POV-Ray : Newsgroups : povray.binaries.images : GL SkySphere Server Time
12 Nov 2026 22:17:17 EST (-0500)
  GL SkySphere (Message 11 to 20 of 20)
<<< Previous 10 Messages Goto Initial 20 Messages
Subject: Re: My GL SkySphere (~120kbu) (Was: GL SkySphere)
Date: 16 May 2003 08:39:35
Message: <3ec4dc07$1@news.povray.org>
"Xilo Musimene" <xil### [at] hotpopcom> schreef in bericht
news:3EC### [at] hotpopcom...
> I've read your code and you seem to have only 16^2 polygons for your
> skySphere, am I right?  Well, I have 10^2, it might explain the
> jaggyness, but I do believe my code is not as optimal as yours! =)
You can get 'perfect' results (without any jaggyness) if you use a skybox
instead of a skysphere.  It's a little bit more complicated to make suitable
skybox-textures, but the results are faster and better.
cu!
Date: 16 May 2003 21:10:06
Message: <3EC58BEE.1030108@hotpop.com>
I've been thinking about this and probably I should need to make 6
images for the skybox, right?  Or should I still use the exact same
spherical camera I just used...?
Thanks,
   Xilo
Dedicated to audio/visual and interactive artwork.
http://www.geocities.com/simonlemieux/
Date: 16 May 2003 21:11:25
Message: <3EC58C3D.2020103@hotpop.com>
>   If I didn't want you to use my code, I wouldn't have posted it in the
> first place (I would have just said what I did).
Good! =)
   Then you will probably see a new EyeCandy on my website in a week or two!
Thanks!
   Xilo
Date: 16 May 2003 21:37:38
Message: <3ec59262@news.povray.org>
skybox
suitable
no, a spherical camera won't work (at least, I don't think it will :), you
will have to make 6 perspective-views.
I did it once, maybe it's still available online, let me check :)
It *might* be this: http://sad.studentenweb.org/cg/stad.zip
But I don't know if it is just the source, or if it is compiled, or whatever
good luck anyway :)
cu!
ZK AKA SaD
http://www.povplace.be.tf
"I'm spinning!"
Date: 17 May 2003 07:56:56
Message: <3EC62388.4010302@hotpop.com>
I found it in your zip file:
     void setSkyBox(GLuint texture,GLfloat helderheid){
         glDisable(GL_LIGHTING);
         glDisable(GL_CULL_FACE);
         glBindTexture(GL_TEXTURE_2D,texture);
         gluLookAt
(0.0,0.0,0.0,_lookat.getX()-_locatie.getX(),_lookat.getY()-_locatie.getY(),_lookat.getZ()-_locatie.getZ(),_up.getX(),_up.getY(),_up.getZ());
         glColor4f(helderheid*2,helderheid*1.5,helderheid,1.0);
         glBegin(GL_QUADS);
             // Top
             glTexCoord2f(1.0/4.0,1.0/3.0); glVertex3f(-1.0,1.0,-1.0);
             glTexCoord2f(0.0/4.0,1.0/3.0); glVertex3f(1.0,1.0,-1.0);
             glTexCoord2f(0.0/4.0,2.0/3.0); glVertex3f(1.0,1.0,1.0);
             glTexCoord2f(1.0/4.0,2.0/3.0); glVertex3f(-1.0,1.0,1.0);
             //Left
             glTexCoord2f(2.0/4.0,2.0/3.0); glVertex3f(-1.0,-1.0,1.0);
             glTexCoord2f(2.0/4.0,1.0/3.0); glVertex3f(-1.0,-1.0,-1.0);
             //Right
             glTexCoord2f(4.0/4.0,2.0/3.0); glVertex3f(1.0,1.0,1.0);
             glTexCoord2f(4.0/4.0,1.0/3.0); glVertex3f(1.0,1.0,-1.0);
             glTexCoord2f(3.0/4.0,1.0/3.0); glVertex3f(1.0,-1.0,-1.0);
             glTexCoord2f(3.0/4.0,2.0/3.0); glVertex3f(1.0,-1.0,1.0);
             // Far
             glTexCoord2f(2.0/4.0,3.0/3.0); glVertex3f(-1.0,1.0,1.0);
             glTexCoord2f(3.0/4.0,3.0/3.0); glVertex3f(1.0,1.0,1.0);
             // Near
             glTexCoord2f(2.0/4.0,0.0/3.0); glVertex3f(-1.0,1.0,-1.0);
             glTexCoord2f(3.0/4.0,0.0/3.0); glVertex3f(1.0,1.0,-1.0);
             //Bottom
         glEnd();
         glColor4f(1.0,1.0,1.0,1.0);
         glEnable(GL_LIGHTING);
         glEnable(GL_CULL_FACE);
         glLoadIdentity();
But I don't really understand what texture you used...  Did you paste
the six images toghether in one?
Thanks,
   Xilo
Date: 17 May 2003 10:09:07
Message: <3ec64283$1@news.povray.org>
>          gluLookAt
>          glBegin(GL_QUADS);
>              // Top
>              //Left
>              //Right
>              // Far
>              // Near
>              //Bottom
>          glEnd();
>          glLoadIdentity();
Yes. I used a texture similar to
http://www.turbosquid.com/Previews/Content_on_4_26_2003_07_30_53/1-5-flat.jp
I believe the texture I used, is included in the zip, probably skybox.raw (I
believe it's 1024*1024*24bit, RGB, no header).  If it's not included, you
can download it here: http://sad.studentenweb.org/cg/skyboxzonderflare.raw
(3MB!!)
cu!
ZK AKA SaD
"Train you will I. Train you I will. Yes! Step one: touch your tongue to
mine."
Date: 18 May 2003 07:34:14
Message: <3EC76FBB.5040406@hotpop.com>
> (3MB!!)
Ok, now I understand...
But, this takes twice Video RAM as it should...  the white squares are
also on the VRAM and I think it would be more optimised to use 6
different square textures...
And I was wondering what exact kind of camera you used?
Simply a normal camera with angle of 90?
Thanks,
   Xilo
Date: 18 May 2003 09:00:25
Message: <3ec783e9@news.povray.org>
it would probably indeed be more efficient if you used 6 different textures
instead of 1 big, and possibly even easier, but I had to do this very
quickly (school-reasons :) and I didn't think of that :)
I believe so, yes... Let me check! :)
hmm, I don't have the POV-file here, sorry :-/
cu!
ZK AKA SaD
"I won't bite... hard."
Date: 18 May 2003 20:57:10
Message: <3EC82BE6.6030507@hotpop.com>
Good!
Anyway, it's not a big problem, it's not like if there were thousand
kinds of cameras!
I'll do some tests whenever I have the time!...
Thanks a lot!
   Xilo
Date: 19 May 2003 07:25:54
Message: <3ec8bf42$1@news.povray.org>
> kinds of cameras!
ok, good luck! :)
> Thanks a lot!
np :)
cu!
ZK AKA SaD
"He can breathe OK, long as nobody unplugs him"
