POV-Ray : Newsgroups : povray.binaries.images : Capriccio18 Server Time
14 Jul 2026 00:51:48 EDT (-0400)
  Capriccio18 (Message 13 to 22 of 22)
Subject: Re: Capriccio18
Date: 18 Jun 2003 10:55:11
Message: <3ef07d4f$1@news.povray.org>
3EF07413.1D11AC50@mail.com...
> Thanks for hints Gilles!
I came upon the same problem some years ago but at this time the tiles were
made with CSG so making large roofs with them was out of the question due to
speed and RAM limitation... and texturing every tile didn't help!
> I'll try to modify the macro.
When I think of it, there could be a separate version of the macro that
would create the entire roof, or at least a half roof, as a single mesh. It
would take longer to parse, but the same roof (preferably saved as an *.inc
file) could be used over and over (like grass patches) which would be great
for some types of city pictures.
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 18 Jun 2003 11:10:39
Message: <3EF07F09.DE9B7261@mail.com>
I modified the macro (source in p.b.s.-f.). Cells pattern is in use
and there is only one texture for the whole roof now. But the
memory still grows. I suspect something is wrong with declarations
just cannot realize what :)
That's a good idea about one mesh. I'll try to do that. Though
it's not so useful for current scene it can be useful for somebody
else in the future :)
Gena.
Date: 18 Jun 2003 11:20:33
Message: <3EF08341.C231B62F@gmx.de>
Gena Obukhov wrote:
> I've created the macro for making tile roof.
> Each tile is a mesh but it doesn't work as I expected.
> Whenever I increase the number of tiles allocated
> memory is increasing too. I'm just wondering
> what's wrong? The source is in p.b.s.-f.
Looks good (so does the 'version 18', i'm a bit late with my comments at
the moment...).  For rendering efficiency it would be better to put
several tiles (like a whole row) in one mesh.  This would cost more memory
but it would render faster.
Last updated 17 Jun. 2003 _____./\/^>_*_<^\/\.______
Date: 18 Jun 2003 11:45:54
Message: <3ef08932$1@news.povray.org>
3EF07F09.DE9B7261@mail.com...
> But the
I guess it's normal, as memory is allocated to each tile anyway, I suppose
for positionning and such (I'll let programmers tell you exactly what
happens). Increase the number of faces and you will see that the RAM use
doesn't change much for a given number of tiles, which proves that
instanciation works correctly.
Note that an additional benefit of using a single mesh is that you'll be
able to use the same mesh for both panes, thus cutting RAM use in half.
G.
- Posters
Date: 18 Jun 2003 13:23:08
Message: <3EF09FFF.FD3C73A6@mail.com>
Txemi Jendrix is making boats for this scene and we need
textures for those boats, ideally for UV-mapping. As far
as I know he is using Hamapatch. What's the best way to
make such UV textures in this case?
Should he save model in OBJ format and using UVMapper
to make that UV template? What kind of template does
UVMapper produce? Is it rectangular image? Is there any
need in using warping software for making such texture?
Gena.
Date: 18 Jun 2003 13:28:34
Message: <3EF0A141.796F425F@gmx.de>
I think the wood textures of the boats should best be procedural, this
would require a good 'design' of the uv-coordinates so the grain of the
wood parts is oriented in a realistic way.
Date: 18 Jun 2003 13:51:16
Message: <3EF0A697.4B8550B4@mail.com>
How can we produce those uv-coordinates? Through UVMapper (I've never
used it before)?
Gena.
Date: 18 Jun 2003 13:55:36
Message: <3EF0A79C.DA1A4CD1@mail.com>
BTW, can we use the cloth patch for POV-Ray for
making sails for some of those boats? Is it easier than
modeling it in Hamapatch?
Gena.
> Christoph
> POV-Ray tutorials, include files, Sim-POV,
> HCR-Edit and more: http://www.tu-bs.de/~y0013390/
Date: 18 Jun 2003 15:30:37
Message: <3ef0bddd@news.povray.org>
3EF0A697.4B8550B4@mail.com...
> used it before)?
I don't use Hamapatch, but UVMapper can do a pretty good job. For instance
the car here :
http://www.oyonale.com/iss/english/museum_07.htm
was uvmapped with it from a mesh that didn't any uv info at first.
I'm using the Pro version though, because the free one has too many
limitations for this sort of job.
G.
- Posters
Date: 18 Jun 2003 20:11:38
Message: <3EF0FFBD.5768EFF5@mail.com>
About speed. It's very slow when it's used in CSG. Is there any way to
improve that? Should I use bounded_by? If so, where - tile, roof or
result of CSG?
Gena.
