POV-Ray : Newsgroups : povray.binaries.images : [WIP] Cornell's Room Server Time
13 Sep 2025 05:34:57 EDT (-0400)
  [WIP] Cornell's Room (Message 1 to 10 of 10)
Subject: [WIP] Cornell's Room
Date: 5 Jan 2003 20:32:14
Message: <3E18DC98.8010507@yahoo.com>
We've all seen "Cornell's Box," the radiosity thing with the green
white, and red walls etc... I decided to expand on that and give him a
drop-in ceiling, a bed, chest of drawers and a table.
There's only one problem though- I've been tinkering with the settings
and the radiosity isn't very well done. I mean, the red and green don't
reflect enough of the light. Could someone suggest better settings? At
the time they are:
pretrace_start 0.1             pretrace_end   0.05
count 250                      error_bound 1.8
nearest_count 15               minimum_reuse .05
low_error_factor .05           recursion_limit 2
gray_threshold 0.0             brightness 1.5
Thanks in advance.
Download 'cornell-room.png' (407 KB)
Preview of image 'cornell-room.png'
Subject: Re: [WIP] Cornell's Room
Date: 6 Jan 2003 06:17:49
Message: <Xns92FB7CDFAEDE2raf256com@204.213.191.226>
Scottish the pig <sco### [at] yahoocom> wrote in
news:3E1### [at] yahoocom
> error_bound 1.8
1.0 and 0.4 for final trace
> recursion_limit 2
3, and 4 or 5 for final trace
> brightness 1.5
i always use 1.0
and most important - modify textures in scenes
a) set higher diffuse i.e. 0.9
b) set ambient to 0.0
  default { finish { ambient 0 diffuse .9 } }
and set assumed_gamma to 1.9 or even 1.5
Date: 6 Jan 2003 14:06:41
Message: <3E19D3BA.3040900@yahoo.com>
> the time they are:
> Thanks in advance.
Still need some help- the ceiling looks a lot better now, but there are
plenty of oddities as well- like the artifacts on the walls.
Download 'cornell-room.png' (483 KB)
Date: 6 Jan 2003 16:25:54
Message: <3e19f462@news.povray.org>
"Scottish the pig" <sco### [at] yahoocom> wrote in message
news:3E1### [at] yahoocom...
Please don't post such large files. Some of us are stuck at work with ISDN
connections.
 -Shay
Date: 6 Jan 2003 16:50:58
Message: <MPG.18840b4aa8f7be42989c5b@news.povray.org>
> connections.
*Some* of us are stuck with 56k modems at home...
Jamie.
Date: 7 Jan 2003 05:35:27
Message: <m9bl1v8b8geuq1mml7l958oer5ffs2i0gl@4ax.com>
On Mon, 6 Jan 2003 21:53:51 -0000, Jamie Davison
And some still use 33.6 modems which connect at 26.4... and yet have
the whole news.povray.org archive :)
Peter Popov ICQ : 15002700
Date: 7 Jan 2003 08:57:25
Message: <MPG.1884edcdd4e442e6989c5c@news.povray.org>
Well, I *say* a 56k modem, but it only connects at 38.6k :)
Jamie.
Date: 7 Jan 2003 15:20:59
Message: <3e1b36ab$1@news.povray.org>
Shouldn't you always use 1.0, if you want realistic results?
Anders
#macro E(D)(#if(D<2)D#else#declare I=I+1;mod(pow(.5mod(I 6))*asc(substr(
"X0(1X([\\&Q@TV'YDGU`3F(-V[6Y4aL4XFUTD#N#F8\\A+F1BFO4`#bJN61EM8PFSbFA?C"
I/6 1))2)<1#end)#end#macro R(D,I,T,X,Y)#if(E(D))R(D-1I,T,Y/2X)R(D-1I,T+Y
/2Y/2X)#else box{T T+X+Y pigment{rgb E(2)*9}}#end#end R(10,5z*3-1v*2u*2)
Date: 7 Jan 2003 16:49:12
Message: <Xns92FCE7EE444D7raf256com@204.213.191.226>
> error_bound 1.8
as I said before, error bound is WAY to big, it should be 0.5 or smaller,
did You read my post ?
Date: 8 Jan 2003 15:04:38
Message: <cjameshuff-05306F.14544908012003@netplex.aussie.org>
In article <m9bl1v8b8geuq1mml7l958oer5ffs2i0gl@4ax.com>,
In a way, you are better off than me...56k at 26.4. And no archive.
http://tag.povray.org/
