POV-Ray : Newsgroups : povray.binaries.images : WIP Library Server Time
17 Nov 2024 18:16:41 EST (-0500)
  WIP Library (Message 1 to 6 of 6)
Subject: WIP Library
Date: 28 Jul 2002 14:16:26
Message: <3D4434F8.6030701@bellsouth.net>
Scene contains 683 frame level objects; 0 infinite.
Statistics for library.pov, Resolution 640 x 480
Pixels:          307850   Samples:         2151050   Smpls/Pxl: 6.99
Rays:           8878446   Saved:            121800   Max Level: 10/10
Ray->Shape Intersection          Tests       Succeeded  Percentage
Box                        13803145632      8840266493     64.05
Cone/Cylinder               4207070609      2767553671     65.78
CSG Intersection            4580610995      3682138795     80.39
CSG Merge                     54803405         2716612      4.96
CSG Union                   1050824354        38387868      3.65
Prism                           430767           45364     10.53
Prism Bound                    2847189         2628747     92.33
Sphere                      2540736121      1996228876     78.57
Torus                        469477761        28117769      5.99
Torus Bound                  469477761        34403855      7.33
Bounding Box              131696701820     43436854723     32.98
Roots tested:             34498139   eliminated:              598521
Calls to Noise:       263103663408   Calls to DNoise:   521870753998
Media Intervals:        3288499117   Media Samples:      42768243114 (13.01)
Shadow Ray Tests:       4416374399   Succeeded:           1784409776
Reflected Rays:             210516
Transmitted Rays:           311069
Radiosity samples calculated:      77044 (0.97 percent)
Radiosity samples reused:        7852198
Smallest Alloc:                 25 bytes   Largest:            12844
Peak memory used:         14156161 bytes
Time For Trace:   91 hours 31 minutes  44.0 seconds (329504 seconds)
     Total Time:   91 hours 31 minutes  44.0 seconds (329504 seconds)
CPU time used: kernel 67.48 seconds, user 283510.03 seconds, total
283577.52 seconds
Render averaged 1.08 PPS over 307200 pixels
POV-Ray finished
...and the worst part of it is, I'm not even done with this.  I had some
ideas for it, such as making the image greyscale except for one candle,
adding a ghost also in full colour, and a Hunter with a gun pointed at
the ghost...the first is easy enough, but the second will involve going
at Poser with a sledgehammer.
Tim Cook
Version: 3.12
Download 'library.jpg' (19 KB)
Preview of image 'library.jpg'
Subject: Re: WIP Library
Date: 28 Jul 2002 16:10:57
Message: <3d444fd1@news.povray.org>
why does it takes 91hours to render what's your CPU ?
3D4### [at] bellsouthnet...
(13.01)
> 283577.52 seconds
> POV-Ray finished
> Tim Cook
> http://empyrean.scifi-fantasy.com
> mirror: http://personal.lig.bellsouth.net/lig/z/9/z993126
> -----BEGIN GEEK CODE BLOCK-----
> Version: 3.12
> GFA dpu- s: a?-- C++(++++) U P? L E--- W++(+++)>$
> N++ o? K- w(+) O? M-(--) V? PS+(+++) PE(--) Y(--)
> PGP-(--) t* 5++>+++++ X+ R* tv+ b++(+++) DI
> D++(---) G(++) e*>++ h+ !r--- !y--
> ------END GEEK CODE BLOCK------
Date: 28 Jul 2002 16:17:34
Message: <3D44515D.6070707@bellsouth.net>
1.8 GHz Pentium IV with 512 MB of DDRAM, 400 MHz FSB.
The reason it took so long is because I've got the room
filled with media, and I have radiosity turned on, and
focal blur.
Tim Cook
Version: 3.12
Date: 29 Jul 2002 05:37:38
Message: <Xns925A75B01E7Braf256com@204.213.191.226>
"Timothy R. Cook" <z99### [at] bellsouthnet> wrote in
news:3D4### [at] bellsouthnet
> focal blur.
LOL :) how about adding photons ?
Date: 29 Jul 2002 09:42:36
Message: <3D45464C.3010700@bellsouth.net>
Wait for the next release of Moray.
Tim Cook
Version: 3.12
Date: 29 Jul 2002 17:28:48
Message: <3D45B448.26BF7B1F@applesnake.net>
IMO just not worth the trace time.  I'd render it sharp and use PSP or
something...  I really can't see using a tracer for what is basically
amounting to 2d work at this point.
91 hours!?
Wow.  Give your cpu my best regards! :)
-peter
Modeling slave:
"Ballet pour ma fille."
http://www.applesnake.net
