POV-Ray : Newsgroups : povray.binaries.images : Odd Focal Blur Effect (from p.g) Server Time
24 Jun 2026 08:35:48 EDT (-0400)
  Odd Focal Blur Effect (from p.g) (Message 1 to 10 of 12)
Subject: Odd Focal Blur Effect (from p.g)
Date: 22 Aug 2002 09:40:55
Message: <3D64EA58.40E092FC@aol.com>
Here is the image exhibiting the unexpected (but not unwelcome) focal
blur effect. Normally, I would expect a circular region of clarity with
blurring around it. In this case, there is a horizontal swath of "in
focus" area, with the blurring above and below:
Download 'oddblur.jpg' (44 KB)
Preview of image 'oddblur.jpg'
Subject: Re: Odd Focal Blur Effect (from p.g)
Date: 22 Aug 2002 10:35:02
Message: <Xns9272A965F69A4seed7@povray.org>
> blurring around it.
The plane of focus is always parallel to the "camera-plane" (unless you
sheared the camera). So you will never have a circular "spot" of focus,
but always something linear / planar.
Ingo
Date: 22 Aug 2002 11:16:49
Message: <3d650061$1@news.povray.org>
You have a "line" of focus because this represents the locus of equidistant
objects (surfaces?) from the camera when you have a plane slanting away from
you.
If instead you had say  a uniform field of particles (say an isosurface of
f_noise3d), then you would be right to expect a circular area to be in
focus, as these would be equidistant from camera.
Date: 22 Aug 2002 12:17:05
Message: <3D650E52.AAB6FED1@aol.com>
Quite acceptable if there were a plane tilting away from me. The object covered
with sand particles (440k, count 'em) is an <ahem> f_noise3d isosurface   ; }
Dave
Date: 22 Aug 2002 13:39:02
Message: <3d6521b6$1@news.povray.org>
I've seen other examples of this same behavior in the past.  The
documentation (6.4.3) indicates the blur should radiate from a focal point.
It says nothing about a "plane" of focus or it being linear. I think it is a
bug in Povray's focal blur.
"Dave Dunn" <poi### [at] aolcom> wrote in message
news:3D64EA58.40E092FC@aol.com...
Date: 22 Aug 2002 14:09:47
Message: <3d6528eb@news.povray.org>
point.
a
No. The area in focus should be the space near the surface of a sphere
around the camera, with a radius of the distance between the camera location
and the focal point. That is, all points that have the same distance from
the camera as the focal point does should be in focus.
The docs may be misleading here.
 - Slime
[ http://www.slimeland.com/ ]
Date: 22 Aug 2002 14:41:10
Message: <3D653018.7629021E@aol.com>
Well, that makes sense then, and reinforces my original idea that the cause of
my particular odd blurring was that my look_at and my focal_point were two
different vectors. If they are the same, this imaginary "sphere" around the
camera will intersect at one point, i.e. where look_at/focal_point coincide. If
they are different, there should be an arc shaped ring between the f_p, and the
l_a, which is exactly what I experienced.
Date: 22 Aug 2002 15:31:33
Message: <Xns9272DBAB9D704seed7@povray.org>
in news:3d6521b6$1@news.povray.org Patrick Dugan wrote:
> The
> point.
"The center of the zone of sharpness is specified by the focal_point
vector. Objects close to this point are in focus and those farther from
that point are more blurred. The default value is focal_point<0,0,0>."
Is this the part that makes you think that the area of focus is
circular? If so it probably needs to be re-phrased.
> think it is a bug in Povray's focal blur.
The secene below tries to illustrate that it is a plane of focus, just
like in the real world.
#version 3.5;
global_settings {assumed_gamma 1.0}
  location  <3.0, 0.0, -3.0>
  look_at   <0.0, 0.0,  0.0>
  aperture 20.0
  blur_samples 50
  focal_point <0,0,0>
  confidence 0.99
  variance 0.001
light_source {<500,500,-500>, rgb 1}
plane {y, -1 pigment { checker}}
sphere {
  0.0, 0.5
  pigment {rgb 1}
Ingo
Date: 22 Aug 2002 17:04:40
Message: <3d6551e8@news.povray.org>
"Dave Dunn" <poi### [at] aolcom> skrev i melding
I thought it worked that way too, and asked same question a few months back.
Although you already got some answers, I suggest reading the tread here:
http://news.povray.org/povray.binaries.images/23677/
I also suggest (as Peter Popov suggested me in the tread above) you try out
DoF.inc, it really helps a lot when setting focal point and aperture. You
can find it here:
http://www.wozzeck.net/images/DoF.html
Good luck!
_.-=^=-._.-=[ Peter ]=-._.-=^=-._
  _.-=[ http://hertel.no/peter ]=-._
Date: 23 Aug 2002 14:52:10
Message: <3d66845a@news.povray.org>
cause of
the
coincide. If
and the
Hmm? No, the look_at point has *absolutely nothing* to do with focal blur.
If you have a focal point 2 units away from the camera, and a look_at point
2000 units away from the camera, then everything 2 units away from the
camera will be in focus.
The arc is caused by the intersection of the surface of the sphere with the
surface of the plane.
 - Slime
