse change from 0.6 to 0.4 for the back is not a bad thing...
      David
Download 'metal_07.jpg' (25 KB)
Preview of image 'metal_07.jpg'
Date: 23 Nov 2000 14:30:04
Message: <3A1D7052.E0205600@kivisalo.net>
Yes. If the color is rgb 0.5 the diffuse should be 0.8.
Date: 23 Nov 2000 19:33:43
Message: <chrishuff-EE3A2F.19341023112000@news.povray.org>
In article <3A1D4DE9.BBB7C7CC@xlstudio.com>, gemelli david
> scenes to see the result... I'll post them again...
It would vary quite a bit with the exact kind of concrete, whether it is
wet, how weathered it is, if it is freshly cut or broken, how dirty it
is, whether vehicles with rubber tires have driven on it...you get the
idea, the range definitely covers both 0.4 and 0.6. And the color also
affects the result...halving the color would require doubling the
diffuse.
Christopher James Huff
Date: 23 Nov 2000 23:57:04
Message: <p8tr1tc6rgd9foqea43v62a39p9stgqkb9@4ax.com>
On Thu, 23 Nov 2000 19:15:51 +0200, Kari Kivisalo <kar### [at] kivisalonet>
Any hint as of the location of this list? I am *very* interested.
Peter Popov ICQ : 15002700
Date: 24 Nov 2000 01:25:33
Message: <3A1E09F6.CB721BA5@kivisalo.net>
I don't remember where this short list was.
specular aluminum 95%,
new snow 74%,
concrete 40%,
vegetation (mean) 25%,
asphalt 7%.
From here you get the full spectral data for materials.
http://www.cs.utah.edu/~bes/graphics/spectra/
