POV-Ray : Newsgroups : povray.binaries.images : Gradient problem Server Time
1 Jan 2026 16:02:50 EST (-0500)
  Gradient problem (Message 1 to 4 of 4)
Subject: Gradient problem
Date: 13 Jun 2003 21:24:25
Message: <3EEA7949.5010909@hotpop.com>
   I have a background image that I would like to darken at some place
to change the final elevation of a resulting heightfield.
I decided to use triangles (because the data that creates the shape is
suitable for triangles).  When I want the color to be exactly the
background I specify my triangle's Z coord to be 0.5 and when I want the
color to be totally black I set Z to 0.
Then I use a gradient to colorize the elevation of my triangles, like so:
  gradient z
  color_map {
    [0.0 color rgbf <0,0,0,1>]
    [0.5 color rgbf <1,1,1,1>]
Now, I've tried with rgbt, with any kinds of values and I don't seem to
get a good result.
If you look at my image you will see like a pair of lips; that is you
see it gets lighter at the extremities and when going to the center it
finally gets dark.
I would like it to be the color of the bg at the extremities and simply
darken towards the center.
BTW, center is rgbf <0,0,0,1> and the extremities of the "lips" are at
rgbf <1,1,1,1>
What should I do to avoid the "lips" problem?
Thanks,
   Xilo
Dedicated to audio/visual and interactive artwork.
http://www.geocities.com/simonlemieux/
Subject: Gradient problem (Image)
Date: 13 Jun 2003 21:27:06
Message: <3EEA79EA.2080504@hotpop.com>
Sorry, here's the example image.
Download 'test.jpg' (1 KB)
Preview of image 'test.jpg'
Subject: Re: Gradient problem (Image)
Date: 13 Jun 2003 21:54:51
Message: <3eea806b@news.povray.org>
Well that is the error you'd get if you used rgbt <0,0,0,0> and rgbt <1,1,1,1>,
because halfway between the two you'd get a grey colour... But I can't explain
why it would happen with rgbf.
Personally I always use transmit because it behaves like alpha blending, which I
understand better than filtering. For the effect you want you could just use
rgbt <0,0,0,0> and rgbt <0,0,0,1>. But you probably know that already.
Sorry I could be much help :(
Tek
http://www.evilsuperbrain.com
Date: 13 Jun 2003 22:26:54
Message: <3EEA87EF.3090005@hotpop.com>
Hehehe, from the time I posted and now I haven't stopped trying anything
possible and finally came to the same conclusion as you...
I now use rgbt <0,0,0,0> and rgbt <0,0,0,1> and it works perfectly!
Now I just have to arrange my data and I'll post an image of what it
looks like!
Thanks,
   Xilo
