POV-Ray : Newsgroups : povray.binaries.images : Subsurface Scattering, 2nd image (43kb jpeg) Server Time
14 Apr 2026 05:43:54 EDT (-0400)
  Subsurface Scattering, 2nd image (43kb jpeg) (Message 11 to 19 of 19)
Subject: Re: Subsurface Scattering, 2nd image (43kb jpeg)
Date: 26 Nov 2003 11:27:49
Message: <3fc4d485$1@news.povray.org>
Samuel Benge wrote:
> I don't plan on keeping it a secret for too much longer.....
When :-))) ?
Date: 26 Nov 2003 11:30:30
Message: <3fc4d526@news.povray.org>
"Samuel Benge" <sbe### [at] hotmailcom> wrote in message
news:3FC### [at] hotmailcom...
Are you using scaled copies of the object in relation to the light
source in order to build some type of illumination map?
Very nice effect.
-Shay
Date: 26 Nov 2003 12:00:01
Message: <web.3fc4db83e15d54f0b4c392b30@news.povray.org>
ok,
my second guess is a mixture of aoi (if accurate) and proximity pattern
Norbert.
Samuel Benge wrote:
>Here's another test image for the subsurface scattering sim I'm
>developing in POV 3.5. Does the object look transparent? It's not.
>No aa on this one, because it's getting late.
>Samuel Benge
>stb### [at] hotmailcom
>See my website@: http://www.goldrush.com/~abenge/Top/index.html
Date: 26 Nov 2003 12:19:46
Message: <3FC4E0B1.7000400@hotmail.com>
Your first guess was much closer, except I didn't use mlPOV... although
I believe it could be used to produce a similar result by using a
slightly different method.
Your proximity pattern guess is close as well.
Norbert Kern wrote:
> ok,
> Norbert.
Samuel Benge
Date: 26 Nov 2003 12:24:39
Message: <3FC4E1D4.60700@hotmail.com>
I thought somebody might guess that, but it isn't the case. Such a
design would be kind of hard to implement because the scaling direction
might be hard to align with the direction of the light_source.
While the surface is taken into account, it is only used as a reference,
and not as an illumination map.
> Very nice effect.
> -Shay
Samuel Benge
Date: 26 Nov 2003 13:25:01
Message: <web.3fc4efb9e15d54f03a02ccab0@news.povray.org>
my third guess:
two pass render:
1. blurred b/w image
2. first render used as image_pattern for a texture with high ambient values
according to brighter parts of the first render and ambient zero for
shadowed parts.
That should explain some artefacts.
Norbert
>Norbert Kern wrote:
>> ok,
>> Norbert.
>Samuel Benge
Date: 26 Nov 2003 14:36:56
Message: <3FC500D6.6090500@hotmail.com>
Good guess, but Christoph Hormann has guessed correctly. See the
original Tuesday Mystery thread.
Norbert Kern wrote:
> my third guess:
> two pass render:
> shadowed parts.
> Norbert
Samuel Benge
Date: 26 Nov 2003 18:25:47
Message: <3fc5367b@news.povray.org>
That's gorgeous!
please don't wait too long to post the source.
Bill Hails
Date: 27 Nov 2003 02:13:58
Message: <3fc5a436$1@news.povray.org>
There is a long time i try to do a thing like that.....
Bravo
Friendly
Sylvain
> Samuel Benge
