POV-Ray : Newsgroups : povray.binaries.images : Somebody kick me (19kb jpeg) Server Time
15 Jul 2026 20:56:34 EDT (-0400)
  Somebody kick me (19kb jpeg) (Message 8 to 17 of 17)
<<< Previous 7 Messages Goto Initial 10 Messages
Subject: Re: sss buddha [16kb]
Date: 27 Nov 2003 13:40:14
Message: <3FC6450C.1040709@hotmail.com>
This is the mlPOV technique, yes? Whatever you did, it looks really
good! That buddha statue was just itching to be rendered this way!
Mael wrote:
> Cool effect ! I had to try it on the happy buddha :)
> M
Samuel Benge
stb### [at] hotmailcom
See my website@: http://www.goldrush.com/~abenge/Top/index.html
Date: 27 Nov 2003 23:20:01
Message: <web.3fc6cbc7e7c0a33498a934b40@news.povray.org>
>M
indeed.
my first thought was that this could be used to simulate
a translucent jade.
this is way beyond me so i have a couple of questions ...
am i to understand that this particular method of samual's
requires mlpov? i haven't been able to run it with ver 3.5.
and ...
i have been trying to obtain this 'happy buddha'
file but see that it is in "lv" and some other format.
how is it possible to convert these to POV?
or is there somewhere i can find them converted ...
to what ... 'mesh' ?
tia for any leads and help.
ts
Date: 28 Nov 2003 00:22:51
Message: <3FC6DBA6.4020906@hotmail.com>
> and ... <break>
There are currently two versions of this technique I have posted to the
newsgroups. The official 3.5 version is in povray.binaries.scenes-files.
The mlPOV version is the one residing in the body of text at the
beginning of this thread.
Samuel Benge
Date: 28 Nov 2003 14:16:58
Message: <3fc79f2a@news.povray.org>
Looks fantastic. I have been trying to do something similar to another mesh2 object I
have
(outputted from Silo), but I can't figure out how to apply the code to the mesh2
object. It's
like a chicken and egg situation that I can't get my head around: The mesh2 object
requires a
texture in its list, but the SSS method refers to the object (my mesh) in the texture
definition. Does that make sense?
Could you post how you applied the SSS to the buddha Mael?
TIA,
Andy Cocker
"Mael" <mae### [at] hotmailcom> wrote in message news:3fc63af3@news.povray.org...
> M
Date: 28 Nov 2003 14:29:04
Message: <3fc7a200@news.povray.org>
#declare buddha = object { #include "../models/buddha_r2.inc" rotate 120*y
scale <35,35,35> translate -3*y }
object {
  buddha
  pigment{ average
   pigment_map{
    #local V=0;
    #while(V<100)
     [1 projection buddha , lpos1 blur .2,10
      translate<rand(R)-rand(R),rand(R)-rand(R),rand(R)-rand(R)>*1.5
      color_map { [0 rgb <.5,1,.5>][1 rgb 0] }
     #local V=V+1;
  finish { diffuse .2 ambient .9 specular .5 roughness .05 }
Date: 28 Nov 2003 14:29:21
Message: <3fc7a211$1@news.povray.org>
I downloaded it, a long time ago, from
http://www.cc.gatech.edu/projects/large_models/ and converted the ply format
to a mesh2 (AFAIR the conversion was quite straightforward)
M
Date: 28 Nov 2003 14:40:34
Message: <3fc7a4b2@news.povray.org>
Hi Mael,
Thanks for your prompt reply. Unfortunately I'm still having the same problem in that
the only
texture showing up on the model is that which is specified in the mesh2 texture_list:
texture_list {
  1,
  texture { Material0 }
I don't know how to overide this texture and make it use the SSS. Does your Buddha
model have
this texture_list entry?
Andy Cocker
"Mael" <mae### [at] hotmailcom> wrote in message news:3fc7a200@news.povray.org...
> object {
>   buddha
>   pigment{ average
>    pigment_map{
>     #local V=0;
>     #while(V<100)
>      #local V=V+1;
>     #end
Date: 28 Nov 2003 15:35:01
Message: <web.3fc7b0c2e7c0a3345d051a070@news.povray.org>
>M
that's what i need to know ...
here: http://www.cc.gatech.edu/projects/large_models/happy.html
it comes in both the ply and iv formats ... each around 10MB.
so i am wondering which to d/l ... and what utility can i use to
convert the ply or iv formats?
so far i haven't found any converters which mention either.
and please understand ... i am a newbie to meshes ...
so assume i know nothing and you will be correct. ;)
i hope to rectify that with a little help from all you pov heavies.
thanks for any leads.
-ts-
Date: 28 Nov 2003 15:56:55
Message: <+db8oDAW$6x$EwKu@econym.demon.co.uk>
Wasn't it Andy Cocker who wrote:
>Hi Mael,
>that the only
>texture_list:
>texture_list {
>  1,
>Buddha model have
The texture_list is optional, but if it's not there you have to remove
the texture number from each entry in the face_indices section.
At first glance, you might think that it might be tedious to remove the
texture numbers from the face_indices section, but it may well be
possible to perform Search->ReplaceAll of ">,1," with ">," and then just
edit the last one manually.
Mike Williams
Gentleman of Leisure
Date: 28 Nov 2003 16:39:39
Message: <3fc7c09b@news.povray.org>
"Mike Williams" <nos### [at] econymdemoncouk> wrote in message
news:+db8oDAW$6x$EwKu@econym.demon.co.uk...
Thanks Mike, that worked. I had already tried removing all UV references along with
the
texture_list section, but was coming up with an error regarding the face_indices.
Using your
tip I got it to work.
Thanks again,
Andy Cocker
