POV-Ray : Newsgroups : povray.binaries.images : One for the Linux Heads (27k) Server Time
28 Oct 2024 07:18:15 EDT (-0400)
  One for the Linux Heads (27k) (Message 1 to 6 of 6)
Subject: One for the Linux Heads (27k)
Date: 26 Nov 2002 07:59:36
Message: <3DE36E2B.40009@webone.com.au>
I really only did this cause I like the look of my icecube.
It looks a bit cartoonish but hey. I need to add drips and stuff to make
it look real, but the ones I tried on detracted from it.
It's povray 3.5 + gimp to stick on the text.
The cube is your basic isosurface noise3d cube. As is obvious, it's all
pretty simple stuff.
What do you think ?
Cheers,
  - Justin
Download 'lunix.jpg' (27 KB)
Preview of image 'lunix.jpg'
Subject: Re: One for the Linux Heads (27k)
Date: 26 Nov 2002 08:59:07
Message: <20021126192824.585b8002.kedarDELETE_THIS@patilkedar.com>
On Tue, 26 Nov 2002 23:50:51 +1100, Justin Higgins typed
something like this:
> What do you think ?
I think if you can do the drips and splashes of water on the
table, it will be nice.
I also like it as it is, though.  Render a nice large version and
ask the KDE* team to bundle that wallpaper with their next
release.  Seriously!
(Or do they have similar wallpaper already?  I haven't used KDE
for a while.)
-Kedar
* No bias for KDE.  Any other Linux DE should also be fine.
Date: 26 Nov 2002 09:39:59
Message: <Xns92D29ED3EF97Draf256com@204.213.191.226>
Justin Higgins <jhi### [at] webonecomau> wrote in
news:3DE### [at] webonecomau
Nice effect :) Try adding some turbulence to table pigment maybe
Date: 26 Nov 2002 11:06:30
Message: <3de39c06$1@news.povray.org>
Me too.
Just tree or four drops on the table?
How about adding an alpha channel to the Tux image map. This way
you could fake Tux to be a "real" figure and not just an image on a
white piece of paper. Doing so should be no problem with the Gimp.
> What do you think ?
And yes, a little work on the table texture would also be fine.
just my 2ct
-Ive
Date: 26 Nov 2002 22:38:06
Message: <3de43e1e$1@news.povray.org>
Dear Justin,
 Wonderful. The  bubbles are also really nice looking!
If you don't mind, I'd like to know how you did the bubbles inside the cube.
Jong
"Justin Higgins" <jhi### [at] webonecomau> wrote in message
news:3DE### [at] webonecomau...
> Hi,
Date: 27 Nov 2002 04:09:25
Message: <3DE489BC.6000400@webone.com.au>
Thanks,
The bubbles are pretty simple, here is the code for the whole cube:
intersection {
   isosurface {
       function {
f_rounded_box(x,y,z,0.05,1,1,1)-f_noise3d(x*1.9,y*2.2,z*1.9)*0.2}
        contained_by { box {<-10,-10,-10><10,10,10>} }
        accuracy 0.01
       threshold 0
        max_gradient 1.34
#local seedvar = seed (14);
#local nbub = 0;
#while (nbub < 150)
   sphere {
<((rand(seedvar)-0.5)*1.8),((rand(seedvar)-0.5)*1.8),((rand(seedvar)-0.5)*1.8)>,rand(seedvar)*0.08
inverse}
   sphere {
<((rand(seedvar)-0.5)*.8),((rand(seedvar)-0.5)*.8),((rand(seedvar)-0.5)*.8)>,rand(seedvar)*0.03
inverse}
   #local nbub = nbub + 1;
   texture { pigment { Col_Glass_General } finish { F_Glass6 } normal {
bumps 0.1 scale 0.2 } }
   interior { I_Glass1  }
     photons {
       target
       refraction on
       reflection on
        rotate <0,3,0>
        translate <0,1.1,4>
Cheers,
  - Justin
Jong wrote:
> Dear Justin,
> Jong
>>Hi,
