![](/i/fill.gif) |
High!
ingo schrieb:
> Open the images with The Gimp. Use for example select by colour to select
> the calligraphies. Then selection to path, save the path. You can use my
> little Python script gimppath2pov to convert the points of the path to an
> array that can be used by POV-Ray as a bezier spline.
> http://members.home.nl/seedseven/#gimpov
This would run only under Linux, wouldn't it? I'm not familiar at all with
Python, if I remember well, it's a purely interpreted language, so I wouldn't
have to compile the script... or am I wrong?
See you in Khyberspace - http://home.arcor.de/yadgar/khyberspace/index-e.html
Afghanistan Chronicle: http://home.arcor.de/yadgar/index-e.htm
Home-made electronic music: http://home.arcor.de/yadgar/music/
Yadgar
![](/i/fill.gif) |
