POV-Ray : Newsgroups : povray.binaries.images : Function-Based Shader Macro Server Time
28 Feb 2026 17:42:26 EST (-0500)
  Function-Based Shader Macro (Message 1 to 10 of 11)
Subject: Function-Based Shader Macro
Date: 16 Aug 2002 22:34:23
Message: <3D5DB601.C180803D@aol.com>
Nothing earthshattering here, just a test of a macro I made after
looking at the source on a few DarkTree shaders. It's simply a
f_ridged_mf function with different offset, noise, scale, color and bump
size settings. I like it because it doesn't look "POV-like" for some
reason.
Download 'shader.jpg' (45 KB)
Preview of image 'shader.jpg'
Subject: Re: Function-Based Shader Macro
Date: 17 Aug 2002 00:02:30
Message: <3d5dcad6$1@news.povray.org>
Nice Dave I like the middle one the best. BTW Long time no see.
"Dave Dunn" <poi### [at] aolcom> wrote in message
news:3D5DB601.C180803D@aol.com...
> reason.
Date: 17 Aug 2002 02:35:25
Message: <3D5DEEAD.3030708@frustratedhousewives.zzn.com>
Lovely. My favourite is the bottom left one. May we have a look at the
source?
/ Martin
Date: 17 Aug 2002 08:55:34
Message: <3D5E486E.1651920F@aol.com>
> source?
Thanks for your interest. I will post in povray.text.scene.files.
Dave
Date: 17 Aug 2002 10:08:00
Message: <170820021008019771%spam-lowmagnet@is-speakeasy.bad-net>
In article <3D5DB601.C180803D@aol.com>, Dave Dunn <poi### [at] aolcom>
> reason.
I too have been messing with custom 'shaders'..
Is there any way to map specularity etc to a function? All of my
attempts to do so so far have been met with error.
Date: 17 Aug 2002 10:47:56
Message: <3D5E61F0.618B8540@aol.com>
Hmm, hope this doesn't get too far off topic, but I believe there was a debate
a few months back on povray.general about the concept of finish maps. I don't
know what the technical limitations are on actually programming them into POV,
but it seems to make logical sense to have pigment/normal/finish all accept
the same patterns - this is especially useful for "cutaway," that is,
partially-transparent patterns. The conventional wisdom is to simply make a
texture map with various materials, but that is the hard way IMO.
Date: 17 Aug 2002 20:53:10
Message: <chrishuff-B27C9B.19395817082002@netplex.aussie.org>
In article <3D5E61F0.618B8540@aol.com>, Dave Dunn <poi### [at] aolcom>
One possibility would be to allow you to specify a function for any
float, color, or vector value in the finish...would that satisfy you? ;-)
There would be a small speed penalty from the overhead of choosing
between a function and a constant, but an enormous increase in
flexibility. It would require lots of rewriting though.
http://tag.povray.org/
Date: 17 Aug 2002 22:08:08
Message: <3D5F015C.594862FF@aol.com>
That is exactly what I was thinking. Since I have finally "come around" to using
functions, I like them better than plain old pattern identifiers anyway, if only for
consistency's sake. Now if we only had a null pattern identifier to make empy spaces
in normal maps, but that of course is a different story...   ; }
Date: 18 Aug 2002 00:25:24
Message: <chrishuff-E9B021.23121617082002@netplex.aussie.org>
In article <3D5F015C.594862FF@aol.com>, Dave Dunn <poi### [at] aolcom>
> around" to using functions, I like them better than plain old pattern
> identifiers anyway, if only for consistency's sake. Now if we only
> had a null pattern identifier to make empy spaces in normal maps, but
Just specify a solid pattern (a function pattern with a constant value).
Normal perturbation only uses the *change* in a pattern, a constant
pattern won't affect the normal. Try the checkers pattern as a normal
sometime, the normal only changes at the cube boundaries.
Date: 18 Aug 2002 04:49:09
Message: <3D5F5F85.A63CB5A@gmx.de>
This has already been done in mlpov (a french patch):
Dans la partie finish d'une texture, au lieu d'un float ou d'une couleur
fonction. Attention il faut que la fonction retourne une valeur/une
finish {
    [uv_mapping]
    ambient COLOR | VECTOR_FUNCTION_IDENT | VECTOR_FUNCTION
    diffuse Amount | FLOAT_FUNCTION_IDENT | FLOAT_FUNCTION
    brilliance Amount | FLOAT_FUNCTION_IDENT | FLOAT_FUNCTION
    phong Amount | FLOAT_FUNCTION_IDENT | FLOAT_FUNCTION
    phong_size Amount | FLOAT_FUNCTION_IDENT | FLOAT_FUNCTION
    specular Amount | FLOAT_FUNCTION_IDENT | FLOAT_FUNCTION
    roughness Amount | FLOAT_FUNCTION_IDENT | FLOAT_FUNCTION (Cf. warning)
    reflection COLOR | VECTOR_FUNCTION_IDENT | VECTOR_FUNCTION
    reflection {
      Color_Reflection_Min | VECTOR_FUNCTION_IDENT | VECTOR_FUNCTION
      Color_Reflection_Max | VECTOR_FUNCTION_IDENT | VECTOR_FUNCTION
      falloff FLOAT_FALLOFF | FLOAT_FUNCTION_IDENT | FLOAT_FUNCTION
      exponent FLOAT_EXPONENT | FLOAT_FUNCTION_IDENT | FLOAT_FUNCTION (Cf.
warning)
    irid {
      Irid_Amount | FLOAT_FUNCTION_IDENT | FLOAT_FUNCTION
      thickness Amount | FLOAT_FUNCTION_IDENT | FLOAT_FUNCTION
See: news://news.zoo-logique.org/aj8g57%241i8%241%40hebus.grizzlydev.com
I have not tried it yet, but it seems to work.  It would of course be good
if the functions would also take into account the other intersection
information (i.e. normal, ray direction).
