POV-Ray : Newsgroups : povray.binaries.images : Round Brick wall/other structure. Server Time
13 Jul 2026 05:51:35 EDT (-0400)
  Round Brick wall/other structure. (Message 1 to 1 of 1)
Subject: Round Brick wall/other structure.
Date: 31 Jul 2002 15:03:39
Message: <3D483542.44B148C3@Rapidnet.com>
I was reading through the posts (It's been a while since I posted
here.) and found one from marabou about creating a brick structure with
pre-defined objects.
I was having a similar problem creating the below scene, and couldn't
find a macro that I could use online, so I created my own.
    The macro takes the parameters for inner and outer radius.  Then
finds the value of one foot degrees by taking C/360, this value is
multiplied by the length of the brick plus the width of the mortar to
produce a rotational value around the y axis.  The result is a curved
wall, clipped by an opposing difference between two boxes and a
cylinder.
    This result is then scaled to the desired height by layering the
bricks, with each layer staggered.
    I can post the code for this macro if anyone is interested.
A.D.B
Download 'sorcery.jpg' (119 KB)
Preview of image 'sorcery.jpg'
