POV-Ray : Newsgroups : povray.binaries.images : Sibenik Server Time
22 Dec 2025 07:10:15 EST (-0500)
  Sibenik (Message 1 to 9 of 9)
Subject: Sibenik
Date: 7 Apr 2003 19:22:47
Message: <3E920836.98E50C14@luxlab.com>
I was testing a ligting setup and it came out pretty good.
The model and image maps from hdri.cgtechniques.com/~sibenik2/
1 light source and ambient sky dome. save_data with error_bound 0.05
and final with error_bound 0.2.
Findings.
Clipped radiosity samples are only an annoyance. The 2nd image
demonstrates this effect when the scene is rendered directly to
display. I used sorcery to get nonclipped radiosity from std 3.5.
1600 samples isn't enough to gather smooth illumination from sources
with small solid angle.
Radiosity ignores brilliance finish parameter. Not that important
but would add that extra touch of realism.
_____________
Kari Kivisalo
Download 'test_load_normal2.jpg' (177 KB) Download '1_1.jpg' (18 KB)
Preview of image 'test_load_normal2.jpg'
Preview of image '1_1.jpg'
Subject: Re: Sibenik
Date: 7 Apr 2003 19:40:15
Message: <3e920c5f$1@news.povray.org>
Wow that looks totally awesome!
Somehow it doesn't look real, but looks like a really amazing painting, or
something. In any case I like it!
I particularly like the way the light seems to bleed where it hits objects
directly, is that just radiosity or some sort of post processing effect?
Tek
http://www.evilsuperbrain.com
Date: 7 Apr 2003 20:47:38
Message: <5essbfgon5mc$.tkcypxxz715u$.dlg@40tude.net>
Wow. The whole contrast and beauty of this image is amazing! Sometimes it's
better if it's not quite photorealistic but rather a kind of
"superrealistic" that you could only see in your dreams or art.
BTW, is your "sorcery" a secret? Or did you scale down the brightness to
within the 0 1 range and postprocess? I wouldn't call it cheating if it was
only used to avoid a titanic oversight in the radiosity engine. :-T
light_source#macro G(E)sphere{z+E*y*5e-3.04rotate-z*E*6pigment{rgbt#end{
20*y-10#local n=162;1}#while(n)#local n=n-.3;G(n)x}}G(-n).7}}#end//GregE
Date: 8 Apr 2003 02:00:24
Message: <web.3e9264a5c028329751dec8010@news.povray.org>
You can avoid the postprocess.  Just wrap a tiny sphere around the camera
with the following attributes:
  pigment {rgbf <BRIGHTNESS,BRIGHTNESS,BRIGHTNESS,1>}
  finish {ambient 0 diffuse 0}
  no_shadow no_reflection hollow
....and the brightness of each pixel will be multiplied by BRIGHTNESS.  So
set BRIGHTNESS to 20 or so, divide all your lights' colors by BRIGHTNESS,
and you get a nice image.  Radiosity seems to get slower as BRIGHTNESS
increases, though.
Date: 8 Apr 2003 03:00:47
Message: <3e92739f@news.povray.org>
if you're patient enough to do some tests with values > 1600 you can try my
halton patch (http://195.221.122.126/tmp/mlpov83-win-bin.zip or the full
package http://195.221.122.126/mlpov83.zip) , just add
#version unofficial mlpov 0.82;
and by adding the keyword "halton" in the radiosity options you can use
count > 1600
M
Date: 8 Apr 2003 03:29:21
Message: <3E927A51.BACE50A9@gmx.de>
Very nice.
Must take quite long to render...
> Findings.
Both problems will be fixed in next MegaPOV.  I guess the 'sorcery' means
rendering on a lower lighting level and adjusting afterwards.
Last updated 28 Feb. 2003 _____./\/^>_*_<^\/\.______
Date: 8 Apr 2003 08:05:39
Message: <3e92bb13$1@news.povray.org>
Nice to see another POV trace of that building. What strikes me is the huge
difference in render-time between different raytracing engines. Most of them
are able to make it look great - but not similar to each other - the
differene is however, the render time... and POV doesn't seem to perform too
fast.
Hugo
Date: 9 Apr 2003 16:39:16
Message: <3E9484EF.7616887C@luxlab.com>
> painting, or something.
The scene would not look like this when viewed directly or in a
normal photograph. The goal was to make a record of the HDR light
levels for reference purposes. Maybe this is why the dreamy/painterly
look.
The glow effect for the hot spots seemed appropriate as their
brightness is about 10000%. Some of it is bound to spill over :)
Generating the radiosity data took 12 hours on XP 2100.
_____________
Kari Kivisalo
Date: 9 Apr 2003 19:59:30
Message: <3e94b3e2$1@news.povray.org>
I have a set of 32000 samples here: http://24.132.254.156/raddist7_32000.zip
. The file contains c-code and .inc POV-Ray code. The XYZ-samples are
normalized non-integer values so the "resolution" of the values is higher
than the shorts of the official version. I'm just to lazy and weary of
compiling POV-Ray now, because there is a 50% chance or something like that
for crashing my system when I try compiling.
