POV-Ray : Newsgroups : povray.binaries.images : T-13 Fisher Recon Starfighter Server Time
18 Nov 2024 14:26:04 EST (-0500)
  T-13 Fisher Recon Starfighter (Message 1 to 8 of 8)
Subject: T-13 Fisher Recon Starfighter
Date: 11 Aug 2002 21:47:37
Message: <3D571350.54666526@yahoo.co.uk>
Created to illustrate a game book, though when it's inserted in the
book, it's on a white backdrop.  (It just looks nicer against black.)
Comments?  Suggestions?  Tomatoes?
ICQ#66022322
  "It's a terrifying thing, isn't it?  To live in fear.
	 That's what it's like to be a slave."
	--Rutger Hauer, Bladerunner
Download 'fisher.jpg' (23 KB)
Preview of image 'fisher.jpg'
Subject: Re: T-13 Fisher Recon Starfighter
Date: 12 Aug 2002 12:22:54
Message: <3D57E149.3070104@earthlink.net>
Well...
At the risk of being a nogoodnik...
You've created an atmospheric fighter here, not a starfighter.  You have
twin engines which have thrust along the longitudinal axis, which is
nice, but you don't seem to have any reaction control thrusters... your
figher couldn't turn in space.
Also, it could use more surface texture... greeblies, if you will.
 Weathering, paint, unit markings... something.  Anything.
A good start, though!
> <cid:par### [at] netscapecom>
Date: 12 Aug 2002 15:51:01
Message: <chrishuff-BBF575.14391812082002@netplex.aussie.org>
In article <3D571350.54666526@yahoo.co.uk>,
I guess "Starfighter" is just a name, because this doesn't resemble any
kind of spacecraft. All aerodynamic surfaces, engines applying thrust
close to the center of mass, that big glass cockpit cover...
http://tag.povray.org/
Date: 12 Aug 2002 16:45:44
Message: <3D581E17.CDA46351@yahoo.co.uk>
Dawn McKnight wrote:
> Well...
Welll...actually, it's meant to be a dual-purpose ship, both atmospheric
and space.  The two 'engines' are reaction-mass tanks;  the engine
itself is centerline.
I figured that reaction thrusters would be placed on the wingtips, nose
and tail;  haven't added any yet.
Yeah...no idea how to do that without using external textures, and I
don't wanna do that.  I'd definitely like to add some control surfaces
to the wings and tail...got lazy on that.
But as for unit patches...how the heck would I do that?  The only way I
can think of is by using an external texture, and I'd rather not do
that.  It always looks like hell, compared to what the renderer itself
is capable of.  The other option is to painstakingly build it with
zillions of tiny triangles, and embed the mesh into the
wing...shudder...
ICQ#66022322
Date: 17 Aug 2002 16:02:13
Message: <3D5EABC2.1010902@mac.com>
The usual way is to use an image map.  As long as the resolution of the
image map is higher than the resolution at which your image is rendered,
it'll look fine.
My own 'Void Sphinx' fighter (which you can find in the archives, if you
search on those words) used this method.
You could also create a simple design as CSG objects, and difference
them from your main object.  I've used this technique as well, and it
works fairly well.
A unit marking doesn't have to be complicated... a red square with the
number 12 in it, for instance, could be created using the box and text
primitives.
Date: 17 Aug 2002 16:34:57
Message: <chrishuff-487110.15214617082002@netplex.aussie.org>
In article <3D5### [at] maccom>,
> it'll look fine.
There is little relation between useable image_map resolutions and the
render size, perspective and scaling could let you get away with very
low-res maps or require much higher resolution.
> works fairly well.
An easier technique would be to use the object pattern to change the
texture or create a new texture layer. For simple geometric designs, you
could have the entire texture generated within POV, with no resolution
worries.
Date: 18 Aug 2002 01:28:01
Message: <3d5f3061@news.povray.org>
> > it'll look fine.
A guesstimate at best. However, I read on dvgarage.com somewhere that an image
resolution of 1.5 to 2 times the size of the area occupied within the final
render.
light_source{0,1}#macro c(J,a)sphere{0,1pigment{rgb z}scale a translate J+O}
#end#macro B(R,V,O)c(0,4)intersection{c(V,R)difference{c(-z*4x+10)c(-z*4.1x+
10)c(0<7.5,45,5>)}}#end B(12,0z*25)B(8y*4<0,12,50>)          // Batronyx ^"^
Date: 18 Aug 2002 10:36:11
Message: <3d5fb0db$1@news.povray.org>
> render.
 . . . .is strongly recommended.
