POV-Ray : Newsgroups : povray.binaries.images : Traunslucency Without Media MIP Server Time
14 May 2026 19:50:58 EDT (-0400)
  Traunslucency Without Media MIP (Message 1 to 10 of 13)
Subject: Traunslucency Without Media MIP
Date: 9 Jul 2002 21:35:45
Message: <3D2B8F65.AD2E3E12@aol.com>
Here is an image that came out of a discussion in our Thrursday night
POV-Ray chat on AOL. The idea was to obtain a subsurface scattering
effect without using media, just to see if it could be done. While far
from perfect, this method shows promise, but is very slow.
Download 'test2.jpg' (10 KB)
Preview of image 'test2.jpg'
Subject: Re: Traunslucency Without Media MIP
Date: 10 Jul 2002 01:53:42
Message: <3d2bcbe6$1@news.povray.org>
3D2B8F65.AD2E3E12@aol.com...
May we know? :)
concentrical semi-transparent spheres?
And is it faster than a scattering media?
C U
Marc
Date: 10 Jul 2002 05:31:40
Message: <slrnainusr.aol.steve@zeropps.org.uk>
It'd be interesting to know what method you used.
                                             or http://start.at/zero-pps
 10:16am  up 12 days, 20:35,  1 user,  load average: 1.09, 1.09, 1.02
Date: 10 Jul 2002 10:54:34
Message: <3D2C4A9D.E20B02E0@aol.com>
> C U
> Marc
I'm impressed. Progressively transparent is more like it, as the loop
increses the filter value and the rgb value, and decreases the roughness and
diffuse value as the spheres get bigger. Not really faster, or better than
media yet, just different.
Date: 10 Jul 2002 14:04:55
Message: <3D2C773D.1010907@caltel.com>
Glad to see you're still posting here, Dave :) Have you tried this trick
using cylinders, cones and torii in csg operations yet? Those objects
should take well to linear transformations, as opposed to blobs and
isosurfaces which may give strange results using this technique.
Samuel Benge
sbe### [at] caltelcom
Date: 10 Jul 2002 15:43:36
Message: <3D2C8E59.18EFAF5A@aol.com>
As a matter of fact, I am currently working on a couple of crayons using this
technique, involving CSG of a cylinder and a cone, scaled in two directions.
If it works out, I will post.
Date: 10 Jul 2002 16:33:37
Message: <3d2c9a21$1@news.povray.org>
I tried doing this myself a few weeks ago and the results using concentric
spheres were significantly slower then media.  I thought this was a similar
technique to the stacked-planes-clouds which are remarkably faster then
scattering media clouds.  I must be mistaken somewhere.
Skip
Date: 10 Jul 2002 16:51:28
Message: <3d2c9e50$1@news.povray.org>
BTW if you want hi Q stacked clouds , you need a lot of planes and it
becomes slower and slower
Marc
3d2c9a21$1@news.povray.org...
similar
> Skip
Date: 10 Jul 2002 22:03:04
Message: <3D2CE74B.2916C3F8@aol.com>
Well, as I said, I just started playing with this method. The thing I like
about it is that it gives you a lot of control over things that happen
incrementally "inside" your composite object. By incrementing and decrementing
features (such as roughness), you can get some interesting effects. I don't
think it's any better than media, overall, just an interesting thought
exercise. The slowness factor, in my case, was a max_trace_level of 100, for
100 nested spheres. I believe the falloff is much sooner than that, and I
probably could have gotten by with a lower trace level. More on this method
when the crayons are finished.
Dave
Date: 11 Jul 2002 15:54:06
Message: <MPG.1797f33af91f8e37989b84@news.povray.org>
Hmm...  To really slow things down, would there be any way to use the
trick to simulate variable internal IOR, however crudely?
It would probably require an obscenely high max_trace_level though.
And i can't remember if you can apply a pattern to the surface iro or
not, as I't sbeen a while since I played with POV.
Jamie.
